aMule released
Сообщений в теме: 53
#21 OFFLINE   drBatty
Отправлено 05 Апрель 2009 - 16:51
aMule 2.2.4 released
April 03, 2009, 10:07:09 PM by GonoszTopi
We are happy to announce the release of aMule 2.2.4 - The "we didn't have a .4 version since... well... long ago" version
This release is intended to be the last of the 2.2.x series, however, noone knows what future brings...
Randomly picking some changes in this release:
    * Adapted for newest support libraries, such as crypto++-5.6.0, GeoIP-1.4.6, etc
    * Several improvements in Kademlia routing
    * Fixes of rare, occasional and frequent crashes (just a joke, aMule never crashes  Roll Eyes )
    * ...and many many more...
Please see the Changelog for a list of all changes.
Grab the sources or official packages at the download page or check the forum for user contributed packages.
You can get the sources also via aMule-2.2.4.tar.bz2
http://www.amule.org/
  • Устранены многие утечки памяти
  • Автозапуск в Gnome
  • Исправлена компиляция в gcc-4.3.2
  • Портированы изменения в Kademlia из eMule0.49c
  • Не интерактивные режимы для amulecmd / amuleweb.
  • Ну и множество других изменений и исправлений..
#22 OFFLINE   NKF
    юниксовый муловод
    03 Янв 2018 12:07
Отправлено 24 Сентябрь 2009 - 02:22
с небольшим опозданием, но все же:
aMule 2.2.6 released
Version 2.2.6 - The "we don't have holidays" version.
2009-09-16
Fixed obfuscated server UDP communication.
Fixed cross-endian Kad node verification.
Fixed name conflict in builtin PHP parser.
Fixed configure finding unwanted Crypto++ installations.
Properly update transfers tab's bottom pane's title.
Fixed a bug in detecting and using the fallocate() function.
Now really fixed that security issue.
Fixed HTTP download if server transmits no content-length
Fixed several cases of amulecmd printing zero on big endian machines
Fixed amuleweb crashing on tiny downloads
Added version resources to MSVC binaries
Fixed wrong search text in search dialog after deleting a tab
Fixed download limit in amuled (which was 50% of what was set)...
смотрим полный Changelog
поставил из исходников на фрю - ослик собрался и замечательно пашет...
но вот вопрос - неужели в amule все так плохо со статистикой, в amule.conf имеются только два параметра: Total downloadи upload.
у кого-нить еще какие статистические данные корректно отображаются, например передано данных (отдельно по файлу), количество запросов, коэффициент передачи?
#23 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 17 Апрель 2010 - 08:53
Потребовался ослик для линукса. Установил на виртуальной машине, чтоб научиться пользоваться сначала. Всё заработало, но я сдуру включил в настройках русский язык.. (Если есть, почему бы и не включить?) Теперь пропала сама кнопка "Настройки" -- Ни язык не переключить обратно, ни другими настройками не поиграться.. Защита от дурака? :crazy:
#24 OFFLINE   emulek
    01 Май 2010 00:09
Отправлено 18 Апрель 2010 - 08:40
Просмотр сообщенияvic2 (17th April 2010 - 17:53) писал:
Защита от дурака?
нет там такого. может за край уехало?
или ещё что-то похожее?
можно подробнее? дистрибутив, версия GTK, опции компиляции? версия мула наконец?
#25 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 19 Апрель 2010 - 02:39
А чего Английский вариант не "уехал за край"? Ubuntu 9.10, версия GTK, опции компиляции -- не знаю что это, версия мула 2.2.6, ставил из репозитория.
Может из-за того, что на виртуальной машине стоит, но согласитесь -- странно. Если бы просто чё-то не работало, а тут кнопка пропала.. Есть у меня хард с этой убунтой, ради интереса можно там попробовать. Просто напрягает перезагружаться с винды в линукс и наоборот, вот и поставил на виртуальной машине.
