eMule beba MoD - Моды мула - eMule-Rus.Net Форум муловодов
eMule beba MoD
Сообщений в теме: 9
#1 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 02 Июнь 2007 - 15:04
eMule 0.48a beba v1.4
Tuxman's eMule beba
- CHANGELOG -
v1.4 [the bullet-proof edition]:
Welcome to eMule 0.48a!
Note that the SLS system has been changed, so all currently saved sources will be lost!
* June 02 2007
- merged: eMule 0.48a
- added: LowID to HighID auto callback (L2HAC) [Xanatos]
  * without a prefs option; why should anyone want to disable it?
- added: searchCatch [SLUGFILLER]
- improved: added checkbox to switch logging of Kad security events [Tuxman]
- improved: added some #pragma stuff to avoid obsolete 4702 warnings [Tuxman]
- improved: inform sources of the new ID after a reconnect [Xanatos/Spike2]
- improved: optimization for large shared file list [leuk_he]
- improved: optimizations for socket SendTo functions [BlueSonicBoy]
- fix: client/queue list bug [Xman]
- fix: fix for corrupt PreferencesKad.dat [NetFinity]
- fix: Infinite Queue [SLUGFILLER]
- fix: small fix in SharedDirsTreeCtrl.cpp [Tuxman]
- fix: some things found while compiling in debug mode [Tuxman, thx to JvA]
- changed: default "max. connections" value increased to 15000 [Tuxman]
- changed: readded old MiniMule prefs icon [Tuxman]
- changed: spreadReask [SLUGFILLER]
- changed: updated emulations to newest client versions [Spike2, Tuxman]
  * released in the beba Easter Edition mod before (no longer available!)
- removed: fix for startupload [Xman]
- updated: Dynamic Block Request to newest Spike2 codebase [NetFinity]
- updated: Slot Control to newest X-Ray CVS codebase [JvA]
- updated: SLS to newest X-Ray CVS codebase [Spike2]
Download Mirrors:
eMule-0.48a-beba-1.4-bin.rar
eMule-0.48a-beba-1.4-src.rar
Download more versions of eMule beba.MoD
Features & Changelogs for eMule beba.MoD
Rate eMule beba.MoD @ emule-mods.de !!!
eMule Tools: Server.met - Server-List - IPFilter - Skins
#2 OFFLINE   Gadget
Отправлено 03 Июнь 2007 - 14:16
thanks Da GuRu
#3 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 26 Июнь 2007 - 21:21
eMule 0.48a beba v1.41
Tuxman's eMule beba
- CHANGELOG -
_______________________________________________________
v1.41 [the beta edition]:
Outside the weather goes crazy, so do I: here's a new beba version.
No new features nor important bugfixes, though; if 1.4 runs fine for you, you don't need this version. Nevertheless some of you noticed that beba's new upload slot system doesn't work as great as the old one, so I merged it back. Have fun. :)
* June 24 2007
- improved: added guide how to determine your connection speed [Tuxman]
- improved: changed default nick to beba's website [Tuxman]
- fix: Kademlia prefs directory under Vista [godlaugh2007]
- fix: merged Slot Control back to beba's old 1.3 base [Tuxman]
  * SHOULD fix all slot glitches; please let me know if it works better for you.
