eMule SharkX MoD
Сообщений в теме: 7
#1 OFFLINE   Da GuRu
    13 Мар 2011 00:27
Отправлено 21 Февраль 2008 - 04:54
eMule 0.48a SharkX v1.1
SharkX 1.1 20/02/08
change : default option - beta versions will check for new betas
fix : fine CS (additional CS) can't be selected with CA CS (wasn't active anyway) - 10'x aSceT
SharkX 1.0f 17/02/08
add : new version + beta check from Mephisto 1.1 (WiZaRd/Stulle/taz)
add : few optimization from Mephisto 1.1 (SiRoB)
fix : possible mem corruption @ CWebServer::CWebServer (WiZaRd)
fix : IntelliFlush options graying (taz)
SharkX 1.0e 11/02/08
fix : GDI leak IP2Country and other custom lists from eMuleFuture CVS (Rapid Mule/WiZaRd)
add : optimization for Progress Hash @ CKnownFile::CreateFromFile from eMuleFuture 0.6 (WiZaRd)
fix : Collection double extension fix from ZZUL_BastarD 1.9.1 (CB)
fix : a mem corruption due to a miss in drop sources menu strings (taz) - 10'x cellax
SharkX 1.0d 30/01/08
update : Generalize (for all directories related, not just for Options->Directories) solution for GDI leak (WiZaRd)
update : fix @ CDirectoryTreeCtrl::OnDestroy to avoid new mem leaks (Rapid Mule)
add : drop sources menu strings for translations @ CDownloadListCtrl::CreateMenues (taz)
SharkX 1.0c 27/01/08
update : AsyncSocketEx code from Warp 0.3a11 (Netfinity), adjustment for eMF winsock2 & Extreme UPNP (taz)
fix : AsyncSocketEx deadlocks and memory corruption from Warp 0.3a11 (Netfinity)
SharkX 1.0b 24/01/08
fix : fix @ CKademliaUDPListener::Process_KADEMLIA2_REQ for RecheckIP and firewall status (Enig123)
add : optimization @ CUpDownClient::SetDownloadState for request a new partstatus as long as we have a socket (Xman)
add : Optionnal funnynick display from MorphXT 10.5 (SiRoB) - 10'x JulGer
change : VS2005
update : cryptlib 5.2.2
update : libpng 1.22
update : CxImage 5.99c
update : md4.cpp and md4.h for x86 and x64 release from Warp 0.3a11 (Netfinity)
update : sha.cpp and sha.h for x86 and x64 release from Warp 0.3a11 (Netfinity)
update : types.h types from Warp 0.3a11 (Netfinity)
Download Mirrors:
eMule-0.48a-SharkX-v1.1-bin.rar
eMule-0.48a-SharkX-v1.1-src.rar
Download more versions of eMule SharkX.MoD
Features & Changelogs for eMule SharkX.MoD
Rate eMule SharkX.MoD @ emule-mods.de !!!
#2 OFFLINE   Da GuRu
    13 Мар 2011 00:27
Отправлено 19 Март 2008 - 07:27
eMule 0.48a SharkX v1.2
SharkX 1.2 17/03/08
fix : version + beta check due to ntohl (taz)
fix : "search Related Files" Always Enabled (tux)
fix : log spam by Fix connection collision (Netfinity) - 10'x Enig123
add : track eMule mem usage (taz)
fix : CleanUpClientList from NeoMule 4.50 (Maella)
change : adapt for longer run sessions (larger hash tables) from Xtreme 6.1 (Xman)
fix : possible crash @CDeadSourceList::IsDeadSource from Xtreme 6.1 (Xman)
add : optimize dead sources handling from Xtreme 6.1 (Xman)
fix : UPNP correct status display at stats - 10'x isch
change : unified known str (taz) - 10'x Alden
add : searchCatch from eMuleFuture v0.6 (SLUGFILLER/WiZaRd) - 10'x Alden
update : Source Cache from MorphXT 10.5 (Xman / Stulle) + adjust to AutoHL (taz)
fix : adjust & optimize (minor) CAntiLeechData::Check4NickThief to funnynick (taz) - 10'x WiZaRd
fix : no funny nick to BadGuys (added Client Analyzer support to funnynick) (taz)
Download Mirrors:
eMule-0.48a-SharkX-v1.2-bin.rar
eMule-0.48a-SharkX-v1.2-src.rar
#3 OFFLINE   drBatty
Отправлено 20 Март 2008 - 02:40
Da GuRu а можно в двух словах? чем он лучше других модов?
