eMule X-Ray MoD - Моды мула - eMule-Rus.Net Форум муловодов
eMule X-Ray MoD
Сообщений в теме: 10
#1 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 13 Апрель 2007 - 23:10
eMule 0.47c X-Ray v1.1
X-Ray MoD 1.1
Type | Idea | Source/Edit | Description | Used Tag
Feature | SiRoB | SilverSurfer | SolidGraph | // X-Ray :: SolidGraph
Feature | Mighty Knife | StulleMule | Static Server Handling - don't remove static servers | // X-Ray :: StaticServerHandling
Feature | SiRoB | MorphXT | Software Column in Upload- & Queuelist | // X-Ray :: ClientSoftwareColumn
Fix | JvA | JvA | Fixed major Uploadbug - thx 2 LorenzoC & hackersondope2002 | // X-Ray :: FullChunk
X-Ray MoD 1.0
Update | itsonlyme | SiRoB | New ModID and Modname Code | // X-Ray :: Modname
Update | Slugfiller | Xman/MorphXT | Minor Update of SafeHash Code | // X-Ray :: SafeHash
Update | SiRoB | Spike2 | Updated "Fix Connection Collision" Code | // X-Ray :: FixConnectionCollision
Update | Spike2 | Spike2 | Enhanced Client Recognization | // X-Ray :: EnhancedClientRecognization
Update | Maella/Stulle | Spike2/Neo | ReAsk Sources - inform eMule's and Donkeys via OP_CHANGE_CLIENT_ID | // X-Ray :: ReAskSrcAfterIPChange
Update | netfinity | Xman | DynamicBlockRequest - merged few xman changes into netfinity's code | // X-Ray :: DynamicBlockRequest
Update | Michael Fatzi | DavidXanatos | Updated major parts of the Speedgraph code (CDialog->CWnd) | // X-Ray :: Speedgraph
Update | A. Kazakovsky | WiZaRd | Updated major parts of the SysInfo code | // X-Ray :: Statusbar
Update | David Xanatos | JvA | AutoSoftLock v2 - now you can set a global- and a file-based ASL-Value | // X-Ray :: AutoSoftLock
Readded | | | Readded IRC
Feature | Slugfiller | SF-IOM/JvA | Set UploadPriority in Downloadlist and DownloadPriority in ShareList | // X-Ray :: DLULPrioExtension
Feature | ??? | TK4Mod | Show Unknown Protocol Tags received from Client in Client Detail Dialog | // X-Ray :: UnknownProtTags
Feature | BlueSonicBoy | TK4Mod/JvA | Redesigned Client Detail Dialog | // X-Ray :: RedesignedClientDetailDlg
Feature | itsonlyme | David Xanatos | ReqFiles | // X-Ray :: ReqFiles
Feature | MorphXT | NeoMule | MultiFileStatusBars | // X-Ray :: MultiFileStatusbars
Feature | slugfiller | David Xanatos | Modeless Dialogs | // X-Ray :: ModelessDialogs
Feature | enkeyDEV | Spike2 | Save/Load Sources | // X-Ray :: SLS
Feature | WiZaRd | eMulefuture | Save Friendslot | // X-Ray :: SaveFU
Feature | netfinity | Spike2 | UDP Reask security check - Don't accept responses if we haven't asked | // X-Ray :: UDPReaskSecurityCheck
Feature | netfinity | Spike2 | Known Client Bonus | // X-Ray :: KnownClientBonus
Feature | WiZaRd | eMulefuture | IntelliFlush | // X-Ray :: IntelliFlush
Feature | EastShare | MorphXT/Xman | IP2Country - added flags, new icons(e+) + Kadflags(emulefuture) + Update | // X-Ray :: IP2Country
Feature | Yun.SF3 | MorphXT | IPFilter Update | // X-Ray :: IPFilterUpdate
Feature | Slugfiller | eMulefuture | Show Estaminated Time till downloading from Client | // X-Ray :: QRETA
Feature | ??? | eMulefuture | OwnPrefs (preferences_xray.ini) | // X-Ray :: OwnPrefs
