Скрытый текстТех. инфо
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 1mn
Width : 1 024 pixels
Height : 464 pixels
Display aspect ratio : 2.2:1
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Title : RPWL-A New Dawn-2017
Writing library : x264 core 129 r2245+729M 1a52e03
Encoding settings : cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.50 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Duration : 2h 1mn
Bit rate mode : Variable
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Title : Flac (Stereo)
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Prologue
00:02:13.880 : en:Revelation
00:06:34.560 : en:Introduction
00:08:47.040 : en:Oh Hapless Man
00:11:10.080 : en:Swords And Guns
00:21:09.600 : en:This Ancient Formula
00:23:37.440 : en:A Clear Cut Line
00:27:52.800 : en:Wanted
00:32:48.480 : en:Like To Like
00:34:57.120 : en:The Fisherman
00:53:23.520 : en:Sound Of Loneliness
00:55:11.040 : en:Hide And Seek
01:01:15.360 : en:From Paul To Saul
01:02:10.560 : en:Disbelief
01:08:19.680 : en:Misguided Thought
01:15:37.440 : en:Still Asleep
01:23:24.960 : en:Home Shopping
01:26:00.000 : en:Perfect Day
01:32:31.200 : en:Terror
01:33:42.240 : en:The Attack
01:44:12.000 : en:The Eternal Recurrence
01:45:45.600 : en:A New Dawn
01:52:23.040 : en:Revelation Reprise
Format : AVC
Duration : 2h 1mn
Height : 464 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 2h 1mn
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Menu
Скрыть
RPWL = TheManAndTheJourney-2016(Flac).mkv
Video
Format : AVC
Duration : 1h 19mn
Nominal bit rate : 4 425 Kbps
Height : 576 pixels
Display aspect ratio : 16:9
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.300
Title : RPWL = The Man And The Journey - 2016
Encoding settings : cabac=1 / ref=6 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.50 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=75 / rc=2pass / mbtree=1 / bitrate=4425 / ratetol=10.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 1h 19mn
Bit depth : 16 bits
Title : Flac(Stereo)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Part I: The Man
00:00:46.080 : en:Daybreak - Pt. I
00:08:53.760 : en:Work
00:13:16.320 : en:Afternoon
00:18:33.120 : en:Doing It
00:22:16.320 : en:Sleep
00:25:48.480 : en:Nightmare
00:36:22.560 : en:Daybreak - Pt. II
00:36:57.120 : en:Part II: The Journey
00:36:57.140 : en:The Beginning
00:40:53.760 : en:Beset By Creatures Of The Deep
00:48:25.920 : en:Narrow Way
00:54:18.240 : en:Pink Jungle
01:01:02.400 : en:Labyrinths Of Auximines
01:07:39.840 : en:Behold The Temple Of Light
01:12:25.920 : en:End Of The Beginning
01:18:21.000 : en:Credits
Format : AVC
Duration : 1h 19mn
Height : 576 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 1h 19mn
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Menu
Скрыть
RPWL = AShowBeyondManAndTime-2013(Flac).mkv
http://kinozal.tv/de....php?id=1580481
Video
Format : AVC
Duration : 1h 36mn
Nominal bit rate : 3 000 Kbps
Width : 864 pixels
Height : 480 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.302
Title : RPWL = A Show Beyond Man And Time-2013
Encoding settings : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.50 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=72 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=10.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 1h 36mn
Bit depth : 16 bits
Title : 16/48 (Stereo) CD
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Transformed
00:03:04.000 : en:We Are What We Are (The Keeper)
00:13:34.433 : en:Beyond Man And Time (The Blind)
00:20:18.299 : en:Unchain The Earth (The Scientist)
00:27:38.865 : en:The Ugliest man (The Ugly)
00:36:38.098 : en:The Road Of Creation (The Creator)
00:42:43.331 : en:Somewhere In Between (The Dream Of Saying Yes)
00:52:14.731 : en:The Shadow
00:58:44.897 : en:The Wise In The Desert
01:05:13.497 : en:The Fisherman
01:22:41.530 : en:The Noon
01:28:46.296 : en:Roses (With Ray Wilson)
Format : AVC
Duration : 1h 36mn
Width : 864 pixels
Height : 480 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 1h 36mn
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Menu
Скрыть
RPWL = TheRPWLLiveExperience-2009(Flac).mkv
http://kinozal.tv/de....php?id=1580474
Video
Format : AVC
Duration : 1h 36mn
Nominal bit rate : 2 780 Kbps
Width : 832 pixels
Height : 464 pixels
Color space : YUV
Bit depth : 8 bits
Title : RPWL = The RPWL Live Experience - 2009
Encoding settings : cabac=1 / ref=6 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.50 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=72 / rc=2pass / mbtree=1 / bitrate=2780 / ratetol=10.0 / qcomp=0.70 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 1h 36mn
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Hole In The Sky
00:07:40.833 : en:Breathe In, Breathe Out
00:11:37.133 : en:3 Lights
00:21:03.466 : en:Start The Fire
00:25:48.999 : en:Silenced
00:35:59.965 : en:This Is Not A Prog Song
00:42:59.865 : en:Sleep
00:52:35.831 : en:Opel
00:58:59.897 : en:Waiting For A Smile
01:06:17.897 : en:Trying To Kiss The Sun
01:11:25.730 : en:Wasted Land
01:17:22.930 : en:Roses
01:25:00.196 : en:Biding My Time
01:30:09.396 : en:I Don't Know
Format : AVC
Duration : 1h 36mn
Width : 832 pixels
Height : 464 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : FLAC
Codec ID : A_FLAC
Duration : 1h 36mn
Bit depth : 16 bits
Language : English
Default : Yes
Forced : No
Menu
Скрыть
Сообщение отредактировал Fother2: 13 Декабрь 2017 - 20:04
