EAC extraction logfile from 22. November 2013, 9:15
RockoCo / Дракон и Принцесса
Used drive : TSSTcorpCDDVDW SH-S223F Adapter: 0 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\wavpack.exe
Additional command line options : -hm %source% %dest%
TOC of the extracted CD
1 | 0:00.00 | 4:30.23 | 0 | 20272
2 | 4:30.23 | 4:57.02 | 20273 | 42549
3 | 9:27.25 | 4:38.19 | 42550 | 63418
4 | 14:05.44 | 3:56.14 | 63419 | 81132
5 | 18:01.58 | 6:20.51 | 81133 | 109683
6 | 24:22.34 | 5:17.15 | 109684 | 133473
7 | 29:39.49 | 5:15.69 | 133474 | 157167
8 | 34:55.43 | 6:55.27 | 157168 | 188319
9 | 41:50.70 | 5:32.60 | 188320 | 213279
10 | 47:23.55 | 3:22.24 | 213280 | 228453
Range status and errors
Selected range
Filename D:\Iso\RockoCo - Дракон и Принцесса\RockoCo - Дракон и Принцесса.wav
Peak level 96.6 %
Extraction speed 1.6 X
Range quality 100.0 %
Test CRC 3468762E
Copy CRC 3468762E
Copy OK
No errors occurred
AccurateRip summary
Track 1 not present in database
Track 2 not present in database
Track 3 not present in database
Track 6 not present in database
Track 7 not present in database
Track 8 not present in database
Track 9 not present in database
Track 10 not present in database
None of the tracks are present in the AccurateRip database
End of status report
==== Log checksum F984403C4BF666CB4235D33FD72B9ADA22D5FB1AB09C77148C2AA7D88E1FFD9E ====
Скрыть