Feature | ??? | eMulefuture | FreshPrefs | // X-Ray :: FreshPrefs
Feature | Official | MorphXT/Stulle| Own Mod Version Check | // X-Ray :: X-Ray Version Check
Feature | MaxUpload | Stulle | Global Hard Limit | // X-Ray :: Global Hardlimit
Feature | leuk_he | eMulefuture | Obfuscated HTTP-Transfers | // X-Ray :: ObfuscatedHTTPTransfers
Feature | eWombat | eMulefuture | Winsock2 Support | // X-Ray :: Winsock2
Feature | Slugfiller | Spike2 | InfiniteQueue | // X-Ray :: InfiniteQueue
Feature | Slugfiller | TKB/JvA/Stulle| SlotRelease (Big Thx Stulle for your help) | // X-Ray :: SlotRelease
Feature | Xman | Spike2 | 80% score for non SUI clients | // X-Ray :: ScoreReducedNonSUIClients
Feature | Xman | Xtreme | Uploadtoolbar | // X-Ray :: Uploadtoolbar
Feature | WiZaRd | eMulefuture | Redesigned Shared Files Window | // X-Ray :: RedesignedFilesWnd
Feature | Stulle | Stulle | Compat Client Stats | // X-Ray :: CompatClientStats
Add | JvA | JvA | Added some more checks for AutoSoftLock and ActiveConnectionControl
Replace | DonkeyHote | WiZaRd | Replaced the old (buggy) toolbar code with the new one | // X-Ray :: Toolbar
Replace | itsonlyme | eMulefuture | Replaced QRDiff code with itsonlyme's one (thought it was little bit buggy) | // X-Ray :: QRdiff
Replace | Commander | NeoMule | Replaced the old Clientpercentage with NeoMule's | // X-Ray :: ClientPercentage
Replace | DarkMaster | DarkMaster | Replaced the old Toolbar with the new one designed by DarkMaster | // X-Ray :: Toolbar
Changed | VQB/WiZaRd | Spike2 | Removed Normal- and FriendChunkNr and changed FriedUploadamount to max 4gb | // X-Ray :: FullChunk
Remove | sivka | | Don't interrupt upload if waiting queue empty or friend-slot | // X-Ray :: HoldULSessionOnEmptyQueue
Remove | Xanatos/JvA | | Removed Skinable Toolbar | // X-Ray :: SkinableToolbar
Remove | Avi3k | hebmule | Extended Shared View | // X-Ray :: ExtendedSharedView
Fix | DavidXanatos | NeoMule | Critical Packet Fix | // X-Ray :: CriticalPacketFix
Fix | WiZaRd | eMulefuture | Threadsafe Fix | // X-Ray :: ThreadsafeFix
Fix | MadDog | JvA | Fixed Trayicon bug that Downloadbar wasn't shown
Fix | JvA | JvA | Fixed Sortbug of TotalUpDown | // X-Ray :: TotalUpDown
Fix | WiZaRd | JvA | Fixed small displaybug around XP-GroupBox | // X-Ray :: XP-GroupBox
Fix | WiZaRd | JvA | Fixed wrong lables of NiceHash Settings | // X-Ray :: NiceHash
Fix | WiZaRd | NeoMule | Fixed Loop-Bug in ClientList.cpp | // X-Ray :: LoopImprovement
Fix | Xman | Xtreme | Fixed destroy splashscreen bug when you close emule right after start | // X-Ray :: SplashExtended
Fix | JvA | JvA | Fixed minor Load/Save Bug of ReleaseBonus-Preferences | // X-Ray :: ReleaseBonus
Fix | dlarge | JvA | Fixed major Bug of VariableReaskTime-Preferences | // X-Ray :: VariableReaskTime
Fix | JvA | JvA | Fixed major Bug of DropSources-Preferences | // X-Ray :: DropSystem
Note: If you upgrade from a earlier X-Ray you have to set all ModPrefs again (Own Preferences File).
Download Mirrors:
eMule-0.47c-X-Ray-v1.1-bin.rar
eMule-0.47c-X-Ray-v1.1-src.rar
Download more versions of eMule X-Ray.MoD
Features & Changelogs for eMule X-Ray.MoD
Rate eMule X-Ray.MoD @ emule-mods.de !!!
