Скрытый текстТех. инфо
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 15mn
Nominal bit rate : 3 110 Kbps
Width : 864 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.250
Title : Seventh Wonder = Welcome To Atlanta Live-2014
Writing library : x264 core 129 r2245+729M 1a52e03
Encoding settings : cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.50 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=29 / scenecut=40 / intra_refresh=0 / rc_lookahead=90 / rc=2pass / mbtree=1 / bitrate=3110 / ratetol=10.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Matrix coefficients : BT.601
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 2h 15mn
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Title : Flac (Stereo)
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:A New Beginning
00:02:57.833 : en:There And Back
00:06:04.799 : en:Welcome To Mercy Falls
00:11:47.932 : en:Unbreakable
00:19:25.998 : en:Tears For A Father
00:21:49.931 : en:A Day Away
00:25:56.831 : en:Tears For A Son
00:27:47.097 : en:Paradise
00:34:01.030 : en:Fall In Line
00:39:57.796 : en:Break The Silence
00:49:41.862 : en:Hide And Seek
00:57:56.062 : en:Destiny Calls
01:04:35.995 : en:One Last Goodbye
01:09:43.795 : en:Back In Time
01:10:47.928 : en:The Black Parade
01:23:23.994 : en:Inner Enemy
01:26:57.179 : en:Taint The Sky
01:34:05.212 : en:Banish The Wicked
01:40:27.212 : en:Alley Cat
01:47:34.012 : en:Walking Tall
01:52:29.212 : en:The Edge Of My Blade
01:59:41.012 : en:King Of Whitewater
02:08:08.178 : en:Seventh Wonder Odyssey
Format : AVC
Duration : 2h 15mn
Width : 864 pixels
Height : 480 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 2h 15mn
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Menu
Скрыть
