VirtualDub
Andry[by]
, 06 янв 2006 12:34
Сообщений в теме: 12
Отправлено 06 Январь 2006 - 12:34
Выложена новая стабильная версия одной из самых ценных утилит для обработки видео от Avery Lee:
Features of VirtualDub 1.6.12 :
Sure, you've probably played a few video clips on your monitor. But have you ever made one yourself? Used a video capture device? Wrestled with the software that comes with it? Felt like the software is a few leagues above or below your level? Time to try something else.
• VirtualDub helps you get video into your computer.
If your capture device is Video for Windows compatible, then VirtualDub can capture video with it. But VirtualDub isn't your average capture program:
- Fractional frame rates. Don't settle for 29 or 30 when you want 29.97.
- Optimized disk access for more consistent hard disk usage.
- Create AVI2 (OpenDML) files to break the AVI 2GB barrier and multiple files to break the FAT32 4GB limit.
- Integrated volume meter and histogram for input level monitoring.
- Real-time downsizing, noise reduction, and field swapping.
- Verbose monitoring, including compression levels, CPU usage, and free disk space.
- Access hidden video formats your capture card may support but not have a setting for, such as 352x480.
- Keyboard and mouse shortcuts for faster operation. To capture, just hit F6.
- Clean interface layout: caption, menu bar, info panel, status bar.
• VirtualDub lets you clean up video on your computer.
There are lots of programs that let you "edit" video. And yet, they're frustratingly complex for some of the simplest tasks. VirtualDub isn't an editor application; it's a pre- and post-processor that works as a valuable companion to one:
- Reads and writes AVI2 (OpenDML) and multi-segment AVI clips.
- Integrated MPEG-1 and Motion-JPEG decoders.
- Remove and replace audio tracks without touching the video.
- Extensive video filter set, including blur, sharpen, emboss, smooth, 3x3 convolution, flip, resize rotate, brightness/contrast, levels, deinterlace, and threshold.
- Bilinear and bicubic resampling -- no blocky resizes or rotates here.
- Decompress and recompress both audio and video.
- Remove segments of a video clip and save the rest, without recompressing.
- Adjust frame rate, decimate frames, and 3:2 pulldown removal.
- Preview the results, with live audio.
You can take a captured clip, trim the ends, clean up some of the noise, convert it to the proper frame size, and write out a better one. Don't see a video filter you want? Write your own, with the filter SDK.
• VirtualDub is fast.
The author of VirtualDub is very impatient. That means his program is designed for speed, both in the interface and in the processing pipeline. Converting a compressed, 320x240 MPEG-1 file to an uncompressed, 24-bit AVI requires only these two steps in VirtualDub:
- Open video file (Ctrl-O).
- Save AVI (F7).
How fast is this operation? On a C450, 40 frames per second (1.3x real-time speed). With a little tweaking, the speed rises to 55 fps (1.8x), with the CPU hardly breaking a sweat at 40%.
• VirtualDub is cheap.
To be exact, it costs nothing. VirtualDub is licensed under the GNU General Public License, meaning you can use it for free. No risk involved, and the whole source code is available if you want it.
Changes from VirtualDub 1.6.11 to VirtualDub 1.6.12 :
• Build 24259 (1.6.12, stable): [January 4, 2006]
• Features added:
- Performance settings are now auto-saved.
- Cropping dialogs now auto-scale video that is too large to display and use a dashed crop border for better visibility.
- Added /cmd flag to quickly invoke a script command from the command-line.
- There is now an option to avoid tearing in the video display panes.
- Script: Added VirtualDub.Exit(int) command to end the program with a specific error code.
- Script: Added VirtualDub.subset.length property for current length of subset in frames (timeline).
- Script: Added VirtualDub.video.length property for current length of source video in frames.
- Capture: The list of statistics displayed in the info panel has been expanded and can be filtered from the Preferences dialog.
- Capture: Modified option to adjust video timing based on drift from ideal stream timing rather than real-time.
- Capture: Reworked video timing interpolation to be less sensitive to discontinuities in the system timer.
- Capture: "Autoincrement filename" option now automatically skips over existing files as well.
- Capture: Added timing graph to visualize behavior of resync engine.
- Capture: Timing logs, if enabled, are automatically saved at the end of capture.
- Capture: Increased precision of frame period selection from 1us to 100ns to reduce frame dropping at device level when using DirectShow drivers.
