Gardening
rusflorida
, 19 фев 2008 19:59
Сообщений в теме: 16
Отправлено 19 Февраль 2008 - 19:59
Care Of The Vegetable Garden.
A productive garden requires considerable attention
and care. Insects, diseases and weeds must be controlled;
water and nutrients must be supplied; plants must be supported;
and harvests must be made at the proper time for
best fl avor, yield and nutritional quality. This factsheet discusses
these practices.
Формат: pdf
Страниц: 4
ослолинк
these practices.
Формат: pdf
Страниц: 4
ослолинк
Отправлено 19 Февраль 2008 - 20:11
Vegetable Gardening Encyclopedia
Any gardener will tell you that gardening is one
of the most absorbing and rewarding
occupations you can undertake. Any gardener will
also tell you — probably loudly and at length — that
gardening requires patience, resilience, hard work,
and a lot of planning. Paperwork is probably the last
thing you have in mind when you think about
growing your own vegetables. More likely you see
yourself leaning contently on your spade as all sorts
of lush, healthy plants shoot up in front of your eyes.
The fact of the matter, though, is that gardening
begins not with seeds and a spade but with paper and a
pencil.
A successful vegetable garden begins with a wellorganized
plan of your garden space. Drawing a plan
may not sound as exciting as getting outdoors and
planting things. But if you don't spend the necessary
time planning what to grow in your garden and
when and where to plant it, you may spend the rest of
the growing season correcting the mistakes you
made because you didn't have a plan. It's a lot easier to
erase a bed when it's a few lines on a piece of paper
than when it's an expanse of soil and plants.
Your plan should include not only the types and
quantities of vegetables you're going to grow and how
they'll be positioned in your garden, but also
planting dates and approximate dates of harvest.
Making a plan may seem like a lot of work to get
done before you even start gardening, but careful
planning will help you make the best use of your
time and available space and will result in bigger,
higher-quality crops.
Кол-во страниц: 261
Формат: PDF
Размер файла: 13,53 МВ
ослолинк
pencil.
Кол-во страниц: 261
Формат: PDF
ослолинк
