IPB
Здравствуйте, гость ( Вход | Регистрация )
> eMule ScarAngel Mod, based on Xtreme !
Da GuRu
сообщение Oct 28 2006, 20:39
Сообщение #1
Группа: Постоянные посетители
Вставить ник
Пользователь №: 20466
Спасибо сказали: 30 раз(а)
eMule 0.49a ScarAngel v3.3
eMule v0.49a ScarAngel v3.3:
- 06.07.2008 -
based on eMule 0.48a Xtreme 6.1 compiled with vs2003 SP1
Merged to eMule v0.49a [Stulle]
- Xtreme\'s heir -
- 03.12.2009 -
based on eMule 0.49c Xtreme 7.2 compiled with vs2008 SP1
Added: Date File Name Log (enabled by default) [AndCycle] - Stulle
Added: Ionix advanced (multiuser) webserver [iOniX/Aireoreion/wizard/leuk_he/Stulle] - Stulle
Added: Multiuser WebInterface (WI) Cookie settings [Aireoreion] - Stulle
+ added code missing in MorphXT so it works
Added: New failed login handling for WI [MorphXT/leuk_he/dreamwalker/Stulle] - Stulle
Added: Failed login screen for WebInterface [SiRoB/CommanderGer/Stulle] - Stulle
+ Also for multiuser WI
Added: Tabbed WebInterface settings panel [Stulle] - Stulle
+ For multiuser settings
Added: Extra logging to notify of missing webserver files [leuk_he] - Stulle
Added: PowerShare support for WebInterface [Stulle] - Stulle
+ fixed missing tick in menu and improper table display from StulleMule
Added: Rebind UPnP mappings (UDP, TCP and Webserver for now) like official [Stulle] - Stulle
Added: Run eMule as NT Service [leuk_he/Stulle] - Stulle
+ localized logging, cleaned up code
Added: Adjustable NT Service Strings [Stulle] - Stulle
Added: Extended Prompt on Exit dialog [leuk_he] - Stulle
Added: Friendslot support for WebInterface [Stulle] - Stulle
Added: Installer for eMule ScarAngel [leuk_he/Stulle] - Stulle
+ translations taken from eMule Morph so credits to the respective creators
Changed: Disable FollowTheMajority per file when file is renamed manually [AndCycle] - Stulle
Changed: Disable ASFU if too many folders are shared [Stulle] - Stulle
+ fixes related crashes; increases ASFU version number to 3.5
Changed: Only display cat selection dialog if there is more than one cat [Stulle] - Stulle
Fixed: Sorting priority descending failed for powershared files [Stulle] - Stulle
Fixed: UPnP setting in First Runtime Wizard [leuk_he] - Stulle
Fixed: Port settings in First Runtime Wizard for Random Ports feature [leuk_he] - Stulle
Fixed: Missing checkmark for PS limited by amount context menu [Stulle] - Stulle
Fixed: (Official) Malfunctioning search results in eMule Light template [Stulle] - Stulle
Fixed: Show last tab in ScarAngel prefs panel on reopening prefs dialog [Stulle] - Stulle
Fixed: Show friend menu in Friendlist of Webinterface [Stulle] - Stulle
Fixed: Design settings font colors overridden in UploadListCtrl [Stulle] - Stulle
Fixed: Personalize Feedback could not be turned off [Stulle] - Stulle
Note: Following languages updated/added: German [Stulle]; French [Heaven];
Chinese (P.R.C.) [jason_jiang]; Italian [Idro182]; Turkish [omeringen];
Spanish [guijarrelson]; Chinese (Taiwan) [alisa/DargonD]
Ionix advanced (multiuser) webserver:
+ You must select the multi user template to enable the multi user settings.
+ Changed user privileges (see below)
+ Added option to restrict user from downloading files via webserver.
+ Multiuser is enabled/disabled automatically on changing template.
Ionix advanced (multiuser) webserver user privileges:
+ Guest: Viewing information from webinterface
+ Operator: Adding/Removing downloads and according to other settings
+ Admin: Like Operator plus privilege to close eMule
+ Hi-Admin: Like Admin plus privilege to shutdown/reboot windows
Run as NT Service:
+ No need to login into windows
+ Keeps running after logging out/ switching users
+ New command line options:
- \"emule -install\" --> install as a service
- \"emule -uninstall\" --> uninstall as a service
+ Make sure all settings are correct before installing as a service
+ Links are passed to webservice
+ Option to set level of optimization (Full may cause errors!)