- Capture: Capture from DV sources to type-2 DV AVI using the DirectShow DV driver is now supported.
• Bugs fixed:
- Increased precision of processing fps estimate.
- "Space" is no longer listed as an accelerator for "abort dub" since it doesn't work as such when rendering to disk. It still works for preview.
- Fixed job control re-enabling itself if a menu command is chosen while a job is running, leading to possible reentrancy crashes.
VirtualDub 1.6.12 Stable
VirtualDub 1.6.12 Stable for AMD64
- Save AVI (F7).
• Features added:
• Bugs fixed:
Отправлено 07 Ноябрь 2006 - 14:34
VirtualDub 1.7.0
Вышла новая версия отличной программы для обработки видео VirtualDub. Данный видео-редактор ориентирован на работу с видео в формате AVI. Не является профессиональным (обратите внимание на размер программы), но для простых действий над видео-роликами вполне сгодится. Имеет GPL-лицензию, то есть распространяется даром, в том числе и в виде открытых исходных кодов.
Скачать (1.19 MB - Open Source)
Скачать для x64 (1.3 MB - Open Source)
Список изменений:
Features added:
- New "smart rendering" feature for selective processing of video around edit areas while copying as many existing frames as possible.
- New audio waveform/spectrogram display.
- Added option for preserving empty frames during recompression or decompression instead of replicating frames.
- Added option for saving raw audio stream without a header.
- Added support for the Sony WAVE64 file format, for wave files larger than 4GB.
- Added support for reading and writing Adobe Filmstrip (.flm) files.
- Added support for reading Maya IFF (.iff) files. Currently this is limited to RGB information at 8 bits/channel.
- PNG output is now supported.
- Resize video filter now has options for relative and aspect-ratio derived sizing and to save defaults.
- Opening a video file from the command-line or drag-and-drop now sets the filename as default for the Save As AVI/WAV dialogs.
- Added new pitch scaling audio filter.
- Improved quality of "center cut" audio filter (with suggestions from Moitah).
- The main window and job control dialogs now save their positions.
- Opacity curves can now be attached to video filter instances.
- Volume adjustment now shows amplification factor in decibels.
- Filter API: Preview code preserves keyboard accelerators on preview button.
- Job control: (X of Y) is now displayed in the job control window caption when the job list is being processed.
- AVI Info now shows additional information for PCM audio streams encoded using WAVE_FORMAT_EXTENSIBLE.
- Capture: Added experimental option to insert arbitrary DirectShow transform filters into a capture graph. To enable, specify the filter moniker in [HKCU\Software\Freeware\VirtualDub\Hidden Features\CapDShow: Transform filter name] in the Registry.
- Capture: Added full-screen toggle (Alt+Enter).
- Capture: Added support for switching DirectShow TV tuners between antenna and cable modes.
Features removed:
- The "integral conversion" option under audio conversion is no longer supported.
Bugs fixed:
- Fixed a case where the projected file size status indicator could overflow for very long audio dumps.
- AVIs with MP3 audio streams where wBitsPerSample != 0 are now detected and auto-corrected for better compatibility with the standard MP3 codec installed in Windows.
- Rewrote segmentation code to buffer data instead of attempting size prediction; this makes the segmentation more accurate and avoids dangling key frames during on-the-fly compression.
- Added workaround for compatibility problems with Aero Glass in Windows Vista beta 2.
- Audio displacement now works when processing only part of the audio stream.
- Added warning for non-zero dwStart values in AVI files.
- Fixed a performance problem in the PNG decoder on large images with a lot of IHDR blocks.
- Fixed errors in JPEG encoding with pure red or blue colors.
- Changed keyboard shortcut for Undo from Ctrl+U to the standard Ctrl+Z.
- Added workaround for annoying Microsoft security update that sometimes prevents the help file from working.
- Fixed clamping in amplifier that caused -0x8000 values to change to -0x7FFF.
- Capture: Duplicate raw wave formats are no longer shown with DirectShow-based drivers.
- Capture: The UI now reflects changes to audio and video sources made through the driver dialogs.
- Capture: Possible fix for crash when changing formats with DirectShow- based devices due to threading issue.
© SLO.ru
Список изменений:
Features added:
Features removed:
Bugs fixed:
© SLO.ru
Отправлено 13 Ноябрь 2006 - 21:03
Штука не стабильная. Вылетает в самых неожиданных местах. Пишет о рантайме и все усилия на смарку. Не советую.