- changed: added readme/ directory for changelogs and the new readme file [Tuxman]
- changed: the Slot Control value is only used if Slot Focus is disabled [Tuxman]
Download Mirrors:
eMule-0.48a-beba-1.41-bin.rar
eMule-0.48a-beba-1.41-src.rar
eMule : Server.met - Server-List - IPFilter - Skins
#4 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 24 Август 2007 - 16:28
eMule 0.48a beba v1.5
v1.5:
- added: SUQWT [Moonlight/CB/Tuxman]
- improved: beba now prevents that "application busy" popup on Windows startup [leuk_he]
- improved: gather no further search results when the search has been stopped [bengarchy]
- improved: some Slot Focus improvements [Tuxman]
  * should additionally fix incompatibilities with the Slot Control
- fix (o): accurate compression percentage indication "fix" [BlueSonicBoy]
- fix (o): crash when hashing during eMule shutdown [Xman]
- fix (o): division by zero fix in TaskbarNotifier.cpp [Xman]
- fix (o): missing reaction to OP_REQUESTFILENAME [WiZaRd]
- fix (o): possible exception in CClientReqSocket::PacketReceived [fafner]
- fix (b): removed useless code in the beba prefs [Tuxman]
- fix (b): Slot Focus couldn't be switched when there was no uploading process [Tuxman/JvA]
- fix (b): small merging bug in TransferWnd.cpp [Tuxman]
- changed: added beba's website URL to the About logo, removed board URL :) [Tuxman]
- changed: various small SLS improvements [taken from the X-Ray and Xtreme mods]
- removed: Vista fix - not needed anymore [leuk_he/Xman]
Download Mirrors:
eMule-0.48a-beba-1.5-bin.rar
eMule-0.48a-beba-1.5-src.rar
eMule: Server.met - Server-List - IPFilter - Skins - eMule Wiki
#5 OFFLINE   DCfan
    14 мар 2024 04:13
Отправлено 23 Март 2013 - 22:02
eMule 0.50a beba 2.70 March 23, 2013
v2.70 [the bing edition]
** released March 23 2013
- added: additional fake check from the search list [WiZaRd/NetFinity]
- added: NeoLoader detection [David Xanatos]
- improved: added recognition of Ogg Theora (.ogv) and TAK (.tak) media files [Tuxman]
- improved: added recognition of some WordPerfect Office document files [Tuxman]
- improved: fixed unfair treatment of clients requesting more than 1 file [eklmn/WiZaRd]
- improved: improved Visual Studio 2010 compatibility [Tuxman/WiZaRd]
- improved: prevent failed UL sessions due to deleted/missing shared files [WiZaRd]
- improved: removed some debug-related functions in release builds [YumeYao]
- fix (o): a double click on the USS status bar item opened the messages window instead of the Tweaks prefs page [Eulero]
- changed: finally fixed the URL in the logo image and did some decent redesign [Tuxman]
- changed: improved the Slot Focus upload list context menu item (clearer display of "enabled"/"disabled") [Tuxman]
- changed: randomly changed something and stuff [Tuxman]
- changed: removed the Slot Focus prefs item (redundant) [Tuxman]
- changed: removed the option to disable Windows 7+ taskbar integration [Tuxman]
- changed: Winsock2 support can not be disabled anymore (removed checkbox) [Tuxman]
* fallback to Winsock1 has been the default behavior anyway
- removed: support for low color desktops [WiZaRd]
* people using VS2010-binary compatible systems should not have them anymore. :-)
- updated: Crypto++ v5.6.2 [Tuxman]
- updated: libpng v1.6.0 [Tuxman/WiZaRd]
- updated: miniupnplib v1.8 [Tuxman]
* including fallback mode for Windows XP [WiZaRd]
eD2K ссылки:
Файлы:
ed2k://|file|beba%202.70%20bin.7z|2545419|FF8C034905D38650270B86395428FCA2|h=6QTJ4HJ6ZBFXLDFNHMTSP35FKEFQ5Q7C|/
Исходный код:
ed2k://|file|beba%202.70%20src.7z|2006755|73DF7172C10CFCC71BE7BEBECCC9A841|h=Z6Q6NWYSDAIUBTYLTTYYVHPXOB52L6A3|/
Источики: http://beba.emulefut...?page=changelog
http://forum.emule-p...opic=84237&st=0
Сообщение отредактировал DCfan: 23 Март 2013 - 22:02
#6 OFFLINE   Gordyj
    06 янв 2024 21:01
Отправлено 24 Март 2013 - 00:20
О, мой любимый MOD обновился!!! :yahoo:
Сообщение отредактировал Gordyj: 24 Март 2013 - 00:21
#7 OFFLINE   DCfan
    14 мар 2024 04:13
Отправлено 07 Июнь 2013 - 22:23
eMule 0.50a beba 2.71 04 июня 2013
v2.71 [the beef edition]
Obviously, v2.70 had no major issues left. Time for another small maintenance release with some neat improvements. Thanks to my favorite eMule-Mods.it members for taking their time to test.
