Исполнитель: Glenn Miller
Год выпуска: 2005, Астра Рекордс / Astra330931
Жанр: Jazz
Тип рипа: image+cue+eac.log+covers
Формат: WAVPack (.wv)
Битрейт: lossless
Контейнер: ISO
Продолжительность: 46:04
Размер файла: 288,81 MB
Скрытый текстКомпозиции:
01. Pennsylvania 6-5000 (3:15)
02. The little man wasn't there (2:51)
03. Don't sit under the appletree (3:07)
04. I've got a girl in Kalamazo (2:40)
05. Indian Summer (3:18)
06. American patrol (3:36)
07. Blue champangne (2:36)
08. Moonlight serenade (2:24)
09. Sun valley jump (2:32)
10. Perfidia (3:23)
11. String of pearls (2:59)
12. Sunrise serenade (3:17)
13. St.Louis Blues March (3:33)
14. Moonlight cocktail (1:42)
15. Under a blanket of blue (1:45)
16. At last (3:06)
10. Perfidia (3:23)
16. At last (3:06)
Скрыть
Скрытый текстLog EAC
EAC extraction logfile from 24. May 2013, 11:04
Glenn Miller / Moonlight serenade
Used drive : TSSTcorpCDDVDW SH-222BB Adapter: 3 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Used interface : Installed external ASPI interface
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\wavpack.exe
Additional command line options : -hm %source% %dest%
TOC of the extracted CD
1 | 0:00.00 | 3:15.00 | 0 | 14624
2 | 3:15.00 | 2:50.62 | 14625 | 27436
3 | 6:05.62 | 3:07.20 | 27437 | 41481
4 | 9:13.07 | 2:39.55 | 41482 | 53461
5 | 11:52.62 | 3:17.68 | 53462 | 68304
6 | 15:10.55 | 3:35.65 | 68305 | 84494
7 | 18:46.45 | 2:36.10 | 84495 | 96204
8 | 21:22.55 | 2:23.55 | 96205 | 106984
9 | 23:46.35 | 2:32.00 | 106985 | 118384
10 | 26:18.35 | 3:22.52 | 118385 | 133586
11 | 29:41.12 | 2:58.60 | 133587 | 146996
12 | 32:39.72 | 3:17.03 | 146997 | 161774
13 | 35:57.00 | 3:33.15 | 161775 | 177764
14 | 39:30.15 | 1:42.15 | 177765 | 185429
15 | 41:12.30 | 1:45.32 | 185430 | 193336
16 | 42:57.62 | 3:05.52 | 193337 | 207263
Range status and errors
Selected range
Filename F:\NetLab\Glenn Miller - Moonlight serenade\Glenn Miller - Moonlight serenade.wav
Peak level 100.0 %
Extraction speed 6.9 X
Range quality 100.0 %
Test CRC 6F3EFF56
Copy CRC 6F3EFF56
Copy OK
No errors occurred
AccurateRip summary
Track 1 not present in database
Track 2 not present in database
Track 3 not present in database
Track 6 not present in database
Track 7 not present in database
Track 8 not present in database
Track 9 not present in database
Track 10 not present in database
Track 11 not present in database
Track 12 not present in database
Track 13 not present in database
Track 14 not present in database
Track 15 not present in database
Track 16 not present in database
None of the tracks are present in the AccurateRip database
End of status report
Read mode : Secure
Quality : High
Add ID3 tag : No
Selected range
Peak level 100.0 %
Test CRC 6F3EFF56
Copy CRC 6F3EFF56
Copy OK
No errors occurred
AccurateRip summary
Скрыть
Релиз от: worand
Glenn Miller - Moonlight Serenade
