eMule Mephisto MoD - Моды мула - eMule-Rus.Net Форум муловодов
eMule Mephisto MoD
Сообщений в теме: 40
#1 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 18 Октябрь 2007 - 23:11
eMule 0.48a Mephisto v1.0
CHANGELOG FOR EMULE Mephisto MOD
eMule v0.48a Mephisto v1.0:
- 18.10.2007 -
based on eMule 0.48a ScarAngel 2.4 compiled with vs2003 SP1
NOTE: This is the new official branch of the ScarAngel mod with slotfocus.
NOTE: All preferences will be stored in the [ScarAngel] settings group.
Added: Slotfocus (always enabled) [Stulle]
Added: full/trickle for GUI purpose [Stulle]
+ F for full, T for trickle in speed column
Added: Display if last UploadBandwithThrottler reached bandwith [Stulle]
+ R for reached, NR for not reached in TransferWnd Splitter
Added: Mephisto version check [Official/MorphXT/Stulle]
Added: Mephisto GFX [eMule-web.de staff]
Added: Multiple friendslots [ZZ]
+ 1:3 ratio (friends excluded) will be enforced
Added: Option to configure slot opening due to missing trickle (0=off) [Stulle]
+ You better leave this option!
Added: Links for Server list and nodes file [Stulle]
Added: Diabolic Easteregg [Stulle]
+ Hell, I really wanted to do that for a long time now! XD
Changed: Superior clients are added after the last superior in UL list [Stulle]
Changed: Resort uploads if PowerShare or friendslot changed [ZZ/MorphXT]
Changed: Replaced ScarAngel references with Mephisto [Stulle]
Changed: Startup Sound [Stulle]
Changed: Status column sorted by slot number [Stulle]
Fixed: Resume mode combobox in Categorie dialog (ScarAngel) [Stulle]
Fixed: Auto Update IP2Country on startup (ScarAngel) [Stulle]
Removed: Several Xtreme upload settings [Xman]
Removed: Xtreme full/trickle upload handling [Xman]
Removed: Always Maximize Slotspeed (redundant) [Stulle]
Removed: ScarAngel version check [Official/MorphXT/Stulle]
eMule Mephisto.MoD Homepage
Download Mirrors:
eMule-0.48a-Mephisto-v1.0-bin.rar
eMule-0.48a-Mephisto-v1.0-src.rar
Download more versions of eMule Mephisto.MoD
Features & Changelogs for eMule Mephisto.MoD
Rate eMule Mephisto.MoD @ emule-mods.de !!!
#2 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 28 Декабрь 2007 - 05:15
eMule 0.48a Mephisto v1.1
eMule v0.48a Mephisto v1.1:
- 28.12.2007 -
based on eMule 0.48a ScarAngel 2.5 compiled with vs2003 SP1
Added: Transfer Multiple Chunks [Stulle]
Added: Adjust maximum upload time (1h-4h; default = 2h) [Stulle]
Added: Upload Tweak settings (be very careful! see documentation!) [Stulle]
Added: Veto new slot if one trickle is present [Stulle]
Added: Add new Slot if new slot is reacting too slow [Stulle]
Changed: Limitation kicks in when 1:2.9 reached instead of 1:3 [Stulle]
+ it worked but it was rather rough...
