Emule 0.46а
Сообщений в теме: 21
#1 OFFLINE   Prandr
    I LISTEN TO HARD'N'HEAVY
    25 Дек 2010 11:45
Отправлено 05 Май 2005 - 16:16
Bugfixes:
# fixed removing servers from static list from the webinterface
# Fixed a socket resource leak in web interface.
# Fixed a bug which sometimes caused a sharing Violation in known2.met when starting eMule
# Fixed: Queue Ranking of sources in Download Listview were not always updated properly.
# Added some missing protocol overhead stats.
# Fixed a bug which made it theortical in some rare cases possible that eMule sent unverified data to other clients
# fixed not working commands on downloadlist multiselections in certain cases
# Fixed bug with file comments/ratings when receiving a rating without a comment [thx MogTheCat]
# Fixed bug with eD2k link parsing when no filename (or filename with just spaces) was specified in link.
# Fixed bug with partfile renaming when new filename contains only spaces.
# Fixed bug in keyword publishing related to filenames ending with too much unpublished characters.
# Fixed some GUI glitches in Friend listview.
# Fixed bug which prevented eMule to minimize to system tray.
# Fixed bug with log messages which were not written to log files during early startup.
# MiniMule shows accurate connection icon.
# MiniMule - fixed problem with eMule installation path containing some special characters.
# Fixed bug in log panes which could create auto-endless up-scrolling.
# Fixed bug in log panes which displayed text too far on top if pane was first time enabled.
# Fixed bug with not adding all available source found during searching when adding a file via an sub-entry to the download queue.
# Fixed wrong file statistics of (previously) stopped files [Xman]
# Fixed bug with too high PeerCache socket timeouts [thx so8so]
# Small fix to USS to prevent it from sometimes disabling itself when network connection is lost. Once the first init of USS is complete it should now never disable itself.
# Fixed issue where bugged compatible clients could receive sources for a file they did not ask for.
# Fixed bug with Kad-notes which were received but not stored.
# Fixed 'Transferred' column data display and sorting in Upload list control.
# Fixed comment rating label order.
# Fixed possible misplaced up/down buttons in details dialog.
Changes:
# Added eMail-Notification settings to the GUI, optional encryption still needs to be configured in the preferences.ini
# Added the setting for alternate toolbar layout in the transferwindow into the preferences dialog
# Access to web interface can be restricted to a list of specified IP addresses. preferences.ini setting 'AllowedIPs=[;]' section '[WebServer]'
# Renamed 'adresses.dat' to 'addresses.dat' for automatic serverlist updates on startup. Renaming will be done automatically during startup on this upgrade.
# Remembering downloaded files can be disabled and eMule will purge all unneeded records from known.met and known2.met
# Implemented protocol change for server for getsources (local/udp) suggested by lugdunum
# Couple very small gui changes to the setup wizard and file comment list.
# Merged the view selector and the downloadingclients view from Mods [TBH]
# added manual filename cleanup on selected files in the downloadlist by pressing Ctrl+F2
# To reduce overal network overhead, dead servers are detected faster and not used for UDP sources and file searches until they are deleted.
# The priority specified in downloaded server.met files is ignored. Server priorities can still be used for the local server list.
# Sortorder and scrollposition are now saved for every open searchresult when switching between them
# Source base is compiled with warning level 4 (and corrected)
# Kad keyword searching and publishing of short words changed to circumvent some limitations for Asian phrases.
# Brushed up Shared Folders context menu in Options/Files.
# Changed all sound creating functions to not use the PC-speaker in case there is no sound card available.
# Log files clearly show session start/end messages.
# MiniMule shows the nr. of completed downloads currently available in Download list.
# MiniMule can be properly attached to each edge of the desktop window (depending on taskbar position).
# Added optional Text-To-Speech notification. For each generated notification eMule will 'read' the log message in the system's default Text-To-Speech engine.
