BitComet - Bit Torrent - eMule-Rus.Net Форум муловодов
BitComet
Сообщений в теме: 16
#1 OFFLINE   Gadget
Отправлено 21 Март 2007 - 03:42
Вышла новая версия программы BitComet. Клиент для Peer 2 Peer сети BitTorrent. Обладает куда более удобным интерфейсом, чем стандартный BitTorrent, имеет ряд полезных настроек, мощный поиск по средствам нескольких крупных порталов, статистику и прочие удобства.
Сайт разработчика http://www.bitcomet.com
Полный хелп по Bitcomet (eng)
Хелп по BitComet (рус)
BitComet 0.85
GUI Improved: new option in torrent maker dialog to enable large file(>1MB) align to piece boundary
GUI Improved: new option in torrent maker dialog to allow user search for HTTP/FTP resources when BT downloading
GUI Improved: new option in BT task properties dialog to enable search for HTTP/FTP resources for BT task files
GUI Improved: new history task filter in fav list, in which tasks displayed in the order of download finish date
GUI Improved: improve task delete dialog, able to remove downloaded files while keep task record in recycle bin
GUI Improved: new option in preferences dialog to enable BT task access P2PCache server (need ISP support)
GUI Improved: task created date and finish date are displayed in task summary
GUI Improved: improve task piece graph, support page down using mouse wheel
GUI Improved: new recomment side-bar which can be toggled in view menu
GUI Improved: BitComet main window minimize to windows taskbar, and system tray icon always displays
GUI Improved: if the task name/publisher name in task list is too long to display, it will be displayed in tooltip
GUI Improved: new search toolbar in the top of BitComet passport view
GUI Improved: improve the clipboard monitor, only capture url links of specific files type
GUI Improved: add support for Maxthon browser
GUI Improved: unhide the option of browse url in BitComet
GUI Improved: downloaded file will be selected when open task save folder
GUI Bugfix: fix the bug that some HTTP download fail due to missing cookie info
GUI Bugfix: fix the bug that hash check of multi BT tasks not running in queue
GUI Bugfix: fix the bug that move to other location command in task context menu does not work
GUI Bugfix: fix the bug that some particular language can not be input to IE edit control when BHO loaded
Core Improved: add P2SP download function to BT task, able to search for HTTP/FTP resources to accelerate download
Core Improved: add large file(>1MB) align to piece boundary function to torrent maker and BT download module
Core Bugfix: fix the bug that may lead to crash when download HTTP task using P2P connection
Core Bugfix: fix the bug that may lead to crash when an error UDP packet received
Core Bugfix: fix the bug that downloaded file may save fail if unsupported characte in current code-page occurred in torrent file
Core Bugfix: fix the bug about GZIP decode in HTTP 1.0
Core Bugfix: fix the bug that the task created from BCTP link is not properly saved if torrent had not downloaded.
Core Bugfix: fix the bug that unable to connect to some FTP server
скачать
#2 OFFLINE   Gadget
Отправлено 07 Июнь 2007 - 00:03
новая версия 0.89
скачать
#3 OFFLINE   Gadget
Отправлено 18 Июль 2007 - 18:12
BitComet 0.90
список изменений:
GUI Improved: add search for eDonkey download source option in BT task properties dialog
GUI Improved: add ED download plugin configuration page in perferences dialog
GUI Improved: display download rate from HTTP/FTP sources and ED sources in BT task summary pane
GUI Improved: shotsnap info for each item in task list and torrent share list changed to a clickable icon
GUI Improved: tasks remain selected after sort task list
GUI Improved: new context menu for my shared torrent and peer shared torrent in fav list
GUI Improved: decrease CPU usage for shared torrent list refresh
GUI Improved: new search icon for each item in shared torrent list
GUI Improved: prompt infomation will be displayed when shared torrent list is empty
GUI Improved: add "copy BC link" to context menu of shared torrent list, with hotkey Ctrl+C
GUI Improved: add "clear all" to context menu of peer shared torrent list
GUI Improved: new option in View menu to show search box in toolbar
GUI Improved: shutdown computer after download finish works for HTTP task now
