EAC extraction logfile from 23. September 2012, 18:21
Henrik Freischlader Band / House In The Woods
Used drive : HL-DT-STDVD-RAM GH22LP20 Adapter: 4 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 102
Used interface : Installed external ASPI interface
Selected bitrate : 896 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files (x86)\Exact Audio Copy\WAV Pack\wavpack.exe
Additional command line options : -hlmx2 %source% %dest%
TOC of the extracted CD
1 | 0:00.00 | 3:54.48 | 0 | 17597
2 | 3:54.48 | 4:31.49 | 17598 | 37971
3 | 8:26.22 | 4:12.23 | 37972 | 56894
4 | 12:38.45 | 4:31.56 | 56895 | 77275
5 | 17:10.26 | 5:51.11 | 77276 | 103611
6 | 23:01.37 | 3:46.13 | 103612 | 120574
7 | 26:47.50 | 3:24.28 | 120575 | 135902
8 | 30:12.03 | 5:54.49 | 135903 | 162501
9 | 36:06.52 | 4:48.48 | 162502 | 184149
10 | 40:55.25 | 8:00.65 | 184150 | 220214
Range status and errors
Selected range
Filename X:\Releases RAW\Henrik Freischlader Band - House In The Woods\Henrik Freischlader Band - House In The Woods.wav
Peak level 98.8 %
Extraction speed 2.6 X
Range quality 99.9 %
Test CRC F69B6C8B
Copy CRC F69B6C8B
Copy OK
No errors occurred
AccurateRip summary
Track 1 not present in database
Track 2 not present in database
Track 3 not present in database
Track 6 not present in database
Track 7 not present in database
Track 8 not present in database
Track 9 not present in database
Track 10 not present in database
None of the tracks are present in the AccurateRip database
End of status report
---- CUETools DB Plugin V2.1.3
[CTDB TOCID: dR88YhkaZdqVBE97crKnQOCq_pc-] found, Submit result: dR88YhkaZdqVBE97crKnQOCq_pc- has been confirmed
[59ac3feb] (5/5) Accurately ripped
==== Log checksum ADDE59F4CB683109A38C93DF76133E0DB651E452AF1696EF5090F6402D3394E8 ====
Скрыть