# Added support GZip compressed IP-filter files.
# Disabled extracting of MetaData with DirectShow - until a more reliable way is implemented.
# Experimental: Added a more efficient method to reject TCP connections of filtered and/or banned clients; see Options/Ext. settings
# All graphs in Statistics window have a different appearance when 'StraightWindowStyles=1' is specified in Preferences.ini, section [emule].
# Couple of optimizations in drawing the statistics graphs.
# When closing the Options dialog, the preferences.ini file is saved only if really needed.
# Searchresult panes: When switching to/from panes with collapsed search entries, the state is properly saved/restored.
# Couple of optimizations in search result handling.
# When receiving different file names for a search result, the filename with the highest availability is eventually used for showing the result
# In ext. user mode only: Search results show nr. of complete sources by percent and accurate number.
# Filename cleanup: dont uppercase character behind apostrophe
# Set file based sources limit via downloadlist context menu (when extended controls enabled)
# moving mouse over statisticgraphs and holding down left mousebutton will display a tooltip containing the corresponding date and time at the current mouseposition in the graph (calculated by the CURRENT statistic settings)
# Reworked all dialogs to properly show the '&' characters in filenames.
# Upgraded to zlib 1.2.2.
# Experimental: Added Right-to-Left reading support. Enable in Preferencs.ini: Section=[eMule]; Setting=RTLWindowsLayout=
Features:
# eMule now (optional) remembers files which were cancelled and marks them in the searchresults
# Added new drop down buttons in Transfers window to select different view types for main and sub window.
# Added support for new PeerGuardian IP filter file format v2.
# Added E-Mail notification for 'Download finished' and 'Important Error' eMule notifications.
# merged webinterface from eMule+, adapted, did some fixes and added: Kad-window, show comments & ratings download of completed files via browser (up to 5MB filesize)
#2 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 05 Май 2005 - 17:00
ооо супер, спасибо за хорошую новость. Как раз сегодня вечером заходил, там еще старая была..а к ночи новую выложили...будем читать в офиц форуме мула о новвоведениях  :yahoo:
#3 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 05 Май 2005 - 17:13
хоть исправлений куча, но самые необычные..отправка писем на ваш майл при окончании загрузки и что мул голосом читает уведомления.
Added optional Text-To-Speech notification. For each generated notification eMule will "read" the log message in the system's default Text-To-Speech engine.
#4 OFFLINE   Prandr
    25 Дек 2010 11:45
Отправлено 05 Май 2005 - 17:30
Вот преимущество, когда на форуме в модераторах официальный перводчик мула. :D
Ты скажи когда наконец к мулу будет прилагаться русский хелп???
Сообщение отредактировал AndrPro: 05 Май 2005 - 17:31
#5 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 06 Май 2005 - 16:21
ну так я не знаю :) я Вячеславу( который интерфейс мула переводил) дал на ознакомление перевод и пока от него молчок, а времени заливать его на сервак емуле проджект пока нету...working hard :)
#6 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 07 Май 2005 - 03:36
Вот что нашел на форуме официального мула в теме о новом емуле.
Edit:
Note: If you have used certain mods before using this version eMule may read values which those mods stored in the part.met files and interprets them as the new sourcelimit. Be sure to reset those limits on all files in this case:
Activate the "show more controls" in extended settings. Then right-click a download, go to Source Handling, select "Source Limit..." and set it to 0.
Новый мул может неверно истолковать настройки от старых модов и принимает их за ограничение кол-ва источников. Включите  Доп. контроль. в настройках-другие настройки. Затем правая кнопка на закачиваемом файле-управление источниками, выберите "Лимит источников..." и поставьте на 0.
Так что те кто юзал моды до установки нового мула..прошу последовать данной рекомендации от Ornis
Также для обладателей win9x:
Microsoft Layer for Unicode on Windows 95/98/ME Systems (MSLU) version 1.0 Эта ссылка поможет вам с Юникодом в емуле.
