Исполнитель: Yello
Издание: 1985, Mercury 822 820-2
Жанр: Synthpop
Тип рипа: image+cue+eac.log+covers
Формат: WAVPack (.wv)
Битрейт: lossless
Контейнер: ISO
Продолжительность: 40:56
Размер файла: 222.34 MB
Скрытый текстКомпозиции
01. Desire - 3:43
02. Vicious Games - 4:21
03. Oh Yeah - 3:05
04. Desert Inn - 3:30
05. Stalakdrama - 3:06
06. Koladi-ola - 2:58
07. Domingo - 4:34
08. Somtimes (Dr. Hirsch) - 3:36
09. Let Me Cry - 3:30
10. Ciel Ouvert - 5:26
11. Angel No - 3:07
03. Oh Yeah - 3:05
07. Domingo - 4:34
11. Angel No - 3:07
Скрыть
Скрытый текстLog EAC
EAC extraction logfile from 19. November 2013, 17:14
Yello / Stella
Used drive : PLEXTOR DVDR PX-810SA Adapter: 2 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 48
Used interface : Installed external ASPI interface
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -V -T "Date=%year%" -T "Genre=%genre%" -T "COMMENT=ripped by bvstudio®" %source%
TOC of the extracted CD
1 | 0:00.33 | 3:42.50 | 33 | 16732
2 | 3:43.08 | 4:20.60 | 16733 | 36292
3 | 8:03.68 | 3:04.70 | 36293 | 50162
4 | 11:08.63 | 3:30.22 | 50163 | 65934
5 | 14:39.10 | 3:05.73 | 65935 | 79882
6 | 17:45.08 | 2:57.62 | 79883 | 93219
7 | 20:42.70 | 4:33.38 | 93220 | 113732
8 | 25:16.33 | 3:35.67 | 113733 | 129924
9 | 28:52.25 | 3:30.25 | 129925 | 145699
10 | 32:22.50 | 5:26.20 | 145700 | 170169
11 | 37:48.70 | 3:07.13 | 170170 | 184207
Range status and errors
Selected range
Filename F:\Yello\1985 - Stella (1985 - Mercury. USA - 822 820-2)\Yello - Stella.wav
Peak level 89.6 %
Extraction speed 6.6 X
Range quality 100.0 %
Test CRC AEFA142C
Copy CRC AEFA142C
Copy OK
No errors occurred
AccurateRip summary
Track 1 accurately ripped (confidence 22) [BDA52F83] (AR v2)
Track 2 accurately ripped (confidence 23) [0AAABB66] (AR v2)
Track 3 accurately ripped (confidence 23) [60211402] (AR v2)
Track 4 accurately ripped (confidence 23) [B4016C71] (AR v2)
Track 5 accurately ripped (confidence 23) [D5451AD3] (AR v2)
Track 6 accurately ripped (confidence 23) [79F5CA25] (AR v2)
Track 7 accurately ripped (confidence 23) [803B071F] (AR v2)
Track 8 accurately ripped (confidence 23) [97066A5D] (AR v2)
Track 9 accurately ripped (confidence 22) [0C50B264] (AR v2)
Track 10 accurately ripped (confidence 23) [6B70F0B3] (AR v2)
Track 11 accurately ripped (confidence 23) [87948FC5] (AR v2)
All tracks accurately ripped
End of status report
---- CUETools DB Plugin V2.1.5
[CTDB TOCID: FKnKjNFizYphVC3X38DAgyuOW3I-] found
Submit result: FKnKjNFizYphVC3X38DAgyuOW3I- has been confirmed
Track | CTDB Status
1 | (3/4) Accurately ripped
2 | (4/4) Accurately ripped
3 | (4/4) Accurately ripped
4 | (4/4) Accurately ripped
5 | (4/4) Accurately ripped
6 | (4/4) Accurately ripped
7 | (4/4) Accurately ripped
8 | (4/4) Accurately ripped
9 | (4/4) Accurately ripped
10 | (4/4) Accurately ripped
11 | (4/4) Accurately ripped
==== Log checksum 4EE5037A3A120A58966321C8900DFAFA3E0D5DA5170442157EE8D6F12F702357 ====
Yello / Stella
Read mode : Secure
Quality : High
Add ID3 tag : No
Selected range
Peak level 89.6 %
Test CRC AEFA142C
Copy CRC AEFA142C
Copy OK
No errors occurred
AccurateRip summary
Track | CTDB Status
Скрыть
Спасибо оригинальному релизеру!
Yello - Stella (non remaster)
Сообщение отредактировал NKF: 16 Май 2019 - 22:20
