Исполнитель: Bruce Dickinson
Издание: 1996, Castle Communications / RAW CD106
Жанр: Heavy metal
Тип рипа: image+cue+eac.log+covers
Формат: WAVPack (.wv)
Битрейт: lossless
Контейнер: ISO
Продолжительность: 47:42
Размер файла: 674,83 MB
Скрытый текстКомпозиции
01. Space Race (3:48)
02. Back From The Edge (4:17)
03. Inertia (3:03)
04. Faith (3:36)
05. Solar Confinement (3:19)
06. Dreamstate (3:50)
07. I Will Not Accept The Truth (3:45)
08. Inside The Machine (3:28)
09. Headswitch (2:14)
10. Meltdown (4:34)
11. Octavia (3:16)
12. Innerspace (3:32)
13. Strange Death In Paradise (5:01)
03. Inertia (3:03)
04. Faith (3:36)
10. Meltdown (4:34)
11. Octavia (3:16)
Скрыть
Скрытый текстLog EAC
EAC extraction logfile from 18. January 2012, 20:44
Bruce Dickinson / Skunkworks
Used drive : TSSTcorpCDDVDW SH-222AB Adapter: 0 ID: 1
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 6
Used interface : Installed external ASPI interface
Used output format : Internal WAV Routines
Sample format : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
1 | 0:00.00 | 3:47.45 | 0 | 17069
2 | 3:47.45 | 4:16.60 | 17070 | 36329
3 | 8:04.30 | 3:03.05 | 36330 | 50059
4 | 11:07.35 | 3:36.00 | 50060 | 66259
5 | 14:43.35 | 3:19.22 | 66260 | 81206
6 | 18:02.57 | 3:49.45 | 81207 | 98426
7 | 21:52.27 | 3:44.73 | 98427 | 115299
8 | 25:37.25 | 3:27.67 | 115300 | 130891
9 | 29:05.17 | 2:14.28 | 130892 | 140969
10 | 31:19.45 | 4:34.27 | 140970 | 161546
11 | 35:53.72 | 3:15.40 | 161547 | 176211
12 | 39:09.37 | 3:32.10 | 176212 | 192121
13 | 42:41.47 | 5:00.43 | 192122 | 214664
Range status and errors
Selected range
Filename E:\Bruce Dickinson - 1996 - Skunkworks\Bruce Dickinson - Skunkworks.wav
Peak level 99.6 %
Extraction speed 1.1 X
Range quality 99.9 %
Test CRC DE5E3938
Copy CRC DE5E3938
Copy OK
No errors occurred
AccurateRip summary
Track 1 accurately ripped (confidence 2) [60B712AD] (AR v2)
Track 2 accurately ripped (confidence 2) [FE50C100] (AR v2)
Track 3 accurately ripped (confidence 2) [836D3A15] (AR v2)
Track 4 accurately ripped (confidence 2) [A1A8DBD4] (AR v2)
Track 5 accurately ripped (confidence 2) [F0300EC4] (AR v2)
Track 6 accurately ripped (confidence 2) [94DEE7E2] (AR v2)
Track 7 accurately ripped (confidence 2) [47716FDA] (AR v2)
Track 8 accurately ripped (confidence 2) [EBEF6841] (AR v2)
Track 9 accurately ripped (confidence 2) [C1CCEFE9] (AR v2)
Track 10 accurately ripped (confidence 2) [37C647C4] (AR v2)
Track 11 accurately ripped (confidence 2) [F4B17646] (AR v2)
Track 12 accurately ripped (confidence 2) [81BD6FDC] (AR v2)
Track 13 accurately ripped (confidence 2) [71AC135B] (AR v2)
All tracks accurately ripped
End of status report
==== Log checksum F620AD1D34A987ADB20D191D5C8F9C5934D6AA17779B793FE1DCB851FDDB0E04 ====
Read mode : Secure
Selected range
Peak level 99.6 %
Test CRC DE5E3938
Copy CRC DE5E3938
Copy OK
No errors occurred
AccurateRip summary
Скрыть
Релиз от: Jocker