eMule Tools: Server.met - Server-List - IPFilter - Skins
Сообщение отредактировал Da GuRu: 14 Апрель 2007 - 16:41
#2 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 20 Сентябрь 2007 - 20:00
eMule 0.48a X-Ray v1.2
X-Ray MoD 1.2
Merge | | | Merged to 48a Codebase
Merge | | | Now x-Ray uses all Xtremelibs (thx2Stulle)
Update | netfinity | WARP | Minor update of DelayedNNP Code | // X-Ray :: DelayedNNP
Update | netfinity | WARP | Minor update of KnownClientBonus Code | // X-Ray :: KnownClientBonus
Update | WiZaRd | eMulefuture | Major update of SLS-Code | // X-Ray :: SLS
Update | MorphXT | NeoMule | Minor update of MultiFileStatusBars | // X-Ray :: MultiFileStatusbars
Update | WiZaRd | eMulefuture | Major update of ClipStat code (also changed tag from WiZaRdStats to ClipStat) | // X-Ray :: ClipStat
Update | David Xanatos | NeoMule | Minor update of BetterClientAttaching Code | // X-Ray :: BetterClientAttaching
Feature | ??? | Diclonius/JvA | Filefeedback | // X-Ray :: Filefeedback
Feature | eMule+ | NeoMule | eMule+ Ini2-Class | // X-Ray :: eMulePlusIniClass
Feature | David Xanatos | NeoMule | KadInterfaceImprovement | // X-Ray :: KadInterfaceImprovement
Feature | WiZaRd | eMulefuture | AICH-Security | // X-Ray :: AICHSecurity
Feature | SR-13 | NeoMule | Part Import/Export | // X-Ray :: PartImportExport
Feature | enkeyDEV | eMF/Spike2 | Intelligent Chunk Selection | // X-Ray :: ICS
Feature | Xman | NeoMule | Uploading Problem Client | // X-Ray :: UploadingProblemClient
Feature | Xman | NeoMule | Extened Credit Table Arragement | // X-Ray :: ExtenedCreditTableArragement
Feature | xrmb | NeoMule | Shared Parts | // X-Ray :: SharedParts
Feature | Spike2 | Spike2 | Rebind UPnP on IP-Change | // X-Ray :: RebindUPnP
Feature | ??? | NeoMule/JvA | Safe Preferences Settings - Check Settings on every call of LoadPreferences() | // X-Ray :: SafePrefsettings
Feature | David Xanatos | NeoMule | Argos Antileechsystem - slightly modified | // X-Ray :: Argos
Feature | ??? | NeoMule/JvA | LeecherLog | // X-Ray :: LeecherLog
Add | Spike2 | Spike2 | Small additions to Sourcecache | // X-Ray :: Sourcecache
Add | BlueSonicBoy | BlueSonicBoy | Some Improvements in IP-Filter and Sockets | // X-Ray :: Optimizations
Add | Spike2/Xman | Spike2/Xtreme | Several code Improvements | // X-Ray :: Optimizations
Change | Xman | Xtreme | Don't save obfuscation required Sources in SourceSaver | // X-Ray :: SLS
Change | Xman | Xtreme | IP2Country shows now 32bit Flags for Windows >= XP | // X-Ray :: IP2Country
Change | WiZaRd | eMulefuture | If FS are toggled then the remaining data is recalculated | // X-Ray :: FullChunk
Change | Stulle | MorphXT | OwnCredits code into the new way for >= 0.48a clients | // X-Ray :: OwnCredits
Change | JvA | JvA | Swaped Upload- and Download-Speedgraph positions | // X-Ray :: Speedgraph
Remove | Xman | Xtreme | Uploadtoolbar due to official code | // X-Ray :: Uploadtoolbar
Remove | SiRoB | SilverSurfer | SolidGraph due to official code | // X-Ray :: SolidGraph
Remove | TBT | pHoeniX | Fadeout on Exit | // X-Ray :: FadeoutOnExit
Fix | WiZaRd | eMulefuture | Fixed minor bug around anchor in shared files window | // X-Ray :: RedesignedFilesWnd
Fix | Stulle | Spike2 | Fixed minor statistics bug in preferences.cpp | // X-Ray :: EnhancedClientRecognization
Fix | shadow2004 | eMulefuture | Fixed minor bug around Preferences Dialog | // X-Ray :: PrefSlider
