IPB
Здравствуйте, гость ( Вход | Регистрация )
> eMule Magic Angel, 03/11/2006 - based on MorphXT
Рейтинг 5 V
Da GuRu
сообщение Nov 4 2006, 09:58
Сообщение #1
Группа: Постоянные посетители
Вставить ник
Пользователь №: 20466
Спасибо сказали: 30 раз(а)
eMule 0.47c Magic Angel v2.1
Changelog for eMule v.47c [Magic Angel v2.1]
-4 nov 2006
based on MprhXT v9.2
FIXED: Multi User Webinterface Tab
Changelog for eMule v.47c [Magic Angel v2.0]
- 22 oct 2006
based on MorphXT v9.1
ADDED: Push small/rare files and file by ratio [sivka/codes from NeoMule]
ADDED: enable/disable Powershare for Leechers
CHANGED: Release Boost works only for complete files
CHANGED: DLP code to Xtreme v5.3
CHANGED: Anti Ghost Mod bans also unkown tag in info packet
CHANGED: Show Size of extra bytes
CHANGED: Also detect extra bytes in info packet
CHANGED: Colored Upload: now you can decide if Morph UL-Slot colors should be used too
CHANGED: all MB-values in Angel Argos preferences window are now KB-values
CHANGED: Quickstart on IP Change can now only set enabled when QuickStart is enabled
CHANGED: FileBuffer Size to max 20MB
FIXED: bug with Anti Uplaoder Ban
FIXED: display bug with max anti upload protection limit
FIXED: displaying of Webcache Icon in Download List
FIXED: some bugs with "Inform Leechers"
FIXED: bug with Quickstart time calculation
UPDATED: German lang.dll
Download Mirrors:
eMule-0.47a-MagicAngel-v2.1-bin.rar
eMule-0.47a-MagicAngel-v2.1-src.rar
Download more versions of eMule Magic-Angel.MoD
Rate eMule Magic-Angel.MoD @ emule-mods.de !!!
Перейти в начало страницы
+Цитировать сообщение
Начать новую тему
> Ответов (1 - 10)
Da GuRu
сообщение Apr 10 2007, 14:40
Сообщение #2
Вставить ник
eMule 0.47c Magic Angel v2.2
Changelog for eMule v.47c [Magic Angel v2.2]
-9 apr 2007
based on MorphXT v9.6
>> this version comes from evcz not from the original modder sFrQlXeRt <<
MERGED: to MorphXT 9.6
CHANGED: CS order as in MorphXT [evcz]
FIXED: Anti Upload Protection default credit value based on the CS in use [evcz]
FIXED: Anti Upload Protection when the other client have not yet uploaded to us [evcz]
REMOVED: Multiple Instances
ADDED: HDD protect
ADDED: Adjustable Buffer Time Limit
CHANGED: DLP code from Xtreme v5.4.2
ADDED: Applejuice to GPL breakers into MagicAntiLeech.dll (now V3)
ADDED: Wikinger to GPL breakers into MagicAntiLeech.dll (now V3)
Download Mirrors:
eMule-0.47c-MagicAngel-v2.2-bin.rar
eMule-0.47c-MagicAngel-v2.2-src.rar
Features & Changelogs for eMule Magic-Angel.MoD
eMule Tools: Server.met - Server-List - IPFilter - Skins
Da GuRu
сообщение Apr 13 2007, 10:17
Сообщение #3
Вставить ник
eMule 0.47c Magic Angel v2.3
Changelog for eMule v.47c [Magic Angel v2.3]
- dd apr 2007
ADDED: Reask Sources after IP Change v4 (Xman) [sFrQlXeRt]
ADDED: Reconnect Kad on IP Change (Xman) [sFrQlXeRt]
ADDED: File Faker Detection (DavidXanatos) [sFrQlXeRt]
ADDED: set Punishment for XS-Exploiter (and not just answer them like before) [sFrQlXeRt]
ADDED: Use own text to inform Leechers (if empty default text will be used) [evcz/sFrQlXeRt]
ADDED: Intelligent Filebuffer Flushing (WiZaRd) [sFrQlXeRt]
ADDED: Color Known Clients list too to Colored Upload [sFrQlXeRt]
ADDED: Show Filenames and Search-Keyword of Kad searches in Kad search list [sFrQlXeRt]
CHANGED: Filebuffer flush size min 512KB, max 40MB [sFrQlXeRt]
CHANGED: increased Filebuffer flush size slider tic frequence to 1 tic every MB and range to 512KB [sFrQlXeRt/evcz]
CHANGED: improved colored upload code and added color brown for the download state no needed parts [sFrQlXeRt]