#4 OFFLINE   -DenisS-
    21 Июн 2018 13:03
Отправлено 20 Март 2008 - 14:39
Просмотр сообщенияdrBatty (Mar 20 2008, 11:40) писал:
+1  :dribble:
#5 OFFLINE   Da GuRu
    13 Мар 2011 00:27
Отправлено 26 Ноябрь 2008 - 08:33
eMule 0.49b SharkX v1.4
SharkX 1.4 - 27/11/08
remove : fix connection collision
remove : ASF
remove : Global HL
add : Advanced download throttling (Netfinity)
add : Optional funnynick display (SiRoB)
add : folder ICONS (Commander)
add : Resource Bar (WiZaRd)
add : AutoHL (WiZaRd)
add : no SUQWT for leechers on file hot swapping (from X-Ray v1.6)
add : Show src totals (taz)
update : community & corrupt userhash detection from DLP v35 (zz_fly/SquallATF)
chnage : mod version check "host name"
change : mod support forum links
change : default region for connection wizard to Israel
change : modstr SharkX
change : mod icons + options side banner
change : upload list layout
change : adjust Sivka file settings to AutoHL (taz)
change : region for connection wizard derived from OS locale / lang (taz)
change : adjust drop system & Sivka file setting to AutoHL (taz)
change : adjust Client Analyzer to funnynick (taz)
fix : mod config dir for multi user, i.e. appdata (taz)
fix : chunk selection mode logic for ICS (taz)
fix : no SUQWT for Mod/Nick thieves (taz)
fix : CA events log once (taz)
fix : crash after lowid notifier (taz)
fix : direct URL updates for ipfilter (taz)
fix : crash on ip2country update
fix : mod (& beta) version check option selection
fix : recode SlotFocus (from eMuleFuture v0.7) & SlotControl (from X-Ray v1.6)
based on AcKroNiC v5.0
Download Mirrors:
eMule-0.49b-SharkX-v1.4-bin.rar
eMule-0.49b-SharkX-v1.4-src.rar
Rate eMule SharkX.MoD @ emule-mods.de!!!
#6 OFFLINE   Kenson
    25 Ноя 2009 11:50
Отправлено 14 Март 2009 - 12:12
Решил посмотреть данный мод и описать что приметил в нем:
В папке с программой присутствует дополнительная папка Addons, в которой находятся следующие файлы: countryflag32.dll, countryflag.dll, ipfilter.dat, ip-to-country.csv, ModIconDLL.dll (как я понял файл для отображения иконок других модов в списке очериди) - похоже все те файлы которые можно обновлять.
После запуска выходит окно со следующим посланием:
Вы используете модификацию с новой системой распознования и защиты от нечестных клиентов если Вы заинтересовынны в способе её работы - посетите наш форум и поделитесь своими впечатлениями и предложениями!
Однако, не пытайтесь запрашивать добавление нечестных\нелегальных возможностей, таких как блокировка (ban)
или рендомальное снижение кредитных очков. Я также не буду добавлять никаких списков "известных личеров" -
система основана только на эвристическом анализе и таковой останется! Б
Благодарю за внимание, высоких Вам скоростей!
--taz
Далее как обычно выходит помощник для настройки программы где приметил такую строку как Region, в которой можно выбрать страну: Официальная, Италия, Израиль. Понял так что видимо от выбора будет зависеть как будет отображаться моя страна для других пользоватилей.
В папке с языками уже присутствует русификатор, поэтому переставлять язык не пришлось.
Интерфейс такой же как и ScarAngel и отсутствует кнопка страны (Country) как в MagicAngel. В настройках присутствуют закладки с левой стороны как MagicAngel, где "Основные настройки" и "дополнительные настройки" идентичны с остальными модами Мула, а вот закладка SharkX является своеобразной. Опишу лишь отличия которые были мне заметны от других модов.
Состоит она из трех подзакладок Shark I, Shark II и обновления. В Shark I настраиваются Закачка, Отдача, дисплей, система. В системе есть одинаковая с MagicAngel настройка Quick Start, в отдаче можно настроить систему наказания виде лишь бана и то очень ограничена (по сравнению с ScarAngel, абсолютна никакая с MagicAngel), тут же есть пункт "Использовать систему кредитов (поощрять отдающих)" в которой три выбора: "не поощрять", "Официальная(Внимание!Эту систему легко обмануть!)", "Анализатор(Встроенная эвристическая антиличерская система)". По умолчанию стоит трений "Анализатор". В пункте дисплей есть пункт IP2country (такой же как в MagicAngel). И есть кнопка включения Забавных ников, но в отличии от других модов здесь нельзя вместо Funnynick написать что-то своё.
В Shark II мне был знаком Invisible mode, из других есть следующие: окно Ackronic Search Filter с двумя кнопками Active Family Filter (напротив кнопка Change password), Active Trash Filter. Ниже пункт Activate LOW-ID NOTIFIER под которым располагается ползунок. За что это отвечает пока не смог определить, если кто знает буду признателен если опишет.
В закладке обновления все тоже самое что и в других модах.
#7 OFFLINE   drBatty
Отправлено 15 Март 2009 - 02:50
скачал, посмотрел... вроде хороший мод...
однако менять свои aMule или Neo+(D39) не буду.
#8 OFFLINE   Kenson
    25 Ноя 2009 11:50
Отправлено 12 Июнь 2009 - 22:41
Заметил неприятную странность у данного мода после 2х недель использования, он напрочь не реагирует на команду "Пытаться сначала загрузить части для предпросмотра". Сначала показалось что возможно клиетов недостаточно, но проследив за ним, стало очевидно что он начинает качать от куда угодно но не с начальной части и конечной.
Чтобы убедиться поставил на закачку файл со множеством источников и как полагается уже он начал качать с середины. Тогда, этот же файл закинул в другой мод - Sivka, и данный мод с того же клиета начал качать как и должен с начала и с конца. Следовательно кому важно просмотреть качества видео файла, эта странность данного мода может быть довольно не приятной.