Fix | Tuxman/JvA | JvA | Fixed minor Statusbarbug;show networkicon(ed2k/kad) even if disabled in prefs | // X-Ray :: Statusbar
Fix | Xman | Xtreme | Fixed minor PeerCache Bug in StatisticsDlg
Fix | Xman | Spike2 | Fixed minor seldom crashbug in Friendlist
Fix | Xman | Spike2 | Fixed minor shared files reloadbug on FNF-Exception
Fix | Xman | Xtreme | Fixed minor division by zero bug in Taskbarnotifier
Fix | Xman | Xtreme | Fixed minor crashbug around AICH-Syncthread on Shutdown
Fix | leuk_he | MorphXT | Fixed minor kad path bug
Fix | ilmira | ilmira | Fixed minor valid hash test bug
Fix | Xman | Xtreme | Fixed minor bug around enable/disable ClientList/QueueList
Fix | fafner | StulleMule | Fixed minor mem leak
Download Mirrors:
eMule-0.48a-X-Ray-v1.2-bin.rar
eMule-0.48a-X-Ray-v1.2-src.rar
eMule: Server.met - Server-List - IPFilter - Skins - eMule Wiki - Nodes.dat
#3 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 18 Май 2008 - 01:37
eMule 0.49a X-Ray v1.4
X-Ray MOD 1.4
Merge: Merged to 49a Codebase
Update: Updated libpng to 1.2.28 due to official lib update
Update: Updated CxImage to 6.0 due to official lib update
Update: Minor Update of Antileech.dll - Xman
Update: Major Update of Rollup Control Code - gui.dat isn't used anymore + cleanup - eMule+/JvA
Update: Minor Update of SlideBar Code - eMule+
Feature: MassRename including SimpleCleanup - MorphXT-Team
Feature: Superior Client Handling - Stulle
Feature: Payback First - AndCycle/SiRoB
Feature: Powershare - zz/MorphXT-Team
Fix: Fixed GDI-Leak around IP2Country - RapidMule/WiZaRd
Fix: Fixed GDI-Leak around Directories-Page on close - RapidMule/WiZaRd (implemented in official)
Fix: Fixed Memory Corruption in Webserver - WiZaRd (implemented in official)
Fix: Fixed minor buffer overflow bug in Uploadlist - JvA
Fix: Fixed minor banning bug - could happen that banned clients aren't recognized - JvA
Fix: Fixed some Memleaks in SysInfo Code - WiZaRd
Remove: SafeKad - has to be verified if needed - netfinitiy
Remove: Anti fragmenting - has to be verified if needed - netfinitiy
Remove: KadPerformance Improvements - has to be verified if needed - netfinitiy
Remove: Corruption Black Box Fix - implemented in official code now - David Xanatos
Remove: ShareFilter - implemented in official code now - WiZaRd
Download Mirrors:
eMule-0.49a-X-Ray-v1.4-bin.rar
eMule-0.49a-X-Ray-v1.4-src.rar
#4 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 17 Июнь 2008 - 12:51
Экстрим мод у меня подох смертью храбрых, поставил X-Ray.
Кто его юзал, какие впечатления?
свои ощущения: мод нравится, хоть и GUI его гм... слишком гуеватая.. имеет похоже свою антилич систему Аргос, с огромным количеством настроек этого аргуса. Вот.. скорость примерна такая-же как и у экстрима.
#5 OFFLINE   Relicto
    08 янв 2009 00:16
Отправлено 19 Июнь 2008 - 11:54
сдается мне, с выбором мода, я уникален
#6 OFFLINE   Skynin
    20 окт 2009 15:36
Отправлено 29 Июль 2008 - 22:48
Просмотр сообщенияRelicto (Jun 19 2008, 10:54) писал:
Не-а :)
Долго жил на ScarAngel 2.5. Поставил недавно 3.0 и настолько плоха оказалась что стал пробовать и другие моды. X-Ray весьма понравился :)
Аргос же работает вполне отменно.
Вобщем пока никаких других модов и знать не хочу - главное в X-Ray есть, а всякие тонкие настройки из морфомодов, как посмотрел, влияют слабо. Только время зря потратил на их изучение и пробы.
#7 OFFLINE   X-Ray
    всё хорошо!