CHANGED: only enable anti-leecher features that can be used (depending on if/wich leecher detection file is loaded) [sFrQlXeRt]
CHANGED: Nick Thief and Mod Thief detection now works also if no leecher detection file is loaded [sFrQlXeRt]
CHANGED: Download URLs: now all links go directly to the download page on SourceForge [evcz]
CHANGED: show more info about leecher hello and info tags in Morph Log [sFrQlXeRt]
CHANGED: minor changes on adjustable file buffer flush time code [sFrQlXeRt]
CHANGED: Magic Angel Other Settings tree group icon [sFrQlXeRt]
FIXED: bug with SUQWT and extended credit-table-arrangement (thanks to Stulle for the note) [sFrQlXeRt]
FIXED: Emulate Others eDonkey and MLDonkey didn't work [sFrQlXeRt]
FIXED: XS-Exploiter Detection didn't work [sFrQlXeRt]
FIXED: minor bug of v2.2 that a soft leecher couldn't be identified as a hard leecher anymore [sFrQlXeRt]
FIXED: Color Queuelist was coloring knwon clients list in v2.2 [sFrQlXeRt]
FIXED: Magic Angel Toolbar Icons were missing in v2.2 [sFrQlXeRt]
FIXED: showing Magic Angel Mod icon for Mod Thief Leechers [sFrQlXeRt]
FIXED: all eMule Morph compiler errors [sFrQlXeRt]
FIXED: eMule Morph bug showing wrong tab icon on switich tabs in Webserver preferences [sFrQlXeRt]
FIXED: eMule Morph bug opening wrong tab on re-opening Webserver preferences [sFrQlXeRt]
REMOVED: Community detection preferences (they had no use because this leecher was detected with Bad Hello detection) [sFrQlXeRt]
REMOVED remaining codes of old Reask Sources after IP Change v2 (we have v4 now) [sFrQlXeRt]
UPDATED: German language file with new Magic Angel preferences [sFrQlXeRt]
Download Mirrors:
eMule-0.47c-MagicAngel-v2.3-bin.rar
eMule-0.47c-MagicAngel-v2.3-src.rar
Da GuRu
сообщение Jun 9 2007, 09:06
Сообщение #4
Вставить ник
eMule 0.48a Magic Angel v3.0
- 9 jun 2007
based on MorphXT v10.0
MERGED: to MorphXT v10.0 [sFrQlXeRt]
ADDED: Recognize MlDonkey XS Answer (Spike2/ideas by Wiz) [sFrQlXeRt]
CHANGED: use redirecting download links for all Magic Angel versionchecks [evcz]
CHANGED: some minor code changes on Magic Angel and Magic Angel+ Creditsystem [sFrQlXeRt]
CHANGED: Clients always have at least 1MB uploaded to us for the division-modifier calculation of Magic Angel Creditsystems
CHANGED: Magic Angel Creditsystems Score calculation for linear calculation of eMule v0.48a [sFrQlXeRt]
CHANGED: show more infos within the tooltip in UploadList [evcz]
FIXED: Magic Angel Creditsystems with Anti Upload Protection [sFrQlXeRt]
FIXED: Magic Angel+ Creditsystem bonus factor calculation [sFrQlXeRt]
FIXED: Magic Angel Creditsystems modifier calculation if we uploaded to a client but he didn't upload to us [sFrQlXeRt]
FIXED: SUQWT bug setting wrong waiting time for clients after restart of v2.3 [sFrQlXeRt]
FIXED: aligned client detail window better [evcz]
FIXED: missing Magic Angel icon in Queuelist for the last few versions [sFrQlXeRt]
FIXED: one DLP update link still went to Xtreme Homepage and not directly do SourceForge [sFrQlXeRt]
FIXED: Leecher Icon couldn't be shown for eDonkey-Hybrid or MLDonkey Clients in some lists (e.g. as Agressive Clients) [sFrQlXeRt]
FIXED: Morph not saving Obfuscated Sources didn't work [sFrQlXeRt]
FIXED: displaying fairplay string in Queulist [evcz]
FIXED: Color Known Clients List too preference wasn't loaded [sFrQlXeRt]
REMOVED: all remaining code parts of Multiple Instances (they caused a bug on startig a 2nd instance) [sFrQlXeRt]
UPDATED: Emulate other clients (Spike2) [sFrQlXeRt]
UPDATED: Enhanced Client Recognition (Spike2) [sFrQlXeRt]
