Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 31. December 2011, 18:38
Rossini Quartet / Rossini. Ouvertures
Used drive : TSSTcorpCDDVDW SH-S223F Adapter: 3 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\wavpack.exe
Additional command line options : -hlm %s
TOC of the extracted CD
1 | 0:00.33 | 8:26.00 | 33 | 37982
2 | 8:26.33 | 11:55.00 | 37983 | 91607
3 | 20:21.33 | 7:20.00 | 91608 | 124607
4 | 27:41.33 | 11:01.00 | 124608 | 174182
5 | 38:42.33 | 8:01.00 | 174183 | 210257
6 | 46:43.33 | 9:45.00 | 210258 | 254132
Range status and errors
Selected range
Filename D:\temp\Misic\Rossini Quartet - Rossini. Ouvertures\Rossini Quartet - Rossini. Ouvertures.wav
Peak level 89.4 %
Range quality 100.0 %
Test CRC D3748171
Copy CRC D3748171
Copy OK
No errors occurred
AccurateRip summary
Track 1 not present in database
Track 2 not present in database
Track 3 not present in database
Track 6 not present in database
None of the tracks are present in the AccurateRip database
End of status report
Скрыть