GUI Improved: text in info bar and status bar of review window change to multi-language string
GUI Improved: the last task will be selected when BitComet startup
GUI Improved: minimize to system tray by close button or minimize button can be configured in preferences dialog
GUI Improved: a prompt window will popup if BitComet detected that the TCP half-open limit of windows is too small at startup
GUI Improved: new state of "detecting" for WAN/LAN ip detector in status bar
GUI Improved: HTTP task connection list move to the up of task log
GUI Improved: the auto-start order for queued task keeps the same to display order of sorted task list
GUI Bugfix: preview window fail to refresh when swtich UI language
GUI Bugfix: "pause all active task" in context menu of floating window does not work
GUI Bugfix: program exit confirm when task running do not count up uploading tasks
GUI Bugfix: unable to click task comment, snapshot and voting for items of 10001th and below in shared torrent list
GUI Bugfix: redownload HTTP task will lose task list sort order
Core Improved: BT task support downloading from eDonkey network (ED plugin for BitComet is required)
Core Improved: BT task support uploading to eDonkey network
Core Improved: add eDonkey network listen port to Windows Firewall and UPNP NAT device when program startup
Core Improved: disable NAT Traversal via UDP automatically for WAN IP user, to improve TCP transfer efficiency
Core Bugfix: auto stop running BT task using a invalid condition dismatch to user settings
Core Bugfix: program will lose respond for a while to flush disk cache when downloading huge HTTP/FTP file under Win2003 64bit
ссылка
#4 Гость_GlaDooo_*
Отправлено 19 Июль 2007 - 23:54
BitComet 0.91
GUI Improved: double click un-downloaded torrent file in my shared torrent list to start download it
GUI Improved: restore option: add .bc! file extension to unfinished file
GUI Improved: new function in context menu of BT task file list: search ED2K link for selected file
GUI Improved: add real-time sort to task list. enable it from View menu
GUI Improved: new operation in context menu of peer shared torrent list: "add to my share list"
GUI Improved: new status icon for BT task downloading torrent file in task list
GUI Improved: add torrent publish date info to torrent share list
GUI Improved: right click torrent share list header to choose displayed column
GUI Improved: a notifier window will display after add a BC link task
GUI Improved: add file category combo list to torrent share list toolbar
GUI Improved: support multi key words in peer shared torrent list filter, separated by sapce
GUI Improved: torrent file name in torrent share list will be displayed in infotip when mouse hover on it if too long
GUI Improved: specify ED2K link from context menu in file list of BT task, to help ED plugin search ED download resource
GUI Improved: when double click .bc! file, prompt to open the unfinished file using the program associated with the original file without .bc! suffix
GUI Improved: right click toolbar of main window to choose displayed buttons, or using View/Toolbar/Buttons menu
GUI Improved: enable auto adjust column width from View/Tasklist menu
GUI Improved: when HTTP/FTP task connection failed, detail error and retry info will be displayed in connection log
GUI Improved: add HTTP/FTP task error retry interval time option in perferences dialog
GUI Improved: restore allocate disk space before downloading option in perferences dialog
GUI Improved: display upload rate and left time in task list by default
GUI Improved: when available space of save location in BT task properties dialog is not enough, the available space size is displayed in red color
GUI Improved: add copy IP address to context menu of status bar in main window
GUI Improved: display task size, progress and preview button in history task list by default
GUI Bugfix: the order of tasks in queue does not match the order in tasklist when start all task from context menu of floating window
GUI Bugfix: the task number in fav list does not refresh when move task to a new category using context menu of tasklist
GUI Bugfix: the wildcard "(*)" does not work in add HTTP/FTP download group dialog
GUI Bugfix: the HTTP/FTP task in queue failed to stop when double click it in tasklist
