12.10.2013 4:04:01: Known.met file version is 14 (doesn't support 64bit tags)
12.10.2013 4:04:02: Using MiniUPnPLib based implementation
12.10.2013 4:04:02: miniupnpc © 2006-2008 Thomas Bernard -
http://miniupnp.free.fr/
12.10.2013 4:04:02: Using 'C:\Users\Amadeus\AppData\Local\eMule\config\' as config directory
12.10.2013 4:04:02: Taskbar Notifier Color: R:23 G:23 B:23, Brightness: 22, Transparent: Yes
12.10.2013 4:04:02: AICHSyncThread finished
12.10.2013 4:04:02: UploadSpeedSense: Try #1. Collecting hosts...
12.10.2013 4:04:02: UploadSpeedSense: Got enough hosts. Listing the hosts that will be tracerouted:
12.10.2013 4:04:02: UploadSpeedSense: Host #1: 194.126.175.202
12.10.2013 4:04:02: UploadSpeedSense: Host #2: 83.233.30.249
12.10.2013 4:04:02: UploadSpeedSense: Host #3: 83.233.30.248
12.10.2013 4:04:02: UploadSpeedSense: Host #4: 83.140.191.163
12.10.2013 4:04:02: UploadSpeedSense: Host #5: 83.233.30.247
12.10.2013 4:04:02: UploadSpeedSense: Host #6: 83.140.191.162
12.10.2013 4:04:02: UploadSpeedSense: Host #7: 83.140.191.161
12.10.2013 4:04:02: UploadSpeedSense: Host #8: 83.140.191.160
12.10.2013 4:04:02: UploadSpeedSense: Host #9: 195.242.152.138
12.10.2013 4:04:02: UploadSpeedSense: Host #10: 83.233.30.126
12.10.2013 4:04:02: UploadSpeedSense: Starting traceroutes to find last common host.
12.10.2013 4:04:03: Cleaning up TrackedClientList, 0 clients on List...
12.10.2013 4:04:03: ...done, 0 clients left on list
12.10.2013 4:04:03: UploadSpeedSense: Pinging for TTL 1...
12.10.2013 4:04:03: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.87ms (0.87ms 0ms) TTL=1
12.10.2013 4:04:03: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.46ms (0.46ms 0ms) TTL=1
12.10.2013 4:04:03: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.40ms (0.40ms 0ms) TTL=1
12.10.2013 4:04:03: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.39ms (0.39ms 0ms) TTL=1
12.10.2013 4:04:03: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.38ms (0.38ms 0ms) TTL=1
12.10.2013 4:04:03: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.43ms (0.43ms 0ms) TTL=1
12.10.2013 4:04:04: List of UPNP devices found on the network:
12.10.2013 4:04:04: Desc:
http://192.168.1.1:53041/rootDesc.xml, st: urn:schemas-upnp-org:device:InternetGatewayDevice:1
12.10.2013 4:04:04: Found valid IGD :
http://192.168.1.1:53041/ctl/IPConn
12.10.2013 4:04:04: Our LAN IP: 192.168.1.148
12.10.2013 4:04:04: No UPnP Mappings to remove, aborting
12.10.2013 4:04:04: Sucessfully added mapping for port 51912 (TCP) on local IP 192.168.1.148
12.10.2013 4:04:04: Sucessfully added mapping for port 51922 (UDP) on local IP 192.168.1.148
12.10.2013 4:04:06: Error from 83.140.191.161: Error=11010
12.10.2013 4:04:06: UploadSpeedSense: Failure #1 to ping host! (TTL: 1 IP: 83.140.191.161 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:06: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:11: UploadSpeedSense: Failure #2 to ping host! (TTL: 1 IP: 83.140.191.161 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:11: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:11: UploadSpeedSense: Unknown pinging error! (TTL: 1 IP: 83.140.191.161 status: 10060). Reason follows. Changing ping method to see if it helps.
12.10.2013 4:04:13: Starting Kademlia
12.10.2013 4:04:13: Read 0 source, 0 keyword, and 0 load entries
12.10.2013 4:04:13: Terminating CIndexed::CLoadDataThread - finished loading data
12.10.2013 4:04:15: UploadSpeedSense: Failure #1 to ping host! (TTL: 1 IP: 83.140.191.160 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:15: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:16: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.59ms (0.59ms 0ms) TTL=1
12.10.2013 4:04:16: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.42ms (0.42ms 0ms) TTL=1
12.10.2013 4:04:16: Reply (ICMP-pinger) from 192.168.1.1: bytes=0 time=0.44ms (0.44ms 0ms) TTL=1
12.10.2013 4:04:16: UploadSpeedSense: Host at TTL 1: 192.168.1.1
12.10.2013 4:04:16: UploadSpeedSense: Pinging for TTL 2...
12.10.2013 4:04:19: Error from 194.126.175.202: Error=11010
12.10.2013 4:04:19: UploadSpeedSense: Failure #1 to ping host! (TTL: 2 IP: 194.126.175.202 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:19: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:24: UploadSpeedSense: Failure #2 to ping host! (TTL: 2 IP: 194.126.175.202 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:24: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:24: UploadSpeedSense: Unknown pinging error! (TTL: 2 IP: 194.126.175.202 status: 10060). Reason follows. Changing ping method to see if it helps.