+ See Preferences->Web Server->NTservice tab
eMule ScarAngel.MoD Homepage
Download Mirrors:
Installer
[url=http://hostex.de/1259872711]Binary
eMule-0.49a-ScarAngel-v3.0-src.rar
Download more versions of eMule ScarAngel.MoD
Features & Changelogs for eMule ScarAngel.MoD
Rate eMule ScarAngel.MoD @ emule-mods.de !!!
Сообщение отредактировал Gadget - Jan 14 2010, 15:14
Перейти в начало страницы
+Цитировать сообщение
7 страниц V   1 2 3 > »
Начать новую тему
> Ответов (1 - 19)
Da GuRu
сообщение Oct 30 2006, 09:48
Сообщение #2
Вставить ник
eMule 0.47c ScarAngel v1.7
eMule v0.47c ScarAngel v1.7:
- 30.10.2006 -
based on eMule 0.47c Xtreme 5.3.1 compiled with vs2003 SP1
Added: Release Bonus (12h or up to 16 days) (not for partfiles) [sivka]
Added: Release Score assurance [Stulle]
Fixed: Crash on renaming/ deleting shared file [Stulle] - Stulle
Release Score assurance:
+ clients requesting complete files with release priority will not get
a score lower than the default unless they are Reduce Score clients
Download Mirrors:
eMule-0.47c-ScarAngel-v1.7-bin.rar
eMule-0.47c-ScarAngel-v1.7-src.rar
Da GuRu
сообщение Jan 4 2007, 07:51
Сообщение #3
Вставить ник
eMule 0.47c ScarAngel v1.8
based on eMule 0.47c Xtreme 5.4 compiled with vs2003 SP1
Added: XP-Style menus [Xanatos/ eMule-web.de staff] - Stulle
Added: Design Settings [eWombat/Stulle] - Stulle
Added: Static IP Filter [Stulle] - Stulle
remark: save "ipfilter_static.dat" in config dir
Added: Limit PS by amount of data uploaded [Stulle] - Stulle
Added: Enhanced Client Recognition [Spike]
Added: Compat Client Stats [Stulle] - Stulle
Added: Enforce Ratio [Stulle] - Stulle
Changed: Tabs in ScarAngel preferences dialog can be translated [Stulle] - Stulle
Fixed: Reset Spread Bars command [Stulle] - Stulle
Fixed: second categories column in DownloadList removed [Stulle] - Stulle
Removed: always one release slot [Xman] - Stulle
+ use PowerShare instead
Design Settings:
+ Only enabled styles will be applied
+ Styles sorted by importance in triggering (default excluded)
+ Combining two styles is impossible
Enforce Ratio:
+ Download will be limited when 80% of the max ratio is reached
+ Example: Ratio = 1:1 --> Limit when 1:0.8 to download = upload*1
+ Display details on ratio activation
Download Mirrors:
eMule-0.47c-ScarAngel-v1.8-bin.rar
eMule-0.47c-ScarAngel-v1.8-src.rar
eMule Tools: Server.met - Server-List - IPFilter - Skins
Gadget
сообщение Jan 4 2007, 09:55
Сообщение #4
Иконка группы
Группа: [Хранители]
Вставить ник
Из: Таллинн
Пользователь №: 4
Спасибо сказали: 1454 раз(а)
скрины
Прикрепленный файл  scarangel_backup.jpg ( 21,08 килобайт ) Кол-во скачиваний: 144
Прикрепленный файл  scarangel_design.jpg ( 17,99 килобайт ) Кол-во скачиваний: 135
Прикрепленный файл  scarangel_scarangel.jpg ( 147,44 килобайт ) Кол-во скачиваний: 133
Прикрепленный файл  scarangel_webcache.jpg ( 22,93 килобайт ) Кол-во скачиваний: 112
Прикрепленный файл  xtreme_antileech.jpg ( 27,74 килобайт ) Кол-во скачиваний: 114
Прикрепленный файл  xtreme_upload_managment.jpg ( 36,3 килобайт ) Кол-во скачиваний: 46