#26 OFFLINE   emulek
    01 Май 2010 00:09
Отправлено 19 Апрель 2010 - 03:29
Просмотр сообщенияvic2 (19th April 2010 - 11:39) писал:
наверное потому, что русские слова длиннее. К сожалению в амуле и хоткеев нет :(
Давай я тебе свой конфиг пошлю?Прикрепленный файл  amule.conf.txt.gz   2,11К   47 Количество загрузок:
Сообщение отредактировал emulek: 19 Апрель 2010 - 03:39
#27 OFFLINE   emulek
    01 Май 2010 00:09
Отправлено 19 Апрель 2010 - 03:46
И это правильно, что из репов: опции компиляции - это грабли, на которые наступаешь, когда сам собираешь ;)
#28 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 19 Апрель 2010 - 04:05
Спасибо, emulek. Конфиг скачал, вот только надо найти, куда его положить.. Я в линуксе слабак. Мне линукс нужен редко, но иногда нужен. А мул для линукса нужен на другом компе, который будет постоянно подключен к интернету. Но этот комп не у меня дома (Не на работе. Всё легально. Просто тот человек не хочет сам заниматься, занятой очень.) и чтоб там не возиться долго, надо дома всё настроить и понять. Ещё хочу настроить удалённое управление. Пока даже не имею представления что это и как делается. Можно ли об этом почитать где-то по-русски?
#29 OFFLINE   drBatty
Отправлено 19 Апрель 2010 - 05:45
Просмотр сообщенияvic2 (19th April 2010 - 13:05) писал:
~/.aMule
Это в твоей домашней папке. Обрати внимание - она скрытая!
э...
http://drbatty.ath.c...opic.php?t=3641
http://drbatty.ath.c...opic.php?t=2240
и вообще там много. в поиске по запросу amule. Здесь это мало кому интересно :(
Впрочем, если хочешь пиши здесь. А удалённое управление делается достаточно просто. Я даже локально использую удалённое управление - у меня мул работает всегда, а вот GUI - только когда надо.
#30 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 19 Апрель 2010 - 06:35
Спасибо, drBatty! Добавил в избранное, почитаю.
#31 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 20 Апрель 2010 - 16:43
Почитал, установил демона, опять-таки из репозитория. Запустил -- работает, качает. Пришлось немного конфиг подправить, но демон при запуске сам сказал чего он хочет для полного счастья.
Теперь вопрос, как им управлять из вынды? Ссылки изучил, понял, что надо amulecmd использовать. Погуглил, но пока не нашел, где скачать. И еще я не понял, amulecmd -- это консольное приложение? А amulegui -- графическое? Где его можно скачать для Windows?
Сообщение отредактировал vic2: 20 Апрель 2010 - 16:43
#32 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 20 Апрель 2010 - 17:08
Протормозил я... Запустил ослика под виндой, Поиском легко нашел aMuleGUI-2.1.3-MSW.zip. Распаковал, запустил. Ввожу IP-адрес, пароль, нажимаю "соединиться" -- окошко закрывается и ничего... Ни знакомой оболочки, ни сообщений об ошибке.. :1584:
Еще один непонятный момент: запускал демона из командной строки, через терминал. Похоже при закрытии терминала демон прекращает работу... А как сделать, чтоб не прекращал?
P.S. Запустил aMuleGUI под Убунтой, т.е. на виртуальной машине. Всё равно не соединяется. Но хотябы выдаёт ошибку -- неправильный пароль. Пароль я ввожу тот, что в конфиге в строке ECPassword.
Попробовал доступиться через WEB-интерейс при запущенном основном муле -- не может браузер найти такую страницу... :999:
P.P.S. Оказывается пароль в конфиг нельзя писать, туда хэш записывается. Запустилась панель управления на локалхосте. А вот из винды -- никак.
Сообщение отредактировал vic2: 20 Апрель 2010 - 18:32
#33 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 20 Апрель 2010 - 21:25
Ура! Заработало. :1584:  Надо было последнюю версию ставить. А она оказывается входит в aMule-2.2.6-installer. Вот её и надо было искать. Потом при установке просто отказываемся савить собственно мула, а выбираем только GUI для удалённого управления. Ну, теперь можно и на реальном компе попробовать ослика запустить.
Сообщение отредактировал vic2: 20 Апрель 2010 - 21:54
#34 OFFLINE   drBatty
Отправлено 20 Апрель 2010 - 23:27
Просмотр сообщенияvic2 (21st April 2010 - 06:25) писал:
э... можно было и не отказываться. в состав амула входят 4 приложения:
  • amule. сам амул. прямо как в Windows emule
  • amuled - демон. тот-же мул, но без GUI. может управляться только удалённо, другим приложением. Кстати, для запуска можно использовать amuled -f.
  • amulegui с виду - простой амул, но на самом деле, это не мул, а только окошки от него. Служат для управления №1 или №2.
  • amulecmd тоже самое, что и №3, только работает в командной строке. Служит для автоматизации работы. Например можно написать скрипт, которые каждые 100 минут ищет "нужный_файл", и ставит найденное на закачку. Или ещё что-то такое.
