-------------------------------------- Changelog for eMule 0.47c MorphXT v9.2 ------------------------------------- 3 nov-2006 Changed: USC review: Powersharing 100% is working again. Changed: (minor) Friendslot logging with funnynick more consistent. Changed: (minor) Copy comment, not username, on file details (pacobell)
-------------------------------------- Changelog for eMule 0.47c MorphXT v9.1 ------------------------------------- 21-Oct-2006 CHANGED:USC review upload splitting class code. CHANGED:Slotlimiter/3 relaxed a bit. CHANGED:Preferences for adding users in multiuser webserver reviewed. [leuk_he] -userData is now written to Webserver.ini. Conversion happens automatic. CHANGED:uPnP reverted to 8.10 intel library for better compatibility. ADDED: Send user agent as firefox for http downloads when obfucscation enabled. ADDED: Morph update: Weekly update ip filter & fakes. FIXED: import & sr13 import now work again. FIXED: Loosing spam prefs in messages preferences when security tab opened.
-------------------------------------- Changelog for eMule 0.47c MorphXT v9.3 ------------------------------------- 14-01-2007 ADD: Always show as trayicon option. ADD: Http links in ed2k links like linkcreator (MoNKi) ADD: Friendnote. Noting area for adding notes about friendlist. (CB mod) -Will be automatically saved and reloaded at each start-up. ADD: Static IP Filter (Stulle) remark: save "ipfilter_static.dat" in config dir ADD: run as NT service v1. [leuk_he] -No need to login into XP. -keeps running after logging out/ switching users -new command line options: "emule install" --> install as as ervice "emule uninstall" --> uninsntall as a service. -make sure all settings are correct before installing as a service. -links as passed to webservice. -See Preferences->Webserver->NTservice tab remark: Not meant to save cpu/memory. ADD: Context menu on chat context. (wizard codesnippet) ADD: Lost preferences. Most official preferences that got an prefereces.ini setting but no gui are Added in preferences->extented->Advanced preferneces. CHANGED:USC: better slotfocus. CHANGED:More upload speed for webcache requester. (no 100ms delay) CHANGED:And also DBR reviewed for high bandwidth transfer. CHANGED:Flush thread, improved. CHANGED:Better requested block queuing CHANGED:Sr-13 import, Also use AICH hash when required. FIX: Upnp: using same port for tcp & udp now possible. CHANGED:uPnP moved most logging to verbose level. FIX: sr-13 import: Chrash on cancel during running import. FIX: Chrash on low diskspace resume. ADDED: Official fix arround CreatePackedPackets (missed overhead filerequest value for file >4GB) 24 instead of 28
мне понравилось две добавки: Lost preferences. Most official preferences that got an prefereces.ini setting but no gui are Added in preferences->extented->Advanced preferneces. т.е все настройки которые были и в офиц. муле в файле preference.ini но не были видны в обычном муле, теперь видны и добавление функции run as service
Kolovrat мне кажется что слетают они не по вине морфа, а по вине офиц мула..потому что это еще при царе(офиц. муле) когда клиент пропадал на время, слот дружеский пропадал. Лечится банальным способом(имхо) но тратящим кое какие ресурсы, а именно keep alive запросами, как в обычных фтп клиентах.
Вроде как я помню, такие keep alive запросы есть в НЕО муле(смотрел по verbose), насчет морфа хз.
Кстати, насчет революционной вещи
когда скачал и посмотрел эти т.н скрытые настройки в морфе, я довольно ухмыльнулся, потому что в нео они уже давно в открытом виде.
Всем привет! Обновился до 9.3, дружеские слоты похоже ведут себя так же, как и в 9.2, слетают Надо посмотреть также часто как в 9.2 или нет. Как сервис может стартовать Webserver, мул похоже не может.. Доп. настроек добавилось, в настройках морфа добавилось регулирование компрессии. Пока ничего революционного не обнаружил. Посмотрю, как будет работать. Ох! перейду на НЕО, ей-богу перейду.... А может и нет, черт его знает!
ну почему же:) пусть хоть исправления местного значения но все же хоть какое то движение вперед CHANGED:USC: better slotfocus. CHANGED:Better requested block queuing
а насчет слетания дружеских слотов- пишите разработчику, может он о такой проблеме еще не знает.