    19 июл 2010 00:18
Отправлено 30 Июль 2008 - 01:29
X-Ray MoD  :baby:
не мой если честно, но тоже довольно забавный - советую тем, кто ищет что-то особенное! )
#8 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 05 Сентябрь 2008 - 06:10
eMule 0.49b X-Ray v1.5
X-Ray MOD 1.5
Merge | | | Merged to 49b Codebase
Update | | | Updated MiniUPnP code to v1.1 (04/07/2008)
Update | Xman | Stulle/MyTh/..| Major Update of Antileech.dll - Version 4 (including xunlei detection)
Update | JvA | JvA | Minor Update of countryflag.dll's | // X-Ray :: IP2Country
Feature | JvA | JvA | Queue List per File in Shared Files Window | // X-Ray :: QueueListPerFile
Feature | Xman | Xtreme | See OnQueue | // X-Ray :: SeeOnQueue
Add | Maella | Xtreme | Several code Fixes | // X-Ray :: FiXeS
Add | Maella/Xman/..| Xtreme | Several code Improvements | // X-Ray :: Optimizations
Improve | Michael Fatzi | JvA | Changed minor code part (FillRect->FillSolidRect) because it's faster | // X-Ray :: Speedgraph
Improve | David Xanatos | JvA | Changed several code parts around Argos code | // X-Ray :: Argos
Fix | Makkurayami | JvA | Fixed minor Statisticsbug caused by a to small array | // X-Ray :: StandbyDownload
Fix | Crimson | JvA | Fixed minor Preferences Bugs in Argos Page and changed some default values | // X-Ray :: Argos
Fix | AUG | JvA | Fixed minor NULL-Pointer bug in AddBannedClient | // X-Ray :: Argos
Fix | JvA | JvA | Fixed minor draw bug on stopping a file with A4AF-sources | // X-Ray :: MultiFileStatusbars
Fix | bscabral | DreaMule | Fixed minor Multimonitor Bug around Tooltips
Remove | WiZaRd | eMulefuture | Redesigned Shared Files Window | // X-Ray :: RedesignedFilesWnd
Remove | SiRoB | MorphXT | Fix Connection Collision - don't know if it's really needed in 49b | // X-Ray :: FixConnectionCollision
Download Mirrors:
eMule-0.49b-X-Ray-v1.5-bin.rar
eMule-0.49b-X-Ray-v1.5-src.rar
Rate eMule X-Ray.MoD @ emule-mods.de!!!
#9 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 22 Октябрь 2008 - 23:37
eMule 0.49b X-Ray v1.6
This version is only a minor code update but i have to release a fixed version for some people that report that X-Ray crashes very often. With this version it sould be fixed now.
I've written some more unique things like saving the date of the last file request, which can be used as an indicator to unshare seldom requested files. Therefor i've added a new column in the Shared Files window.
I've planed something for the next version and i need some talented graphic artists for this. If you think you can help please pm me.
And as always i am searching for some more translators.
Thanks to all beta testers, my translators (AUG,nuberu and the darkforge.it guys). thanks for you hard work.
this time the binary package contains already the translations for Spanish, Italian, Traditional and Simplified Chinese.
X-Ray MOD 1.6
Update: Updated Crypto++ code to v5.5.2 (9/24/2007)
Update: Updated MiniUPnP code to v1.2 (07/10/2008)
Update: Updated Argos code by adding some new detection methods for fake emules... (zz_fly/JvA)
Feature: Automatic Restart eMule Client if necessary (David Xanatos/JvA)
Feature: Save Date of the last SharedFileRequest to avoid removing requested files (JvA)
Feature: Relative Chunk Display (David Xanatos)
Add: Added H.264 and 3vid FourCC Codes to the MediaInfo Detection (JvA)
Add: Added DownloadChunkDisplay also to the Downloading Clients List (JvA)
Add: Added some more information to the SharedParts Chunklist (JvA)
Improve: Minor optimization in CPartFile::UpdatePartsInfo (taz/WiZaRd)
Improve: Skip DupCheck if it is not necessary (WiZaRd)
Change: Bad Sources (identified by Argos) won't be sent via SourceExchange (JvA)
Fix: Fixed (hopefully) major source finding bug (JvA)
Fix: Fixed minor official draw bug around SharedFiles Filter on Language change (JvA/WiZaRd)
Fix: Fixed minor draw bug around Toolbar on low resolutions (Hiding speedmeter now) (JvA)
Fix: Fixed minor crash bug around Collections (caused by Modeless Dialogs) (WiZaRd)
Fix: Fixed minor crash bug around ReqFileCtrl (caused by my own stupidity) (WiZaRd)
http: //forum.emule-project.net/index.php?showtopic=140334
Download Mirrors:
eMule-0.49b-X-Ray-v1.6-bin.rar