Da GuRu
сообщение Mar 25 2007, 15:15
Сообщение #5
Вставить ник
eMule 0.47c ScarAngel v1.9
CHANGELOG FOR EMULE ScarAngel MOD
eMule v0.47c ScarAngel v1.9:
- 25.03.2007 -
based on eMule 0.47c Xtreme 5.4.2 compiled with vs2003 SP1
Added: More icons in context menus [various] - Stulle
Added: Improved ICS-Firewall support [MoNKi] - Max
Added: Invisible Mode [TPT/MoNKi/SiRoB] - Stulle
Added: UPnP support [MoNKi/leuk_he] - leuk_he
Added: Random Ports [MoNKi] - Stulle
Added: Select window background color [MaxUpload] - Max
Added: Simple cleanup [MorphXT] - Stulle
remark: This is not in the Xtremes implementation, stick to older versions
Added: Support page in preferences [Stulle] - Stulle
Added: Default value for background colors [Stulle] - Stulle
Added: Design settings save version number (now v2) [Stulle] - Stulle
Changed: Superior clients inserted at first position in UL [Stulle] - Stulle
Changed: Various things around XP-Style menus [Stulle] - Stulle
Changed: Reworked "give waiting time back"-code for SUQWT [Stulle] - Stulle
Changed: Rewrote Design settings (one enum per master item) [Stulle] - Stulle
Changed: List backgrounds unrelated to items in list (instant change) [Stulle] - Stulle
Updated: Webcache [MorphXT] - Stulle
Fixed: Columns with wrong background in DlClients and QueueList [Stulle] - Stulle
Fixed: Webcache information drawn in wrong column [Stulle] - Stulle
Fixed: Sometimes client's credits are not updated though they should [Stulle] - Stulle
Fixed: ScarAngel horizontally truncated in Splash [Stulle] - Stulle
Removed: Unnecessary log line on Design settings changed [Stulle] - Stulle
Removed: UPnP support [Xtreme] - Stulle
Removed: Unused code of TBH: MiniMule implementation [Stulle] - Stulle
eMule ScarAngel Homepage
Download Mirrors:
eMule-0.47c-ScarAngel-v1.9-bin.rar
eMule-0.47c-ScarAngel-v1.9-src.rar
Da GuRu
сообщение Aug 13 2007, 11:48
Сообщение #6
Вставить ник
eMule 0.48a ScarAngel v2.1
eMule v0.48a ScarAngel v2.1:
- 13.08.2007 -
Added: Do not reserve 1/3 of your uploadlimit for emule [Stulle] - Stulle
Added: Disable accepting only clients who asked within last 30min [Stulle] - Stulle
+ Xtreme only grants upload to clients that asked within the last 30min
Added: Follow The Majority [AndCycle/Stulle] - Stulle
Added: Fair Play [AndCycle/Stulle] - Stulle
Added: Alwasy maximize slot speed [Stulle] - Stulle
Added: Timer for ReAsk File Sources [Stulle/ idea from sivka] - Stulle
+ Due to Spread Reasks the actual ReAsk time is: [SetTime]+{-3...0.5 minutes}
Changed: check mark superior to icon (MenuXP) [fafner] - Stulle
Changed: Quickstart for KAD-only connection [Stulle] - Stulle
Changed: No FunnyNick for bad guys [Stulle] - Stulle
Changed: Max enforced ratio to 1:10 [Stulle] - Stulle
Fixed: Saving of Cat version (save default Cat viewfilters) [Stulle] - Stulle
Fixed: GDI-Leaks around the context menus [Stulle] - Stulle
Do not reserve 1/3 of your uploadlimit for emule:
+ Only active if you upload more than download in this session.
+ Reserves only a minimum of 2 kB/s for eMule.
