EAC extraction logfile from 19. August 2012, 21:21
Профессор Лебединский / Смеяться или плакать
Used drive : _NEC DVD_RW ND-4571A Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 48
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
1 | 0:00.00 | 3:41.72 | 0 | 16646
2 | 3:41.72 | 3:37.43 | 16647 | 32964
3 | 7:19.40 | 4:26.29 | 32965 | 52943
4 | 11:45.69 | 5:33.15 | 52944 | 77933
5 | 17:19.09 | 3:53.67 | 77934 | 95475
6 | 21:13.01 | 4:27.69 | 95476 | 115569
7 | 25:40.70 | 4:10.50 | 115570 | 134369
8 | 29:51.45 | 6:28.04 | 134370 | 163473
Range status and errors
Selected range
Filename D:\Iso\Профессор Лебединский - Смеяться или плакать\Профессор Лебединский - Смеяться или плакать.wav
Peak level 100.0 %
Extraction speed 5.7 X
Range quality 100.0 %
Test CRC 102C1909
Copy CRC 102C1909
Copy OK
No errors occurred
AccurateRip summary
Track 1 not present in database
Track 2 not present in database
Track 3 not present in database
Track 6 not present in database
Track 7 not present in database
Track 8 not present in database
None of the tracks are present in the AccurateRip database
End of status report
Скрыть