Changed: Allow PBF for Non-SUI only if state is NotAvailable [Stulle]
Changed: Accept new clients every 5 seconds instead of 10 [Stulle]
Changed: Accept new client when closing client uploads more than 1 KByte/s [Stulle]
Changed: Move PBF client down when he finished a chunk [Stulle]
Changed: Include Full/Trickle handling in slot opening process [Stulle]
+ does not effect bandwith spreading but represents it
Changed: Change between Full and Trickle only after a configured time [Stulle]
Changed: Move finishing clients down in upload [Stulle]
Changed: Calculation for the maximum to give [Stulle]
Fixed: New slot if no trickle (set wrong variable) [Stulle]
Transfer Multiple Chunks:
+ Mode 1: Do not transfer multiple Chunks (like disable the old function)
+ Mode 2: Xtreme Full Chunk (the old version of full chunk transfer)
+ Mode 3: Finish X chunks: Helps the other clients to finish x chunks (max X*PARTSIZE)
+ min 3 MB; max 9.28MB*x
+ Mode 4: Upload X Chunks: Transfers X*PARTSZIZE at the max
Download Mirrors:
eMule-0.48a-Mephisto-v1.1-bin.rar
eMule-0.48a-Mephisto-v1.1-src.rar
#3 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 06 Июль 2008 - 03:54
eMule 0.49a Mephisto v2.0
eMule v0.49a Mephisto v2.0:
- 06.07.2008 -
based on eMule 0.49a ScarAngel 3.0 compiled with vs2003 SP1
- Xtreme's evil heir -
Added: Drop blocking clients [Stulle]
Changed: Updated libs like the ScarAngel [Stulle]
Changed: Use 0x03 for saving Friendslots to friends.met [ZZ]
Changed: Keep Sup clients in up if there is no other sup client in queue [Stulle]
+ Works a little different, Sup clients are pushed down in upload
Changed: Min Slot number to two (uses "MinSlotsNew" now) [Stulle]
Fixed: Trickle threshold calculation [Stulle]
Remove blocking clients:
+ Upload health has to be 100%
+ Client has to be Full
+ Min Upload to prevent from kick is one tenth of the upload speed or 1 kbyte/s
+ Client has to be receiving for more than 5 minutes
+ Avg block ratio has to be >= 80% or >= 90% in last 20 sec
Download Mirrors:
eMule-0.49a-Mephisto-v2.0-bin.rar
eMule-0.49a-Mephisto-v2.0-src.rar
Rate eMule Mephisto.MoD @ emule-mods.de!!!
#4 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 28 Июль 2008 - 12:39
замечательный мод - очень хорошее продолжение экстрима и скарэнжела
#5 OFFLINE   mss73
    Руки прочь от ослика!
    08 ноя 2021 07:26
Отправлено 28 Июль 2008 - 14:18
Mephisto v2.0 - так же не стабилен, как и ScarAngel 3.0, на основе которого он сделан. :(
Не советую ставить эти две версии.
Молча вылетают, не выдав никакой ошибки.
От себя замечу, что ScarAngel 2.5 - пахал до 40 дней без остановки и никаких глюков не было.
#6 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 30 Июль 2008 - 07:14
2mss73
пока проблем с ним и глюков не было, юзаю его дней 5
#7 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 09 Сентябрь 2008 - 21:48
даешь каждому мефисто! самый лучший мод..)))
оле-оле-оле..
#8 OFFLINE   mss73
    08 ноя 2021 07:26
Отправлено 12 Сентябрь 2008 - 10:17
Для начала по-русски отличия от ScarAngel
Их совсем немного... а по сути два, но вполне существенных (настолько существенных, что эти два отличия невозможно было выделить в две отдельных галочки в настройках ScarAngel - а ведь эти оба мода делает один человек!)
1. SlotFocus
Mephisto пытается открывать как можно меньше слотов на отдачу, при этом давая каждому слоту качать столько, сколько тому канал позволит (а не всем поровну, как в большинстве модов).
То есть - первый качающий получает такую скорость, сколько может потянуть.
Второй - опять же сколько может потянуть из оставшейся ширины исходящего канала
А дальше - Mephisto открывает по одному слоты на отдачу, пока ими не заполнится весь исходящий канал, при этом пытаясь отдавать каждому столько, сколько он в состоянии забирать, постоянно пытаясь уменьшить число слотов на отдачу.
2.
Можно давать несколько дружеских слотов. Кроме того, слоты сохраняются при выключении Mephisto - так что в следующий раз не надо заново расставлять.
_____________
Проработал на этом моде, как на основном раздающем 2 недели.
Сразу замечание - PowerShare, PayBackFirst, FairPlay на версии 2.0 включать строго не рекомендую. Именно где-то в этих вещах именно в этой версии присутствует нестабильность, приводящая к тому, что Mephisto в любой момент может вылететь без объяснения причин.
А так - впечатления самые положительные. Для раздающих/релизеров - по сравнению с Xtreme и даже ScarAngel - преимущества очевидны.
#9 OFFLINE   drBatty
Отправлено 12 Сентябрь 2008 - 10:44
Просмотр сообщенияmss73 (12th September 2008 - 11:17) писал:
без PS - какие же релизы?
#10 OFFLINE   NeByvalyi
    Сегодня, 01:32
Отправлено 12 Сентябрь 2008 - 13:26
Просмотр сообщенияmss73 (Sep 12 2008, 11:17) писал:
... а не всем поровну, как в большинстве модов ...