Download Mirrors:
eMule-0.48a-ScarAngel-v2.1-bin.rar
eMule-0.48a-ScarAngel-v2.1-src.rar
Da GuRu
сообщение Sep 8 2007, 18:42
Сообщение #7
Вставить ник
eMule 0.48a ScarAngel v2.2
eMule v0.48a ScarAngel v2.2:
- 08.09.2007 -
Changed: Recode of the file settings [Stulle]
Fixed: Crashfix in Upload list (FairPlay code) [Stulle] - Stulle
Fixed: Odd word invention "constantinously" to "constantly" [LorenzC]- Stulle
Fixed: Some more mem leaks [fafner] - Stulle
File Settings:
+ all .sivka files will be deleted
+ all settings will be stored in the FileSettings.ini
+ supports all current settings by StulleMule and ScarAngel
+ settings are saved on taking over SivkaFileSettings and on closing eMule
Download Mirrors:
eMule-0.48a-ScarAngel-v2.2-bin.rar
eMule-0.48a-ScarAngel-v2.2-src.rar
Da GuRu
сообщение Sep 17 2007, 10:01
Сообщение #8
Вставить ник
eMule 0.48a ScarAngel v2.3
eMule v0.48a ScarAngel v2.3:
- 17.09.2007 -
Added: Advanced Options [Official/leuk_he] - Stulle
Added: handling of one-time-events for Scheduler [Mighty Knife] - Stulle
Added: Weekly IPFilter update [leuk_he] - Stulle
Added: IP2Country update [MorphXT] - Stulle
Added: One click update for antiLeech.dll [Stulle] - Stulle
Added: Auto update antiLeech.dll [Stulle] - Stulle
Added: Display data difference on PBF in UploadList [Stulle] - Stulle
Changed: ASFU: Moved EndCall [Stulle] - Stulle
Changed: AFSU: Reset when en-/disabled [Stulle] - Stulle
Changed: Update IPFilter on every startup if enabled [Stulle] - Stulle
Changed: antiLeech.dll, ip-to-country.csv & ipfilter.dat not in BIN pack [Stulle] - Stulle
+ files will be updated/ downloaded on startup by default
Changed: Auto update IPFilter migrated to Update tab [Stulle] - Stulle
Changed: Enforce Ratio will start when configured ratio-0.1 reached [Stulle] - Stulle
+ Examples: 1:1 -> 1:0.9 ; 1:3 -> 1:2.9 ; 1:5 -> 1:4.9 ; ...
Changed: Enforce 1:1 ratio when configured enforce ratio exceeded [Stulle] - Stulle
Changed: Increased max slotspeed by 25% [Stulle] - Stulle
+ WARNING: If upload is less stable decrease slotspeed and/or enable OpenMoreSlots!
Changed: Increased maximum possible slot speed to 19 (by 26.6666%) {Stulle] - Stulle
Changed: Decrease MinSlots value and minmum by one if UL-health >= 75% [Stulle] - Stulle
Changed: Decrease MaxSlots value by one if slotspeed > 4kbps [Stulle] - Stulle
Changed: MuleListCtrl context menu (column context) in XP Style [Stulle] - Stulle
Changed: Icon for share folder commands in context menu [Official] - Stulle
Fixed: Loading of Cat version (fix default cat settings) [Stulle] - Stulle
Download Mirrors:
eMule-0.48a-ScarAngel-v2.3-bin.rar
eMule-0.48a-ScarAngel-v2.3-src.rar
Da GuRu
сообщение Oct 14 2007, 14:28
Сообщение #9
Вставить ник
eMule 0.48a ScarAngel v2.4
eMule v0.48a ScarAngel v2.4:
- 14.10.2007 -
Changed: Override max upload session time for PBF clients [Stulle] - Stulle
Changed: Override max upload session time for friends [Stulle] - Stulle
Changed: Keep friends in upload like PBF clients [Stulle] - Stulle
Changed: Do not reserve 1/3 if ratio is max 1:2 [Stulle] - Stulle
Changed: Only give back waitingtime if transferred < 9MB [Stulle] - Stulle
Changed: Do not give back waitingtime if it would be more than the old [Stulle] - Stulle
Changed: Only give back waitingtime if transfer completed [Stulle] - Stulle
Changed: Only give back waitingtime if SUQWT or FullChunk enabled [Stulle] - Stulle
Changed: Friends with friend slot always get superior status [Stulle] - Stulle
Fixed: Possible buffer overun in Enforce Ratio code [Stulle] - Stulle
Fixed: Do not reserve 1/3 of your uploadlimit for emule [Stulle] - Stulle
Fixed: Missed to enable Auto IPfilter update by default [Stulle] - Stulle
Download Mirrors:
eMule-0.48a-ScarAngel-v2.4-bin.rar
eMule-0.48a-ScarAngel-v2.4-src.rar
vadim92
сообщение Oct 17 2007, 07:34
Сообщение #10
Вставить ник
Из: Холон, Израиль
Пользователь №: 548
Спасибо сказали: 2 раз(а)
Много модов перепробывал, но, скажу Вам, такой скорости как в ScarAngel ещё не было. Да и настройки попроще чем в Neo.
Пока доволен. Не нравится только то, что скачиваемые файлы и "рабочие" клиенты обозначены мерзопакостно-зелёным цветом.
Искал, вроде тщательно, где менять этот цвет - не нашел. Цвет фона есть. Цвет букв - тоже есть (установлен чёрный).