Отправлено 08 Февраль 2007 - 11:41
Changes in VirtualDub 1.6.17 and VirtualDub 1.7 :
• Build 24469 (1.6.17, stable): [November 4, 2006]
• Bugs fixed:
- Fixed divide by zero crash when Direct3D display is enabled and a video pane is shrunken to zero width.
- UYVY video streams were being reported as RGB16.
- Direct3D display minidriver didn't clip properly when the image was zoomed larger than the screen.
• Regressions fixed:
- Capture: Reverted change in rendering strategy for DirectShow filter graphs in order to fix field problems with ATI devices.
- Capture: Fixed crash when capturing video only using a VFW driver.
• Build 25854 (1.7.0, experimental): [November 5, 2006]
• Features added:
- Capture: Added experimental option to insert arbitrary DirectShow transform filters into a capture graph. To enable, specify the filter moniker in [HKCUSoftwareFreewareVirtualDubHidden FeaturesCapDShow: Transform filter name] in the Registry.
• Features removed:
• Bugs fixed:
- Capture: Possible fix for crash when changing formats with DirectShow-based devices due to threading issue.
VirtualDub 1.7.1 - Experimental
VirtualDub 1.7.1 for AMD - Experimental
• Bugs fixed:
• Features added:
• Features removed:
• Bugs fixed:
Отправлено 15 Февраль 2007 - 17:42
Попробовал VirtualDub 1.7.1 English - понравилось. Добавилось несколько функций, стала "умней". Работает стабильно. Советую.
#7 Гость_GlaDooo_*
Отправлено 13 Сентябрь 2007 - 18:35
Отправлено 27 Сентябрь 2007 - 22:05
VirtualDub 1.7.4 почему-то плохо держит фрейм рейт (Frame Rate) при перекодировании массы клипов. :(
ЗЫ. Извиняюсь, был внутренний глюк. После решения\исправления баг не наблюдается.
Сообщение отредактировал AlexStorm: 06 Октябрь 2007 - 21:09
Отправлено 10 Декабрь 2007 - 10:45
VirtualDub 1.7.7
Changes from VirtualDub 1.7.6 to VirtualDub 1.7.7 :
VirtualDub 1.7.7 | VirtualDub 1.7.7 - 64-bit (AMD64)
• Build 28312 (1.7.7, stable): [December 9, 2007]
• [bugs fixed]
- Improved accuracy of "set so audio and video durations match" for short clips.
- Fixed vertical chroma positioning errors when converting to 4:2:0 or 4:1:0 YCbCr.
- PluginSDK: Direct stream copy from a plugin audio stream caused dwStreamSize in the AVI to be set incorrectly.
- PluginSDK: Fixed crash when using plugin to load a file with an audio stream that isn't AVI compatible.
- Capture: When "wait for OK" was enabled with a DirectShow driver, time spent in the dialog was counted against a time stop condition.
- Capture: Fixed crash when an error occurs while starting capture with a custom hotkey.
• [regressions fixed]
- "Save segmented AVI" no longer crashes when only video is enabled.
- Prohibit zero for frame rate adjustment.
- Filters: The error return from runProc is ignored again for compatibility with earlier versions of VirtualDub; this fixes some video filters that broke in the 1.7.x series.
- D3D: Fixed a display change related crash.
• [bugs fixed]
Отправлено 05 Февраль 2018 - 20:03
VirtualDub2 41493 (Rus)
- открывает разные виды файлов (благодаря плагину caching input driver)
- умеет сохранять в форматах MKV, MP4, MOV и др.;
- в комплекте идут кодеки x264, Huffyuv, FFV1, Apple ProRes, AAC и MP3
- поддерживает работу с цветом высокой битности (10 bit)
https://yadi.sk/d/ZF2lTa1v3TxG88 (01.04.2018)
Отправлено 02 Апрель 2018 - 10:15
Перезалита новая версия: 41552En + Добавлен русский эксешник 41493.
Наконец-то исправлена ошибка совмещения звука при кодировании кодером x264.
У меня Win7-64. Если из "VirtualDub2" запустить 64-битное приложение, то файлы открываются без проблем.
Если запустить 32-битное приложение (пофиг ru или en), то то при открытии некоторых файлов возникает ошибка.
Но! Если в mkvtoolnix поставить галку "исправить информацию о битовом потоке", то в 32-битных приложениях ошибок уже не возникает!