Ой, только не надо поливать веером всех остальных!
Это только в официальном Муле зашит принцип отдачи "всем по 3кБ/с", т.е. всем поровну.
В большинстве МОДОВ как раз имеется возможность настроить другие варианты (и Мефисто тут ни фига не первый).
ЗЫЖ А вообще самая лучшая релизёрская отдача - "кумулятивная" в Нео. Вот это действительно Экстрим!
#11 OFFLINE   mss73
    08 ноя 2021 07:26
Отправлено 12 Сентябрь 2008 - 15:27
Что за кумулятивная?
#12 OFFLINE   NeByvalyi
    Сегодня, 01:32
Отправлено 12 Сентябрь 2008 - 17:46
Просмотр сообщенияmss73 (Sep 12 2008, 16:27) писал:
Читай тему "Обсуждение НеоМула"
в частности:
Просмотр сообщенияNeByvalyi (Jul 8 2008, 04:41) писал:
..включая опцию "кумулятивной отдачи", мне удавалось сфокусировать отдачу на 1-2 юзерах при ширине канала отдачи 240. Получалось что-то вроде: Юзер1-200, Юзер2-20 (типа в состоянии готовности перехватить отдачу у Юзера1), ещё с десяток юзеров - сочащиеся слоты (по 1-1,5)..
Добавлю, что и от сочащихся слотов можно избавится в настройках.
ЗЫЖ Сорри за оффтоп, может перенести последние посты в тему про Нео?
#13 OFFLINE   drBatty
Отправлено 12 Сентябрь 2008 - 17:54
Просмотр сообщенияNeByvalyi (12th September 2008 - 18:46) писал:
подтверждаю. фича такая есть, и она работает(в нео). Однако мне больше несколько другая схема нравится(та что в aMule по дефолту(хотя можно и "всем по 3" поставить), а в нео тоже покрутив настройки ставится.) мне нравится когда раздаётся по(к примеру) 20К каждому. Но если приёмник может больше - пусть больше(не во весь канал, конечно, раза в три), или меньше - тоже не сильно меньше, те кто по 1К мне не нужны.
#14 OFFLINE   mss73
    08 ноя 2021 07:26
Отправлено 12 Сентябрь 2008 - 18:15
Просмотр сообщенияdrBatty (12th September 2008 - 18:54) писал:
Открытая дискриминация и нарушение принципов работы ослосети.
#15 OFFLINE   drBatty
Отправлено 13 Сентябрь 2008 - 17:53
Просмотр сообщенияmss73 (Sep 12 2008, 19:15) писал:
да ни я им не нужен, ни они мне. С такой скоростью только фотками можно менятся, а у меня всё равно их нет на раздаче. Или они мод так криво настроили - тоже не интересно. К тому-же, это имено на отдачу, если будет для таких место - отдам, хотя практика показывает что они даже один кусок не могут скачать.
#16 OFFLINE   mss73
    08 ноя 2021 07:26
Отправлено 13 Сентябрь 2008 - 18:49
Если ты думаешь, что там где, скорости измеряются в десятках килобит - народ не пользуется Мулом - то глубоко ошибаешься.
Между прочим - я постоянно вижу несколько человек, которые со скоростью 1-2 кб/с тянут с меня 2 сериала размером в 12 и 35 гигабайт. Тянут месяцами! (хотя я не единственный полный источник - но у меня эти два сериала на PowerShare)
#17 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 13 Сентябрь 2008 - 21:34
кстати, единственное нарекание к Мефисто - это периодические вылеты... понятия не имею как с ними справиться..((
#18 OFFLINE   mss73
    08 ноя 2021 07:26
Отправлено 13 Сентябрь 2008 - 21:51
Ну читай же выше - всё написано.
Автор мода в курсе - он над этим работает...
#19 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 14 Сентябрь 2008 - 07:12
2mss73
у меня все это отключено.. все равно вылетает
#20 OFFLINE   mss73
    08 ноя 2021 07:26
Отправлено 14 Сентябрь 2008 - 13:52
Просмотр сообщенияdrBatty (Sep 12 2008, 18:54) писал:
Просмотр сообщенияdrBatty (13th September 2008 - 18:53) писал:
У этого юзера такая скорость всегда!