А что скачивается в данный момент - всё равно зелёное!Прикрепленный файл  S.A..jpg ( 6,97 килобайт ) Кол-во скачиваний: 102
Gadget
сообщение Oct 17 2007, 13:07
Сообщение #11
Иконка группы
Группа: [Хранители]
Вставить ник
Из: Таллинн
Пользователь №: 4
vadim92
а для этого можешь вытащить файл template.eMule.ini из папки оригинального мула и поместить в папку с твоим модом и заменить на желаемые цвета
vadim92
сообщение Oct 17 2007, 14:44
Сообщение #12
Вставить ник
Из: Холон, Израиль
Пользователь №: 548
[quote name='Gadget' date='Oct 17 2007, 20:07' post='72755']
vadim92
[/quot
Понял. Спасибо.
picasyk
сообщение Nov 28 2007, 16:15
Сообщение #13
Иконка группы
Группа: Модераторы
Вставить ник
Из: Афины
Пользователь №: 37727
Спасибо сказали: 115 раз(а)
Может кто-что посоветует для eMule Plus v1.2b?Пасибо за внимание. worthy.gif
папаВлад
сообщение Nov 28 2007, 16:31
Сообщение #14
Вставить ник
Из: подмосковье
Пользователь №: 32522
Спасибо сказали: 443 раз(а)
просьба создавать отдельные темы для подобных вопросов, здесь обсуждают другой мод.
могу посоветовать вместо твоего устаревшего ослика, наиболее совершенного emule 0.48а, а также любой мод, созданный на его базе.
picasyk
сообщение Nov 29 2007, 12:07
Сообщение #15
Иконка группы
Группа: Модераторы
Вставить ник
Из: Афины
Da GuRu
сообщение Dec 27 2007, 20:17
Сообщение #16
Вставить ник
eMule 0.48a ScarAngel v2.5
eMule v0.48a ScarAngel v2.5:
- 28.12.2007 -
Added: Links for Server list and nodes file [Stulle] - Stulle
Added: High resolution speedmeter on toolbar [eFMod/Stulle] - Myth88
Changed: Do not restrict download if no upload possible [Stulle] - Stulle
Fixed: Resume mode combobox in Categorie dialog [Stulle] - Stulle
Fixed: Auto Update IP2Country on startup [Stulle] - Stulle
Fixed: Do not reserve 1/3 of your uploadlimit (finally!) [Stulle] - Stulle
Fixed: URL input for updates [Stulle] - Stulle
Fixed: Design Settings (backgrounds and windows were broken) [Stulle] - Stulle
Download Mirrors:
eMule-0.48a-ScarAngel-v2.5-bin.rar
eMule-0.48a-ScarAngel-v2.5-src.rar
Gennadij
сообщение Dec 29 2007, 14:35
Сообщение #17
Вставить ник
Из: ЛАТВИЯ, г. РИГА
Пользователь №: 38536
Спасибо сказали: 87 раз(а)
Поставил v2.5. За сутки работы конкретную оценку дать нельзя, но работает стабильно устойчиво, с предельно высокими скоростями, *враги* разбежались-чисто. Считаю, что со временем программа может стать популярной и потребуется свежий и подробный FAQ конкретно для ScarAngel. Всех с Новым Годом!!!
Gennadij
сообщение Mar 9 2008, 07:35
Сообщение #18
Вставить ник
Из: ЛАТВИЯ, г. РИГА
Подскажите пож.:
-как понизить служебный траффик. По сравнению с другими клиентами, он у меня около 7.0 на отдаче и около 5.5 на приёме. Рекомендации, найденные на форуме, не изменяют ситуацию. Может так и должно быть?
- на 5000 очередников на отдаче, 220-250 забаненых. Не много ли это?
А в основном, клиент надежный.
drBatty
сообщение Mar 9 2008, 07:41
Сообщение #19
Группа: Юзвери
Вставить ник
Из: Петербург(Центр)
Пользователь №: 27753
Спасибо сказали: 1249 раз(а)
отключить твои любимые фичи(флажки, идентификацию, и т.д.)
чего именно? и какая у тебя скорость?
позиция страуса - спрятать голову в песок.
Спасибо сказали:
NeByvalyi
сообщение Mar 9 2008, 17:55
Сообщение #20
Иконка группы
Группа: [Хранители]
Вставить ник
Из: Нью-Васюки
Пользователь №: 4079
Спасибо сказали: 1557 раз(а)
Нормально!
Быстрый ответОтветить в данную темуНачать новую тему
1 чел. читают эту тему (гостей: 1, скрытых пользователей: 0)
Пользователей: 0
RSS Текстовая версия Сейчас: 6th September 2010 - 15:56
              IPB Skins Team, стиль Retro