GUI Bugfix: the wildcard "(*)" does not work in add HTTP/FTP download group dialog for FTP links
GUI Bugfix: when click cancel button of BT task properties dialog after torrent file downloaded from BC link, the BT task will not be removed
GUI Bugfix: unable to handle non-english character in publisher URL of BT task
Core Improved: support persistent seeding to seed finished torrents in background automatically without starting the task
Core Improved: support uploading rate limit for all persistent seeding, tweak in perferences dialog
Core Improved: support customize file download order for BT task, in BT task properties dialog
Core Improved: support patch TCP half-open limit in Windows Vista
Core Bugfix: program will lose respond for a while to flush disk cache when high-speed downloading HTTP/FTP file from LAN
Core Bugfix: ED plugin will upload invalid data in some situation
Core Bugfix: scheduler failed to resume download after stop tasks for 2 hour or longer
Core Bugfix: unfinished tasks will not auto-start at program startup if BitComet is not closed normally
| http |
#5 Гость_GlaDooo_*
Отправлено 14 Сентябрь 2007 - 22:07
BitComet 0.93
Core Improved: improve the stability of persistent seeding
| download.com |
#6 OFFLINE   RoadTrain
Отправлено 19 Июнь 2008 - 13:36
BitComet 1.02
BitComet v1.02 2008.6.3 Release Notes
    GUI Improved: task category will display "empty" when not set
    GUI Improved: whether to search for mirrors when add new HTTP task can be set as default setting
    GUI Improved: new option for preview window: keep aspect ratio of video
    GUI Improved: new switch button in toolbar of preview window: skip undownloaded range or waiting for buffering
    GUI Improved: BitComet resource browser (CometBrowser.exe) will exit immediately after close all its window
    GUI Improved: removw server mode option in advanced netword settings
    GUI Bugfix: user name and password in HTTP/FTP task properties dialog do not take effect
    Core Improved: Long-Time Seeding can download file boundary data for BT task, where one piece containing multi files
    Core Improved: when select part files of a BT task to download, the file boundary data......
eMule Plugin for BitComet
#7 Гость_GlaDooo_*
Отправлено 07 Август 2008 - 17:02
BitComet 1.03
| ed2k |
#8 OFFLINE   RoadTrain
Отправлено 23 Сентябрь 2008 - 05:06
BitComet 1.04
GUI Improved: "my shared torrent list" turns into "torrent archive". all downloaded torrent files will be saved there.
GUI Improved: add filter edit box to torrent archive list.
GUI Improved: remove deleted task list. when delete BT task, its torrent file can be kept in torrent archive
GUI Improved: new option: clear peer sharing torrent list when program exits. enabled by default.
GUI Improved: new option: standby, hibernate, restart or shutdown computer when all task downloaded and stopped
GUI Improved: new command in Tools menu: check for BitComet updates
GUI Improved: improve Long-Time Seeding download rate display in peer list
GUI Improved: displays play button in task list after download audio file, like mp3, wma
GUI Bugfix: open file from file list will fail, after rename BT task and restart BitComet
GUI Bugfix: when make torrent file in v1.03, files in sub-directories will not be added into torrent
GUI Bugfix: when main window is not wide enough, the search box in toolbar will display in invalid position
GUI Bugfix: total downloaded/uploaded bytes in statistics list will be clear in some situation since v1.02
Core Improved: all opened torrent files will be saved to archive folder
eMule plugin
#9 OFFLINE   RoadTrain
    24 мар 2009 04:49
Отправлено 17 Декабрь 2008 - 21:42
BitComet 1.07
eMule plugin
v1.07 2008.12.03
GUI Improved: add tags to task by context menu (support multi-selection)
GUI Improved: filter tasks by tag from favorites list
GUI Improved: new option in task setting panel of option dialog: add tag to new task by download file type
GUI Improved: display task tags and public date for BT task in summary pane
GUI Improved: display task tags for HTTP task in summary pane
GUI Improved: add "Apply" button to option dialog
GUI Improved: new option in Web Interface setting panel of option dialog: display prompt window for web interface operation
