Исполнитель: Yello
Издание: 1980, Mercury 818 339-2
Жанр: Electronic
Тип рипа: image+cue+eac.log+covers
Формат: WAVPack (.wv)
Битрейт: lossless
Контейнер: ISO
Продолжительность: 41:03
Размер файла: 218.54 MB
Скрытый текстКомпозиции
01. Bimbo - 3:39
02. Night Flanger - 4:55
03. Reverse Lion - 1:21
04. Downtown Samba - 2:39
05. Magneto - 2:48
06. Massage - 1:28
07. Assistant's Cry - 1:49
08. Bostich - 2:15
09. Rock Stop - 2:33
10. Coast To Polka - 1:57
11. Blue Green - 5:28
12. Eternal Legs - 4:09
13. Stanztrigger - 2:57
14. Bananas To The Beat - 3:06
05. Magneto - 2:48
06. Massage - 1:28
08. Bostich - 2:15
Скрыть
Скрытый текстLog EAC
EAC extraction logfile from 19. November 2013, 15:49
Yello / Solid Pleasure
Used drive : PLEXTOR DVDR PX-810SA Adapter: 2 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 48
Used interface : Installed external ASPI interface
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -V -T "Date=%year%" -T "Genre=%genre%" -T "COMMENT=ripped by bvstudio®" %source%
TOC of the extracted CD
1 | 0:00.33 | 3:39.25 | 33 | 16482
2 | 3:39.58 | 4:55.02 | 16483 | 38609
3 | 8:34.60 | 1:21.30 | 38610 | 44714
4 | 9:56.15 | 2:38.40 | 44715 | 56604
5 | 12:34.55 | 2:47.55 | 56605 | 69184
6 | 15:22.35 | 1:27.43 | 69185 | 75752
7 | 16:50.03 | 1:49.12 | 75753 | 83939
8 | 18:39.15 | 2:14.40 | 83940 | 94029
9 | 20:53.55 | 2:33.20 | 94030 | 105524
10 | 23:27.00 | 1:57.08 | 105525 | 114307
11 | 25:24.08 | 5:28.05 | 114308 | 138912
12 | 30:52.13 | 4:08.42 | 138913 | 157554
13 | 35:00.55 | 2:56.63 | 157555 | 170817
14 | 37:57.43 | 3:05.60 | 170818 | 184752
Range status and errors
Selected range
Filename F:\Yello\1980 - Solid Pleasure (1985 - Mercury. USA - 818 339-2)\Yello - Solid Pleasure.wav
Peak level 92.2 %
Extraction speed 6.6 X
Range quality 100.0 %
Test CRC 9DF3FA59
Copy CRC 9DF3FA59
Copy OK
No errors occurred
AccurateRip summary
Track 1 accurately ripped (confidence 4) [9AE19855] (AR v2)
Track 2 accurately ripped (confidence 4) [6C4DC235] (AR v2)
Track 3 accurately ripped (confidence 4) [9D158947] (AR v2)
Track 4 accurately ripped (confidence 4) [85F8B04F] (AR v2)
Track 5 accurately ripped (confidence 4) [89B6D8C3] (AR v2)
Track 6 accurately ripped (confidence 4) [1E699D82] (AR v2)
Track 7 accurately ripped (confidence 4) [C10B0D7A] (AR v2)
Track 8 accurately ripped (confidence 4) [AA0910CD] (AR v2)
Track 9 accurately ripped (confidence 4) [7C0080A1] (AR v2)
Track 10 accurately ripped (confidence 4) [D66C28EA] (AR v2)
Track 11 accurately ripped (confidence 4) [883A7BF7] (AR v2)
Track 12 accurately ripped (confidence 4) [BC445F7C] (AR v2)
Track 13 accurately ripped (confidence 4) [034FD0CF] (AR v2)
Track 14 accurately ripped (confidence 4) [6E7BA05B] (AR v2)
All tracks accurately ripped
End of status report
---- CUETools DB Plugin V2.1.5
[CTDB TOCID: Yyi4AeDmFct9VyuMoZcMYyztJEg-] found
Submit result: Yyi4AeDmFct9VyuMoZcMYyztJEg- has been confirmed
Track | CTDB Status
1 | ( 7/13) Accurately ripped
2 | ( 7/13) Accurately ripped
3 | ( 7/13) Accurately ripped
4 | ( 7/13) Accurately ripped
5 | ( 7/13) Accurately ripped
6 | ( 7/13) Accurately ripped
7 | ( 7/13) Accurately ripped
8 | ( 7/13) Accurately ripped
9 | ( 7/13) Accurately ripped
10 | ( 7/13) Accurately ripped
11 | ( 7/13) Accurately ripped
12 | ( 7/13) Accurately ripped
13 | ( 7/13) Accurately ripped
14 | ( 7/13) Accurately ripped
==== Log checksum B9A7AF6515AC2AB3F9435403036FCD0A4601FE1C6C1C02BE3BA612377883815A ====
Read mode : Secure
Quality : High
Add ID3 tag : No
Selected range
Peak level 92.2 %
Test CRC 9DF3FA59
Copy CRC 9DF3FA59
Copy OK
No errors occurred
AccurateRip summary
Track | CTDB Status
Скрыть
Спасибо оригинальному релизеру!
Yello - Solid Pleasure (non remaster)
Этим диском начинаю серию неремастеров Yello.
Я вообще небольшой любитель электронной музыки, но эта команда меня зацепила, да так, что выискал в сети и собрал играбельные имиджи альбомов.