eMule-0.49b-X-Ray-v1.6-src.rar
#10 OFFLINE   DCfan
    Вчера, 05:11
Отправлено 15 Июль 2009 - 14:50
eMule 0.49c X-Ray v1.7 RC1
X-Ray MOD 1.7 RC1
Merge: Merged to 49c Codebase
Update: Minor Update of Antileech.dll - Version 6 (zz_fly)
Update: Updated Crypto++ code to v5.6.0 (15/03/2009)
Update: Updated MiniUPnP code to v1.3 (17/04/2009)
Update: Reworked Shared-Parts feature due to shareable file class
Feature: FunnyNick (xrmb/Stulle)
Add: Added Part Status Bar to Shared Parts Feature (JvA)
Add: Added Fincan Hash detection to Argos (enabled by default) (JvA)
Add: Added RAR support for IPFilter Update (Stulle)
Change: Minor adjustments of the owing upload data amount calculation (JvA)
Change: HTTP-Download Progressbar style is now the same as in the Shared Files Window (JvA)
Change: Several enhancements and changes around Transfer Window (disable list etc.) (JvA)
Change: Altered IntelliFlush to use official FileBufferTimeLimit prefences.ini option (JvA)
Change: Minor changes around vertical Countryflag Alignment (jerryBG)
Change: Now the known clients count in Transfer-Wnd counts instead of beeing static (JvA)
Change: Minor changes around value saving to preferences.ini (faster method) (eMule+)
Fix: Fixed major argos bug that caused that all X-Ray clients were modthiefs (gomez82)
Fix: Fixed minor crash bug around SharedParts feature (JvA)
Fix: Fixed minor draw bug around ClientDetailDialog (Tuxman/JvA)
Fix: Fixed minor draw bug around Sourcecache Column in DownloadListCtrl (Tuxman/JvA)
Fix: Fixed minor cosmetic bug on saving SLS clients (JvA)
Fix: Fixed minor bug on saving Argos preferences (Plain AntiNickThief wasn't saved) (morph4u)
Fix: Fixed minor bug around Argos Nickchanger detection (Rapid_Mule)
Fix: Fixed minor crash bug around SearchResult DetailDialog (morph4u/WiZaRd/JvA)
Fix: Fixed possible crashes around Credit-pointer (JvA)
Fix: Fixed minor PBF display bug around Uploadlist (JvA)
Fix: Fixed minor bug around SharedFilesCtrl that could result in an endless loop (Stulle)
Fix: Fixed minor bug around MassRename that could result in an endless loop (JvA)
Fix: Fixed minor sorting bug in SharedFilesCtrl (moloko+)
Fix: Fixed minor bug around FileFeedback (forgot one codeline...stupid me) (morph4u)
Fix: Fixed major bug around Simple Cleanup -> Simple Cleanup was not working (morph4u/JvA)
Fix: Fixed minor bug around Downloading via Webserver (Stulle)
Fix: Fixed memleak around RollupCtrl (WiZaRd)
Fix: Fixed major crash around SysInfo on Vista (WiZaRd)
Fix: Fixed memleak around Global Hardlimit (JvA)
Fix: Fixed memleak around SimpleCleanup (JvA/WiZaRd)
Fix: Fixed minor unicode bug around Categries if non-unicode Logfont was selected (Tuxman/WiZaRd/JvA)
Fix: Fixed bug around Friends - Friends were not correctly recognized in some cases (Tuxman/JvA)
Fix: Fixed minor bug on IP-Filter update (Crimson/Stulle)
Fix: Fixed minor ID3lib buffer overflow (WiZaRd)
Remove: Removed some more redundant official code around Transfer Window Style
Remove: Removed redundant Optimization around List Controls due to 49c merge
Remove: Removed redundant buggy fix for filtertext update on language change
Скачать бинарик :
http://prdownloads.s...in.rar?download
Скачать исходники :
http://prdownloads.s...rc.rar?download
#11 OFFLINE   Da GuRu
    13 мар 2011 08:27
Отправлено 18 Июль 2009 - 19:36
X-Ray MOD 1.7
Add: Added drop blocking clients (Stulle/JvA)
Add: Added gap support for Part Status Bar of Shared Parts Feature (JvA)
Add: Bypass ICS when preview chunks should be downloaded first (SiRoB)
Fix: Fixed minor roundering bug around slotspeed (JvA)
Fix: Fixed minor crashbug around SharedParts on Single-File Sharing (TuXMan/JvA)
Fix: Fixed minor preferences bug around statistics tree update delay (morph4u)
X-Ray MOD 1.7 RC1
Fix: Fixed minor draw bug around ClientDetailDialog (TuXMan/JvA)
Fix: Fixed minor draw bug around Sourcecache Column in DownloadListCtrl (TuXMan/JvA)
Fix: Fixed minor unicode bug around Categries if non-unicode Logfont was selected (TuXMan/WiZaRd/JvA)
Fix: Fixed bug around Friends - Friends were not correctly recognized in some cases (TuXMan/JvA)
Download Mirrors:
eMule-0.49c-X-Ray-v1.7-bin.rar
eMule-0.49c-X-Ray-v1.7-src.rar