GUI Improved: show prompt window when open a torrent file that already existed in torrent archive list
GUI Improved: when modify the save path of an existed BT/HTTP task, show a prompt to choose whether to move downloaded files to new save path
GUI Improved: when modify BT/HTTP task save path, show the path auto-complete drop list
GUI Improved: when the width of file list in BT task properties dialog is not enough for file name, try to display the head and tail part of the filename, with the middle part as ellipsis
GUI Improved: when switch task lists, task tags or torrent share list from favorites list, remember the scroll bar position and task selections before switch
GUI Improved: add context menu to BitComet passport and DHT area in main status bar
GUI Improved: when click comment or snapshot icon in task list, display them below task list, instead of open a browser window
GUI Improved: add support for 10 new languages
GUI Bugfix: program crash when display task delete confirm dialog under Win98/2K
Core Improved: Web Interface support create new task from BC link
Core Improved: When create a task that already existed, Web Interface will displays an webpage link to the existed task
Core Improved: eMule plugin can download file boundary data for BT task, where one piece containing multi files
Core Improved: create bak file when save task list to downloads.xml
Core Bugfix: error data received in file boundary piece makes task download can not finish
Сообщение отредактировал RoadTrain: 17 Декабрь 2008 - 21:42
#10 OFFLINE   DCfan
Отправлено 25 Май 2016 - 19:18
BitComet  v1.41 2016.05.25
GUI Improved: display Batch Download window when open multiple torrent files in File Explorer
GUI Improved: merge 32bit/64bit editions into one install package
Core Improve: increase default disk cache limit from 50 MB to half of total momory, up to 1GB
Core Improve: add peer software version recognization
С установкой http://download.bitc..._1.41_setup.exe
Без установки http://download.bitc...tComet_1.41.zip
#11 OFFLINE   DCfan
    24 мар 2009 04:49
Отправлено 05 Июль 2016 - 20:28
BitComet  v1.42 2016.07.04
GUI Improved: improve support for high-DPI monitor
Ссылки на скачивание:
С установкой http://download.bitc..._1.42_setup.exe
Без установки http://download.bitc...tComet_1.42.zip
#12 OFFLINE   DCfan
    24 мар 2009 04:49
Отправлено 16 Июнь 2018 - 16:41
BitComet v1.51 2018.6.12
GUI Improved: new settings in Tracker page of option window, automatically add trackers when start BitTorrent download
GUI Improved: new settings in Tracker page of option window, automatically update trackers list every day
GUI Improved: increase max value for global rate limit, task rate limit and scheduler rate limit from 9999kB/s to 100MB/s
GUI Bugfix: unsupport download torrent file from HTTPS link
GUI Bugfix: remove P2PCache function from Advanced page of Option window, which was out-of-service for a long time
Core Improve: improve download speed stability of BitTorrent downloading
Core Improve: increase max download speed of single connection of BitTorrent downloading
Core Improve: refine Crash Report program
Core Bugfix: fix problems when exit program while high-speed downloading
С установкой https://download.bit..._1.51_setup.exe
Без установки https://download.bit...tComet_1.51.zip
#13 OFFLINE   Ruslan432f
    14 мар 2024 04:13
Отправлено 09 Январь 2021 - 12:11
Щяс BiglyBT вышел с открытым исходным кодом , чатом и поиском в сети dht с поддержкой  BitTorrent v2
#14 OFFLINE   NeByvalyi
    14 мар 2024 04:13
Отправлено 09 Январь 2021 - 15:49
Просмотр сообщенияRuslan432f сказал:
BiglyBT
Что за зверь?
Если что-то достойное - отрывайте новую тему и рассказывайте! Подробно
#15 OFFLINE   Ruslan432f
    14 мар 2024 04:13
Отправлено 09 Январь 2021 - 17:04
Просмотр сообщенияNeByvalyi (09 Январь 2021 - 15:49) писал:
BiglyBT
Что за зверь?
Штука очень достойная, там поиск получше чем в эмуле, тему открыть не могу - недостаточно прав на форуме - я новичок, был бы рад, если бы кто то из вас открыт тему за меня
#16 OFFLINE   Ramerup
    30 мар 2023 12:59
Отправлено 09 Январь 2021 - 17:31
Ruslan432f, держи:
http://forum.emule-r...showtopic=60885
#17 OFFLINE   Ruslan432f
    Сегодня, 22:52
Отправлено 09 Январь 2021 - 17:46
Просмотр сообщенияRamerup (09 Январь 2021 - 17:31) писал:
Спасибо