UPDATED: German language file to be compatible with eMule v0.48a [sFrQlXeRt]
Download Mirrors:
eMule-v0.48a-MagicAngel-v3.0-bin.rar
eMule-v0.48a-MagicAngel-v3.0-src.rar
Da GuRu
сообщение Aug 4 2007, 21:09
Сообщение #5
Вставить ник
eMule 0.48a Magic Angel v3.1
Changelog for eMule v.48a [Magic Angel v3.1]
- 05 july 2007
MERGED: to MorphXT v10.1 [evcz]
ADDED: *LOGGING-ONLY* - Secure Source Exchange (beta) - Detects clients sending source response with invalid ips [sFrQlXeRt]
FIXED: Crash with Secure Source Exchange in 3.1beta1 when adding an ed2k link with IP [evcz]
ADDED: [EMULATE]Emulate Community Nick Addon (*only clients not punished are emulated*) [evcz]
FIXED: Load from preferences MA and MA+ creditsystem correctly [evcz]
FIXED: Link in server window pointing to Magic Angel homepage [evcz]
FIXED: Leecher Icon overlay [evcz]
ADDED: AJ-community-detection by userhash, code from xtreme 6.1 (Detect Userhashes, GPL breaker punishmet) [evcz]
Download Mirrors:
eMule-v0.48a-MagicAngel-v3.1-bin.rar
eMule-v0.48a-MagicAngel-v3.1-src.rar
eMule: Server.met - Server-List - IPFilter - Skins - eMule Wiki
Спасибо сказали:
vic2
сообщение Aug 10 2008, 14:34
Сообщение #6
Вставить ник
Пользователь №: 68317
Спасибо сказали: 0 раз(а)
ScarAngel и Magic Angel -- это одно и то же? Чет не нашол темы про ScarAngel. Есть гдето рекомендации как перейти с официального мула на ScarAngel?
папаВлад
сообщение Aug 10 2008, 14:54
Сообщение #7
Вставить ник
Из: подмосковье
Пользователь №: 32522
Спасибо сказали: 443 раз(а)
eMule 0.49a ScarAngel v3.0
по скарангелу все вопросы туда
NeByvalyi
сообщение Aug 10 2008, 16:32
Сообщение #8
Иконка группы
Группа: [Хранители]
Вставить ник
Из: Нью-Васюки
Пользователь №: 4079
Спасибо сказали: 1557 раз(а)
Глубоко ОШИБОЧНОЕ мнение!!!
Скар - на базе Экстрима (более "эгоистический" мод), но зато есть свежая версия на базе 0.49а
Мэджик - на базе Морфа (мод для "справедливой" раздачи, больше подходит релизёрам), но пока есть только старая версия 3.1..
mss73
сообщение Aug 12 2008, 05:31
Сообщение #9
Руки прочь от ослика!
Вставить ник
Из: песни слова не выкинешь
Пользователь №: 12175
Спасибо сказали: 89 раз(а)
Из, того что Xtreme меньше подходит релизёрам - не надо делать вывод, что это более "эгоистический" мод. Можно догадаться какое значение именно ты вкладываешь в это слово, но со стороны несведующих это выглядит почти как "личерский".
Da GuRu
сообщение Nov 26 2008, 16:15
Сообщение #10
Вставить ник
eMule 0.49b Magic Angel v3.5
Changelog for eMule v.49b [Magic Angel v3.5]
MERGED: to MorphXT v11.1 [gomez82]
UPDATE: DLP from Xtreme7 [XMan/Stulle/ZZ00fly]
Download Mirrors:
eMule-0.49b-MagicAngel-v3.5-bin.rar
eMule-0.49b-MagicAngel-v3.5-src.rar
Da GuRu
сообщение Dec 14 2008, 18:10
Сообщение #11
Вставить ник
eMule 0.49b Magic Angel v3.6
eMule v.49b Magic Angel v3.6
CHANGED: some things to compile with VS2005[gomez82]
CHANGED: AntiModThief in Argos now uses WiZaRds AntiModthiefCode from ClientAnalyzer
FIXED: ClearMessageField[Tuxman]
FIXED: ReAskSourcesAfterIpChange: if we receive a LowID we do a recheck[XMan]
ADDED: open a default website when nodesurl is invalid[ZZ00fly]
ADDED: More Creditsystems(Sivka/Xtreme/SWAT/TK4/ZZUL) and some Code changes in Clientcredits[Stulle]
Download Mirrors:
eMule-0.49b-MagicAngel-v3.6-bin.rar
eMule-0.49b-MagicAngel-v3.6-src.rar
Спасибо сказали:
Быстрый ответОтветить в данную темуНачать новую тему
1 чел. читают эту тему (гостей: 1, скрытых пользователей: 0)
Пользователей: 0
RSS Текстовая версия Сейчас: 6th September 2010 - 15:52
              IPB Skins Team, стиль Retro
