eMule 0.50a SaintAngel
Сообщений в теме: 20
#21 OFFLINE   DCfan
    Вчера, 10:51
Отправлено 18 Октябрь 2013 - 09:44
Новость старая, но упомянуть стоит.
eMule v0.50a [SaintAngel v1.3 BETA2]
Список изменений:
Changelog for eMule v0.50a [SaintAngel v1.3 BETA2]
Based on MorphXT
Add: GDI Plus UI [dolphinx]
Add: Splash Extended lite [Xman/dolphinx/ZZUL-TRA]
Add: Custom Homepage(WebBrowser)
Add: FriendBoost
Add: FakeManager
Remove: sidebanner
Remove: unused icons/code/other
Remove: Only download complete files
Remove: PeerCache
Change: Some icons and argos::upload ban
Fix:change SLS code(i forget it)
rewrite auto restart&close
Changelog for eMule v0.50a [SaintAngel v1.3 BETA1]
Based on MorphXT
Add: Some mod icons
Add: Custom modstring [eyerb]
Add: Auto restart&close emule&pc
Add: manual kick and ban
Add: manual remove banned client
Add: Custom Bantime
Add: Don't ban community
Add: Push2upload
Add: server-auto-disconnect [morph4u]
Add: Default server.met and nodes.dat URL [pP]
Add: Releaser
Add: AutoFriendSlots
Add: ClipStat [X-Ray/WiZaRd]
Add: Remove All Banned Clients at Tools button [X-Mod]
Add: QuickStart at Tools button
Add: Show IP Filter Hits(statistics) [dolphinx]
Add: Show CustomModstring on title
Add: webbrowser [eMuleFuture]
Add: ASFU v3.5 (auto shared files updater) [Monke/Stulle/Wiz]
Add: SLS and remove morph-SLS
Add: Log ASFU and SLS
Add: ModLog and remove morphlog
Remove:Help
Remove:Some codes
Remove:WapServer
Remove:Wizard
Remove:MobileMule
Change:Change argos
Change:Only angvil's DLP and MADLP Support
Change:CUpDownClient::GetANTAddOn()(Random string)
Change:Rewrite CustomModstring code
Change:Slot Limit changed to 1-255
Change:Some small changed
Скачать:
ed2k:
ed2k://|file|SaintAngel.1.3.beta2.zip|5049622|35BA4FB427026D5989A2F0915AED6391|h=DEY7IS7IS2DJS5W5UJQVHIB63X6WLNF6|/
http:
https://docs.google....WEyZDA0Njg5ZWRl
Источник: http://angvil.tk/
Сообщение отредактировал DCfan: 18 Октябрь 2013 - 09:46