#7 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 07 Май 2005 - 03:37
кстати одобрение на хелп получено, так что впринципе можно будет его заливать на сайт мула..может быть с следующей версией он выйдет вместе с мулом.
#8 OFFLINE   Prandr
    25 Дек 2010 11:45
Отправлено 09 Май 2005 - 09:09
Ну как новый мул? У меня он сосёт так, что лдумаешь не стал ли лн личерским:  :yahoo: на 7 файлах разогнался до 66 кбайт/с. Правда разгоняется медленне обычного.
#9 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 09 Май 2005 - 10:19
я не тестил, пока что сижу на морфе. Когда включат в офиц мула хотя бы powershare и hideOS я перейду на офиц мула..хотя потестю обязательно
#10 Гость_pavel_*
Отправлено 13 Май 2005 - 10:44
странный он какойто етот мул 1) разгоняется очень быстро(вклучу уже через минуту качает во всю) 2)скорость зашкаливает (с моим доунлодом в 100 все 80 качает почти постоянно) 3) юзеры стали болше отдовать(раньше 9-10 мб дадут и отклучаются а ща дают скоко влезит конечно не все )С одной стороны рад  :yahoo:  а с другой както настараживает  :(
#11 Гость_pavel_*
Отправлено 13 Май 2005 - 11:06
AndrPro (May 9 2005, 16:09) писал:
я тоже!!!
#12 OFFLINE   Prandr
Отправлено 13 Май 2005 - 11:44
А я разочаровался. Сосал он только файлы с большим кол-вом источников. Как их немного поменьше стало  ползёт как улитка.
#13 Гость_Void()_*
Отправлено 13 Май 2005 - 12:30
Я тоже поставил себе, но у меня за 10 часов не скачал ни байта! До этого Plus стоял. Я думал это что-то с новым мулом. Оказалось это файрвол мой.
:offtopic2:
У меня Аутпост временами блокирует весь входящий траффик. Независимо от правил. Просто отрубает и все!
#14 OFFLINE   Gadget
Отправлено 13 Май 2005 - 17:05
ну агнитум такой...такой...короче кака. Даже если ставишь чтобы пропускал весь входящий и исходящий траффик в оба конца для мула, он все равно блокирует некоторые соединения с приложения:емул...короче отстойный файрвол. Плюс еще вписывает пару прог как доверенные,  как раз этим и пользуются хакеры...они маскируют свой троян под какую то прогу, которую файрвол по умолчанию ставит статус Доверенное приложение, и троян спокойно выходит в инет
#15 OFFLINE   Prandr
    25 Дек 2010 11:45
Отправлено 13 Май 2005 - 17:08
Ну у меня с ним мул работает
#16 Гость_Void()_*
Отправлено 13 Май 2005 - 18:16
Да я теперь его отрубаю когда eMule пашет. А он у меня круглые сутки работаетИзображение
#17 OFFLINE   digitalriver
Отправлено 17 Май 2005 - 16:10
Я тоже задам свой ламерский вопрос. У меня он тоже качает раз в 100 медленнее,чем предыдущая версия. Стен нет никаких, Hi Id имеется, всё как позвчера, а не качает два дня нифига. Есть предложения может у кого?
#18 OFFLINE   Gadget
    12 Мар 2018 01:57
Отправлено 18 Май 2005 - 09:46
конечно есть..возращайся на ТУ версию, что качала хорошо.
Уже давно говорили, что к каждому компу-свой мул.
#19 OFFLINE   digitalriver
    25 Дек 2010 11:45
Отправлено 18 Май 2005 - 13:25
Такой кардинальный вариант. :)))
Но тогда я никогда не узнаю, почему же так происходит. Ну да ладно. Всё равно спасибо.
#20 OFFLINE   serio
Отправлено 18 Май 2005 - 14:39
Сранно! У меня новоя версия скал в припрыжку!! А вот морф который щас стоит немного тормозит... Хотя полезных прибамбасов больше...
Ослы, одним словом.