* June 4, 2013
- improved: added recognition of some more file types [Tuxman]
- improved: enhanced eD2k filters in Shared Files; applied by folder, listed as subfolders [Tuxman/WiZaRd]
- fix (o): preventing OP_HASHSETREQUEST by invalid clients [Enig123]
- changed: tiny code changes to reduce C4244 warnings [Tuxman]
eD2K ссылки:
Файлы:
ed2k://|file|beba%202.71%20bin.7z|2547633|58645A0E8795B6FB9F57DA71FFB3263B|h=DIIBDSYAQNRDZBEN3M3F6WMNVNTUSWIV|/
Исходный код:
ed2k://|file|beba%202.71%20src.7z|2005659|B2D75C24B7D206CF2370E6A2F2F7829C|h=EVIH4NAKQUEFYF2YUKU2WRSDBO4MMY5I|/
Источник: http://beba.emulefut....php?page=index
#8 OFFLINE   DCfan
    14 мар 2024 04:13
Отправлено 09 Июль 2013 - 00:42
eMule 0.50a Beba 2.72 04 июля 2014
- added: added the eMule Content Database as a search source [Tuxman]
  * this replaced the now-defunct FileDonkey method
- improved: added recognition of Android applications (.apk) [Tuxman]
- improved: improved beba's manual version checking quite a bit [Tuxman]
- improved: improved some code (no, really) [Tuxman]
- improved: merged a few general code improvements from NetF WARP mod [NetFinity]
- improved: merged a few Kad code improvements and fixes from kMule mod [WiZaRd]
- fix (b): fixed a fix from beba v2.70 [Tuxman]
- fix (b): fixed score calculation with the Analyzer CS [Tuxman]
  * probably broken since beba v1.0; well then.
- updated: updated to libpng 1.6.2 [Tuxman]
eD2K ссылки:
Файлы:
ed2k://|file|beba%202.72%20bin.7z|2402674|45C542DC3A506DA5BC09D3028665BE52|h=CLJ6ZXJXSYWFWZW2K3RRGLPFWQDCTINP|/
Исходный код:
ed2k://|file|beba%202.72%20src.7z|2007465|CBDAE6C278B4B03E7B8BEDCC7A033EED|h=D4YEN3R5EQ7HQGJBHFWQQXLH44ZCQM7T|/
Сообщение отредактировал DCfan: 09 Июль 2013 - 00:42
#9 OFFLINE   Gordyj
    06 янв 2024 21:01
Отправлено 09 Июль 2013 - 21:57
отличная новость!
#10 OFFLINE   DCfan
    14 мар 2024 04:13
Отправлено 31 Январь 2021 - 09:36
Нашёл ссылки на форуме мода на предварительную сборку eMule v0.50b | beba v3.00 от 10.02.2016
_http://tuxproject.de/nightlybin.7z
_http://tuxproject.de/nightlysrc.7z
Tuxman's eMule beba
- CHANGELOG -
v3.00 [noitide sdrawkcab eht]
This should have been v2.80; however, a new eMule is in town, so I pushed it. Maybe I should have used NetFinity's version scheme from the beginning, this would have been beba 0.4 then or something. Sigh. - Thanks to the guys on eMule-Mods.it and Jason for testing this beba version extensively so I could squash some bugs.
* ............, 2015
- merged: eMule 0.50b
- added: Clipboard Watchdog [Tuxman]
  * provides a more elegant way to watch the clipboard for eD2k links
- added: MediaInfo.dll update [WiZaRd]
  * automatically updating the MediaInfo.dll for a better user experience
- improved: added Client Analyzer status icons [WiZaRd]
  * technically added but disabled in beba for now
- improved: allowing parallel http downloads now [Avi-3k]
- improved: beba displays "(Proxy)" in the status bar if a proxy is connected [Tuxman]
- improved: eMule's Hard Limit box is greyed out when Auto Hard Limit is enabled [Tuxman]
- fix (b): beba didn't show mod versions in the sources list [Tuxman]
- fix (o): http sources were marked as dead incorrectly [Avi-3k]
- fix (b): Internet Security Zone settings were not saved [Tuxman]
- changed: added EditBinX and ReplaceVistaIcon to the sources packages [Tuxman]
- changed: ASFU reload intervals are now customizable (as in StulleMule) [Stulle/MoNKi]
- changed: beba has a smaller toolbar by default now :-) [Tuxman]
- changed: Client Analyzer information in the clients dialog is now more verbose [WiZaRd]
- changed: grammar fix in the credits [Tuxman]
- changed: no more maximum for "min. free disk space" [Tuxman]
- updated: MiniUPnP library to v1.9 [WiZaRd]
Win10 x64, запускается, порты в роутере через UPnP открываются и получаем High ID.
Можно пользоваться.
Сообщение отредактировал DCfan: 31 Январь 2021 - 10:25