Естественно, при установке можно выбрать любую комбинацию. Обычно на сервере с мулом ставят №2 (и возможно №4), а на той машине, с которой происходит управление, только №3.
важное примечание: В Linux Mandriva и других пакетных дистрибутивах aMule разделён на несколько пакетов - можно устанавливать не все, а лишь некоторые из них. Если у вас Slackware или ещё более кондовый дистр, то мула придётся собирать самому, используя опции компиляции (параметры скрипта ./configure).
Сообщение отредактировал drBatty: 21 Апрель 2010 - 01:16
#35 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 21 Апрель 2010 - 02:42
drBatty, я уточню, какая задача у меня была: собственно мул стоит на машине под Линуксом, которая постоянно подключена к интернету. Управление мулом осуществляется удалённо с компа, на котором Виндовс -- основная операционка. Потому мне ставить мула или демона из инсталятора не нужно было, но может кому и понадобится для решения своих задач.
Сейчас "удалённая" часть прекрасно работает на виртуальной машине, а управляется из-под Виндовс, основной операционки.
Но остались нерешенными некоторые мелочи.
1. Как запустить демона, чтобы он не отваливался при закрытии терминала? Возможно мой товарищ, которому принадлежит комп под Линуксом, сам знает, как это делается. Скорее всего знает. Но мне бы тоже не помешало.
2. В настройках я вижу файловую систему своего компьютера, хотя подключен к другому. Т.е. я не могу переназначать папки (могу, но они же всё равно будут недоступными. Кто знает, к чему это приведёт?). Это просто баг в текущей версии или я чегото не понял?
#36 OFFLINE   drBatty
Отправлено 21 Апрель 2010 - 03:22
Просмотр сообщенияvic2 (21st April 2010 - 11:42) писал:
ага. достаточно поставить только amulegui.
А на другой машине, именно его можно НЕ ставить, а установить только демон (кстати, для демона намного меньше зависимостей, к примеру ему не нужна GeoIP, флажков всё равно не будет. А вот для GUI это нужно, впрочем, в виндовс версии эта библиотека жёстко вкомпилена и не выковыривается)
у меня 2 раза в час исполняется этот скрипт:
Раскрывающийся текст
Который, при необходимости, вызывает этот:
конечно можно просто написать где-нить в rc.local что-то вроде
sudo -u ВАСЯ /usr/local/bin/amuled -f
но это не слишком удобно. За то - просто.
Да. Баг. удалённое GUI пока ещё не обеспечивает полное управление каталогами. её настройки просто игнорируются (хотя лучше не пробовать - возможны разные глюки). Для управления каталогами приходится использовать следующие методы:
1) запустить на удалённой машине обычный амул (не забыв вырубить предварительно демона).
2) вырубить демона, и исправить конфиг.
Кроме того, удалённое GUI пока ещё не позволяет просматривать источники :(
#37 OFFLINE   vic2
    22 Июн 2013 00:02
Отправлено 21 Апрель 2010 - 11:10
Да, я заметил, немного разочаровывает, но в принципе можно смириться.
А демона я запустил по-другому:
sudo /etc/init.d/amule-daemon start
При этом пришлось указать в файле /etc/default/amule-daemon в строке AMULED_USER="UserName", где UserName -- имя пользователя, разумеется.
После этого демон даже автоматически стартует после перезагрузки системы (что меня удивило).
Осталось всего ничего -- повторить все эти операции на другом компе.
#38 OFFLINE   drBatty
Отправлено 21 Апрель 2010 - 11:23
Просмотр сообщенияvic2 (21st April 2010 - 20:10) писал:
да. это более правильный метод. но только для убунты/дебиана.
не думаю, что будут проблемы.
единственное - амул иногда падает.
#39 OFFLINE   NKF
    юниксовый муловод
    03 Янв 2018 12:07
Отправлено 05 Апрель 2011 - 04:38
Вот так тихо и совсем неторопливо появился aMule 2.3.1 RC1
#40 OFFLINE   Al71
    Сегодня, 00:43
Отправлено 03 Декабрь 2011 - 12:46
The "unobvious evil date" version:                           aMule 2.3.1 released
2011-11-11
По ссылке можно скачать готовые пакеты для Windows и MacOSX. На других платформах пока придется собирать из исходников самостоятельно.
Список изменений на сей раз довольно внушительный: Changelog
На убунте все установилось нормально. Немного непривычно выглядит окно на отдачу, которое отделили от загрузок и перенесли в раздел публикуемых файлов, а так новый мул работает пока без проблем.