-------------------------------------- Changelog for eMule 0.47c MorphXT v9.4 -------------------------------------- 24-01-2007 CHANGED:DBR: tuned for finishing downloads faster. CHANGED:Advanced preferences. Fix wrong values during reading. CHANGED:Advanced preferences. Add UseUserSortedServerList preference. CHANGED:Run As service, startup service detection. CHANDED:Vista/X64/win2003 detection to lower number of half open connenctions. CHANGED:Upload: smooth socket buffer when remote client is fast. CHANGED:Avoid GUI glitches due to Static Tray Icon UPDATE :Simplified chinese tranlation [pennyliu123] http://emulemorph.sourceforge.net/
Я предпочитаю на морфа давать муловский линк - не надо лазить по сайтам в поисках прямого линка да и качаться начинает сразу на максимальной скорости. eMulev0.47c.-MorphXTv9.4-bin.zip
-------------------------------------- Changelog for eMule 0.47c MorphXT v9.5 -------------------------------------- 04-02-2007 ADD: Servers ->obfuscated connection to server required preference. -Only obfuscated connections to servers are made. -fake/spy servers do no support obfuscation 8-) Note: you may have to increase server retries if you enable this option and enable serverlist from servers again.... ADD: startup wizard, New obfuscation required option to servers added. ADD: Startup wizard, show more controls and option to start import after wizard. REMOVE: Startup wizard, Set auto up/down file priority (default still is enabled..) ADD: Preferences groups (ePlus/Sirob) CHANGED: Complete pending hashing at shutdown like official to prevent rehash. ADDED : USC: limiting of opening slots with exponential delay based on the number of new connecting slot. ADDED : USC: Don't allow new slot to be opened if number of half connection reached the limit. CHANGED: USC: Reviewed to allow high latency remote client to download at a higher speed.
FIX: Default for advanced preference MEDIAINFO_RIFF/ID3LIB (avi/mp3) detection was unchecked, should be enabled.
This version adds a new option "show less controls" in the startup wizard that tunes the top bar & some lists so less information is shown. So you can now also advice morph to your begginner friends...
-------------------------------------- Changelog for eMule 0.47c MorphXT v9.6 -------------------------------------- 19-03-2007 ADD: Startup wizard, Show less controls: custimize toolbar and columns to show some less. Useful for beginners. FIX: load of multiuser web interface preferences in [webserver] section. FIX: mass rename:Unicode issue . FIX: Upnp: hang on close of upnp. CHANGED: massrename: resizeable dialog. CHANGED: Run as service. method "started" reported earlier. CHANGED: Run as service. Disabled some optimizations to fix 100% load issue. CHANGED: workarround failing to startup under wine. CHANGED: icon & tray icon. CHANGED: upnp "my info" displayed. CHANGED: upload splitting class: review code. CHANGED: ZZratio is active display in connection options. CHANGES: iMaxFilesPerTcpFrame in local server request tuned.
-------------------------------------- Changelog for eMule 0.48a MorphXT v10.0 -------------------------------------- 06-06-2007 Merged to 0.48a [Stulle] ADD: FollowTheMajority, a new feature that will auto rename your file with majority used, default action can be changed from ModOptions->EastShare->FollowTheMajority, can be direct active from right click or disable by any rename operation per file based. [AndCycle] ADD: FairPlay, at least upload one copy of downloaded file with priority. [AndCycle] REMOVED: WebCache (http://forum.emule-project.net/index.php?showtopic=124737) FIXED: Obfucated server only connect on first startup, Always send cryptping. ADD: Safe KAD :slows down the spreading of bad KAD nodes & kad cpu optimizations. (netfinity) FIX: KAD: save in coorect directory to prevent loosing kad pref under vista. (godlaugh2007) ADD: CryptTCPPaddingLength added to advanced preferences. Add: Anti Mod Faker [Xman] CHANGED: Never ask confirmation when emule stopped with "eMule.exe exit" CHANGED: Send non existing "morph 9.7" to old mods to work arround bug in morph anti leecher. CAHNGED: Do not save obfuscated sources [Xman] CHANGED: Calculate own score the new way for >= 0.48a clients FIXED: Official bug when dis/enabling Queuelist/Clientslist (Xman) FIXED: Official bug when checking for empty userhash (ilmira) FIXED: Hang(deadlock) on exit (xman)
