Exact Audio Copy V0.99 prebeta 5 from 4. May 2009
EAC extraction logfile from 6. November 2010, 23:32
Jazz-Quintet / Barometer
Used drive : TSSTcorpCDDVDW SH-S223F Adapter: 3 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Selected bitrate : 1024 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\Exact Audio Copy\wavpack.exe
Additional command line options : -hlm %s
TOC of the extracted CD
1 | 0:00.00 | 4:54.58 | 0 | 22107
2 | 4:54.58 | 7:50.66 | 22108 | 57423
3 | 12:45.49 | 8:08.49 | 57424 | 94072
4 | 20:54.23 | 8:29.01 | 94073 | 132248
5 | 29:23.24 | 9:35.70 | 132249 | 175443
Range status and errors
Selected range
Filename E:\temp\Misic\Jazz-Quintet - Barometer\Jazz-Quintet - Barometer.wav
Peak level 100.0 %
Range quality 100.0 %
Test CRC 41E7094F
Copy CRC 41E7094F
Copy OK
No errors occurred
AccurateRip summary
Track 1 not present in database
Track 2 not present in database
Track 3 not present in database
None of the tracks are present in the AccurateRip database
End of status report
Скрыть