12.10.2013 4:04:28: UploadSpeedSense: Failure #1 to ping host! (TTL: 2 IP: 83.233.30.249 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:28: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:32: Error from 83.233.30.249: Error=11010
12.10.2013 4:04:32: UploadSpeedSense: Failure #2 to ping host! (TTL: 2 IP: 83.233.30.249 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:32: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:33: UploadSpeedSense: Timeout when pinging a host! (TTL: 2 IP: 83.233.30.249 Error: 11010). Keeping host. Error info follows.
12.10.2013 4:04:33: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:37: UploadSpeedSense: Failure #1 to ping host! (TTL: 2 IP: 83.233.30.248 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:37: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:41: Error from 83.233.30.248: Error=11010
12.10.2013 4:04:41: UploadSpeedSense: Failure #2 to ping host! (TTL: 2 IP: 83.233.30.248 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:41: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:42: UploadSpeedSense: Timeout when pinging a host! (TTL: 2 IP: 83.233.30.248 Error: 11010). Keeping host. Error info follows.
12.10.2013 4:04:42: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:42: UploadSpeedSense: Could perform no ping at all at TTL 2. Trying next ttl.
12.10.2013 4:04:42: UploadSpeedSense: Pinging for TTL 3...
12.10.2013 4:04:45: Error from 194.126.175.202: Error=11010
12.10.2013 4:04:45: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 194.126.175.202 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:45: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:04:49: UploadSpeedSense: Failure #2 to ping host! (TTL: 3 IP: 194.126.175.202 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:49: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:50: UploadSpeedSense: Unknown pinging error! (TTL: 3 IP: 194.126.175.202 status: 10060). Reason follows. Changing ping method to see if it helps.
12.10.2013 4:04:50: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:54: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.233.30.249 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:54: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:04:55: Reply (ICMP-pinger) from 77.37.254.198: bytes=0 time=2.12ms (2.12ms 1ms) TTL=3
12.10.2013 4:04:58: Error from 83.233.30.248: Error=11010
12.10.2013 4:04:58: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.233.30.248 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:04:58: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:05:02: UploadSpeedSense: Failure #2 to ping host! (TTL: 3 IP: 83.233.30.248 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:02: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:03: UploadSpeedSense: Unknown pinging error! (TTL: 3 IP: 83.233.30.248 status: 10060). Reason follows. Changing ping method to see if it helps.
12.10.2013 4:05:03: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:07: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.140.191.163 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:07: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:08: Reply (ICMP-pinger) from 77.37.254.198: bytes=0 time=2.25ms (2.25ms 1ms) TTL=3
12.10.2013 4:05:11: Error from 83.233.30.247: Error=11010
12.10.2013 4:05:11: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.233.30.247 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:11: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:05:15: Stopping Kademlia
12.10.2013 4:05:15: Wrote 0 contacts to file.
12.10.2013 4:05:15: Wrote 0 source, 0 keyword, and 0 load entries
12.10.2013 4:05:15: UploadSpeedSense: Failure #2 to ping host! (TTL: 3 IP: 83.233.30.247 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:15: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:16: UploadSpeedSense: Unknown pinging error! (TTL: 3 IP: 83.233.30.247 status: 10060). Reason follows. Changing ping method to see if it helps.
12.10.2013 4:05:16: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:20: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.140.191.162 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:20: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:21: Reply (ICMP-pinger) from 77.37.254.198: bytes=0 time=2.13ms (2.13ms 1ms) TTL=3
12.10.2013 4:05:24: Error from 83.140.191.161: Error=11010
12.10.2013 4:05:24: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.140.191.161 error: 11010). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:24: IP_REQ_TIMED_OUT (11010)
12.10.2013 4:05:28: UploadSpeedSense: Failure #2 to ping host! (TTL: 3 IP: 83.140.191.161 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:28: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:29: UploadSpeedSense: Unknown pinging error! (TTL: 3 IP: 83.140.191.161 status: 10060). Reason follows. Changing ping method to see if it helps.
12.10.2013 4:05:29: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:33: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 83.140.191.160 error: 10060). Sleeping 1 sec before retry. Error info follows.
12.10.2013 4:05:33: Pinger: Error 10060: Попытка установить соединение была безуспешной, т.к. от другого компьютера за требуемое время не получен нужный отклик, или было разорвано уже установленное соединение из-за неверного отклика уже подключенного компьютера.
12.10.2013 4:05:34: Reply (ICMP-pinger) from 77.37.254.198: bytes=0 time=2.12ms (2.12ms 1ms) TTL=3
12.10.2013 4:05:37: Error from 195.242.152.138: Error=11010
12.10.2013 4:05:37: UploadSpeedSense: Failure #1 to ping host! (TTL: 3 IP: 195.242.152.138 error: 11010). Sleeping 1 sec before retry. Error info follows.
Скрыть
