Exact Audio Copy V1.0 beta 1 from 15. November 2010
EAC extraction logfile from 28. October 2011, 23:28
Unison / Unison
Used drive : PIONEER DVD-RW DVR-215D Adapter: 0 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 48
Selected bitrate : 128 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\Flac\flac.exe
Additional command line options : -8 -V %s
TOC of the extracted CD
1 | 0:00.00 | 3:18.10 | 0 | 14859
2 | 3:18.10 | 3:10.01 | 14860 | 29110
3 | 6:28.11 | 3:45.40 | 29111 | 46025
4 | 10:13.51 | 3:17.29 | 46026 | 60829
5 | 13:31.05 | 4:34.55 | 60830 | 81434
6 | 18:05.60 | 4:48.29 | 81435 | 103063
7 | 22:54.14 | 4:10.02 | 103064 | 121815
8 | 27:04.16 | 7:33.54 | 121816 | 155844
Range status and errors
Selected range
Filename C:\Program Files\Exact Audio Copy\Flac\Unison - Unison.wav
Peak level 99.3 %
Extraction speed 1.1 X
Range quality 100.0 %
Test CRC DFAB69E1
Copy CRC DFAB69E1
Copy OK
No errors occurred
AccurateRip summary
Track 1 cannot be verified as accurate (confidence 1) [EC367136], AccurateRip returned [EE4E60DA]
Track 2 cannot be verified as accurate (confidence 1) [FCCEEE03], AccurateRip returned [3D0D9A9B]
Track 3 cannot be verified as accurate (confidence 1) [3CF8E7CB], AccurateRip returned [89E7BEE3]
Track 4 cannot be verified as accurate (confidence 1) [301F37F0], AccurateRip returned [7234B9F0]
Track 5 cannot be verified as accurate (confidence 1) [03365373], AccurateRip returned [B0110FDB]
Track 6 cannot be verified as accurate (confidence 1) [47589EB3], AccurateRip returned [5C4BA558]
Track 7 cannot be verified as accurate (confidence 1) [A43C8A6E], AccurateRip returned [0B5D8B29]
Track 8 cannot be verified as accurate (confidence 1) [5A4159F5], AccurateRip returned [43D36073]
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
End of status report
Скрыть
